April 29, 2026, 06:04:45 06:04
Author Topic: Which chip measurement temperature can i used under water?  (Read 7933 times)
chithanh04dt2
-Given: 97
« on: January 07, 2013, 03:51:37 03:51 »
I need to know the temperature of water cooling in spindle for CNC machine, can i used LM35? if not, what IC i can used underwater.
« Last Edit: January 07, 2013, 04:00:15 04:00 by chithanh04dt2 » Logged
Sorry for my English.
Regard !
Okada
-Given: 29
-Receive: 188
« Reply #1 on: January 07, 2013, 04:36:16 04:36 »
What will be the temperature range you want to measure? If it is from -55 degree C to +150 degree C then you can use LM35. You have to insulate the leads of the LM35 or any other sensor properly.
« Reply #2 on: January 07, 2013, 03:55:16 15:55 »
Yes you can use LM35 as long as you isolate the leads from the water.
But, doesn't it better (and easier) to measure the temperature of the spindle it self?
Ganymed
« Reply #3 on: January 10, 2013, 12:44:47 12:44 »
Or you take a thermocouple element like NiCr-Ni wire.
It's easier to isulate.
« Reply #4 on: January 11, 2013, 07:40:17 07:40 »
I suspect you are talking about coolant used in machining that happens to run through the spindle, vs "water", and has fine metal particles in it.
Anyway, if you implement some of the cowboy ideas here, let us know which CNC's will have it so we can steer clear of being electrocuted by them  Tongue
READ THE DATA SHEET FIRST   READ THE DATA SHEET FIRST   READ THE DATA SHEET FIRST   READ THE DATA SHEET FIRST   READ THE DATA SHEET FIRST   READ THE DATA SHEET FIRST
http://www.ti.com/lit/gpn/lm35
"As with any IC, the LM35 and accompanying wiring and circuits must be kept insulated and dry, to avoid leakage and corrosion."
AND
" the LM35 can be mounted inside a sealed-end metal tube, and can then be dipped into a bath or screwed into a threaded hole in a tank"
 Grin
Use an automotive sensor and you're done.
jiakoub
-Given: 16
-Receive: 58
« Reply #5 on: January 11, 2013, 07:44:25 07:44 »
check this its cheap and waterproof
http://www.ebay.com/itm/1pcs-DS18B20-Waterproof-Digital-Thermal-Probe-or-Sensor-GOOD-/230908052812?pt=LH_DefaultDomain_0&hash=item35c331454c
gmua
-Receive: 88
« Reply #6 on: March 26, 2013, 07:35:12 19:35 »
There's a nice tutorial on www.instructables.com on how to Waterproof a LM35 Temperature Sensor
http://www.instructables.com/id/Waterproof-a-LM35-Temperature-Sensor/
Hope this helps...
« Reply #7 on: March 29, 2013, 02:50:58 14:50 »
As mentioned above,
use an insulated temperature probe, or an insulated thermistor, or an insulated thermocouple.
If you want to use an LM35 you can submerge the whole thing and wires in potting compound or even plastidip, but your thermal response will be slower.
bigtoy
-Given: 365
-Receive: 297
« Reply #8 on: April 02, 2013, 04:44:16 04:44 »
Buy it in the TO-46 (metal can) package, pot it with whatever plastic or epoxy you prefer, but leave the top of the can exposed. That way you still get good thermal connection to the water (and fast response time).
f22kma
-Given: 22
« Reply #9 on: April 02, 2013, 06:06:15 06:06 »
Thermopockets are usually quite expensive.
If you need a cheap option, we sometimes use 1/4" stainless tube brazed to a 1/4" bulkhead fitting and then braze a small rod into the tube tip to seal.
With a chip sensor and some silver loaded thermal transfer compound inserted into the tube, the performance should be more than adequate for CNC machine coolant monitoring.
You could also add a "T" fitting to the coolant supply line (with the sensor inserted into the branch of the "T") for a fully reversible installation that doesn't require modification of the CNC machine itself.
galaxy
« Reply #10 on: June 11, 2013, 07:49:57 19:49 »
my fav. is  SMT160-30-TO-18
metal, so you can seal it in a metal case without losing quick response,
digital outout, so you can have long wires without losing your signal (PWM)
sfiga69
-Given: 211
-Receive: 163
« Reply #11 on: June 11, 2013, 09:47:18 21:47 »
If you want to save money with DS18B20 Waterproof, watch these:
http://www.aliexpress.com/item/waterproof-temperature-sensor-Probe-DS18B20/758253787.html
I have taken them and work fine
« Reply #12 on: June 12, 2013, 08:48:52 08:48 »
I agree with that, they are just excellent.
