April 29, 2026, 05:00:06 05:00
Author Topic: Layman heat sink design?  (Read 7241 times)
max
-Given: 1817
-Receive: 52
« on: October 05, 2016, 08:38:43 20:38 »
how to design a heat sink without going into mathematical details.
e.g requires the heat sink for LM317 which dissipating a 10watt power
using flat aluminum sheet having 3mm thickness.
-Given: 239
-Receive: 1058
« Reply #1 on: October 05, 2016, 09:18:51 21:18 »
I would say home made heatsinks are really not that good. And it will be kind of hard to do proper calculations. If I may come up with an suggestion. Calculate what kind of heatsink you need. Then find some examples on proper heatsinks from say online catalogs. Using these data you can go dumpster diving to find something that may work. If the heat sink is somewhat overdimensioned it does not matter
optikon
-Given: 1139
-Receive: 2008
« Reply #2 on: October 05, 2016, 10:38:37 22:38 »
10 Watts? Seem like you have a serious design problem. I am not sure what package you plan to use, but I think if you need to dissipate 10W, then its going to be trouble.
I suggest you look at putting an outboard transistor (look it up) to help share the power dissipation or if you can tolerate the cost and noise, look at a switch mode solution.
Have these options been considered? If it were my design and I found I needed to dissipate 10W in a single package, I would be looking at how to re design for a better situation.
Even if you find a heatsink, 10W - yuck.. you really want to do that?
CocaCola
-Given: 170
« Reply #3 on: October 05, 2016, 11:12:20 23:12 »
Irregardless of the amount of dissipation in said design as has been pointed out, it's really dollar stupid to design your own heat sinks when properly designed commercial ones are so cheap...
You can get some very decent legacy used computer CPU heatsinks for free or dirt cheap, you simply can't make or even consider designing one for the cost of buying and properly mounted they can easily dissipate 10W and laugh back at you asking for more...
« Reply #4 on: October 06, 2016, 12:56:18 00:56 »
I know you are going to hate me for this and it is shitty and super anal, but it's one of those pet peeves.  Irregardless isn't a word.  Use regardless.
http://www.dictionary.com/browse/irregardless
CocaCola
-Given: 170
« Reply #5 on: October 06, 2016, 01:36:31 01:36 »
And you might hate me for this, but I'm not a student in your anal English class...  A Nonstandard word does not equate to not being a word, it is in fact a word in common use even if your self elevated $@#$% anal pet peeve jumps up and down screaming it's not...
Words and speech in any living language are ever evolving, especially in the English language that has distinct forked dialects worldwide...
http://www.merriam-webster.com/dictionary/irregardless
Usage Discussion of irregardless
Irregardless originated in dialectal American speech in the early 20th century. Its fairly widespread use in speech called it to the attention of usage commentators as early as 1927. The most frequently repeated remark about it is that “there is no such word.” There is such a word, however. It is still used primarily in speech, although it can be found from time to time in edited prose. Its reputation has not risen over the years, and it is still a long way from general acceptance. Use regardless instead.
A good read that will most certainly get your pet peeve is a hissy...
http://www.huffingtonpost.com/jonathon-owen/yes-irregardless-is-a-wor_b_4434749.html
« Last Edit: October 06, 2016, 01:43:28 01:43 by CocaCola » Logged
-Given: 239
-Receive: 1058
« Reply #6 on: October 06, 2016, 09:29:42 09:29 »
Wow! It looks like Maxs LM317, is not the only thing that need to loose some heat here. As an aside I think I need some popcorn here. And it is not even Friday yet Cool
-Receive: 4460
« Reply #7 on: October 06, 2016, 01:39:44 13:39 »
He may want to heat his work bench, you do know winter is coming.
intel
-Given: 53
-Receive: 2144
« Reply #8 on: October 06, 2016, 02:31:07 14:31 »
Maybe this link helps a little.
http://www.myheatsinks.com/calculate/thermal-resistance-plate-fin/
http://www.daycounter.com/Calculators/Heat-Sink-Temperature-Calculator.phtml
http://my.ece.ucsb.edu/York/Bobsclass/2C/Tutorials/Heatsinks/heatsinks.htm
-Given: 239
-Receive: 1058
« Reply #9 on: October 06, 2016, 03:54:29 15:54 »
My hot iron is hot enough to heat the whole room. And I am the only one who are allowed to even touch it. Some thing do not belong in others persons hand. They do not how to clean it properly using at wet sponge and gently rub it after use
« Last Edit: October 06, 2016, 04:05:33 16:05 by Sideshow Bob » Logged
« Reply #10 on: October 19, 2016, 05:27:37 05:27 »
HAHAAHAH, sorry I got you all wound up.
Your huffington post article is absolutely right "To put it a different way, the problem with irregardless is entirely social: If you use it, you’ll be thought of as uneducated, even though everyone can understand you just fine." That was really my only point.
Anywho sorry for pissing you off @CocaCola.  Accept the doctor's most humble apologies!
And sorry to everyone for cluttering the post and going off topic.
« Last Edit: October 19, 2016, 05:43:49 05:43 by Gallymimu » Logged
CocaCola
-Given: 170
« Reply #11 on: October 19, 2016, 07:48:00 19:48 »
One could apply that same social logic to those that use vulgar slang words in their postings, something about glass houses and tossing stones..
