March 27, 2026, 01:39:07 13:39
Author Topic: OBDII J1850 VPW AVR Started Project  (Read 10752 times)
Matrixx
-Given: 68
-Receive: 37
« on: July 24, 2011, 11:32:38 23:32 »
Removed.
« Last Edit: July 30, 2011, 12:16:20 00:16 by Matrixx » Logged
hate
-Given: 156
-Receive: 355
« Reply #1 on: July 29, 2011, 11:59:31 11:59 »
An open-source OBDII (I hope) device would be nice and better than the one Elektor published without its firmware. Good luck with this.
Regards...
Regards...
Matrixx
-Given: 68
-Receive: 37
« Reply #2 on: July 30, 2011, 06:55:55 06:55 »
A project I'm doing to learn about OBDII J1850 VPW.
i know, I'm trying to reinvent the wheel Smiley
But learning is great.
http://www.diyprojects.zobyhost.com/
-Given: 405
-Receive: 545
« Reply #3 on: July 30, 2011, 03:05:51 15:05 »
Matrix
feel free to re-publish your project and anything else you want here and don't let the opinion of someone living under a rock discourage you
With over 400 views on the post I would have to say there is a great deal of interest in the subject no matter what the ferret seem's to think about re-inventing the wheel, which by the way engineer's do everyday
Ferret if I see you or anyone else in this forum trying to discourage or make any member feel inferior for posting any kind of project even a blinking led I will see that your account is removed and your permantly banned
Mega32
-Given: 273
-Receive: 37
« Reply #4 on: August 01, 2011, 01:52:27 13:52 »
@Matrixx
Nice project idea ..
Have a look here for inspiration etc...
http://www.mictronics.de/projects/j1850-vpw-interface/
http://www.mictronics.de/projects/usb-can-bus/
Mega32
TomJackson69
-Receive: 63
« Reply #5 on: August 01, 2011, 05:53:40 17:53 »
@Matrixx,
While you are at the beginning of the OBD II project. I think you should design the OBD that capable of interface with new car too. I think more member will be interesting and they will give you a hand.
Tom
Con Rong Chau Tien
shailesh5
Translator
-Given: 56
« Reply #6 on: August 02, 2011, 05:56:00 05:56 »
u can start with stn 1110 from scantool, lately they were sending free samples try to see with them
shailesh
Matrixx
-Given: 68
-Receive: 37
« Reply #7 on: August 02, 2011, 03:42:20 15:42 »
Thanks!   Smiley
Yes, vpw is a slow protocol. Maybe once I can get more familiar with vpw I will go to CAN as its newer and faster.
I'm uploaded the past files to the site.
http://www.diyprojects.zobyhost.com/ProjectFiles.htm
Currently writing TX and RX procedures to talk to PCM. I will update the page this weekend.
« Last Edit: August 12, 2011, 05:16:47 05:16 by Matrixx » Logged
Matrixx
-Given: 68
-Receive: 37
« Reply #8 on: August 17, 2011, 05:35:28 05:35 »
Finally I'm getting the Send vpw subroutine to work.
I wrote a separate source to act as vpw sender, to send bytes to the previous vpw receiver. I get messed adjusting the timings for the sending routine as the loop itself added some uC cycle time making the output pulses wider, but now it is working ok.
So far this is the subs code in Bascom:
Dim Snd_str As String * 30
Snd_str = "6A7C3B35FF"
 Gosub J1850_send
 Wait 1
End
Sub J1850_send
 Gosub Preparebytestosend
 For I = 1 To Nbytes
  If I = 1 Then
   Gosub Send_sof
  End If
  Tmpbyte = Txarray(i)
  Gosub Tx_data
 Next I
 Gosub Send_eof
End Sub
'Fill The Array with the Bytes to shorten waste time..
Sub Preparebytestosend
 Snd_qty = Len(snd_str) : Snd_qty = Snd_qty / 2             'Every Byte is represented by 2 characters
 If Snd_qty > 12 Then
  Print "Error: more than 12 bytes!"
  Waitms 500
  Exit Sub
 End If
 Print "Bytes Qty: " ; Snd_qty
 Nbytes = Snd_qty
 Print ""
 Print "Sending: ";
 Str_index = 1
 For I = 1 To Snd_qty
  Sbyte = Mid(snd_str , Str_index , 2)
  Tmpbyte = Hexval(sbyte)
'  Tmps = Bin(tmpbyte)
  Print "$" ; Hex(tmpbyte) ; " " ;
  Txarray(i) = Tmpbyte
  'Gosub Tx_data
  Str_index = Str_index + 2
 Next I
 'Gosub Send_eof
End Sub
Sub Tx_data
 For J = 7 To 0 Step -1
  If Tmpbyte.j = 1 Then
   If Last = 1 Then
    Gosub 1_low
   Else
    Gosub 1_high
   End If
  Else
   If Last = 1 Then
    Gosub 0_low
   Else
    Gosub 0_high
   End If
  End If
 Next J
End Sub
Project advance at: http://www.diyprojects.zobyhost.com/
« Last Edit: August 17, 2011, 05:43:53 05:43 by Matrixx » Logged
Matrixx
-Given: 68
-Receive: 37
« Reply #9 on: August 26, 2011, 02:32:24 02:32 »
I have done good advances, hope to update page this weekend, I have had a heavy weeks  Smiley
