April 11, 2026, 02:59:11 14:59
Author Topic: How about we Build a PIC Microcontroller Programmer and Development Board  (Read 8104 times)
-Receive: 4459
« on: March 05, 2010, 10:26:06 22:26 »
devices to program 8pin 14pin & 20pin devices based on a pickit2 clone and the 20pin demo board from microchip.
1. To have a LCD 4bit mode for 14pin & 20pin devices (on the 14pin & 20pin 16F690 to use port C)
2. plugin boards for relays or led display (using port B)
3. on board Usb programmer pickit2 or clone
Or have you seen a cheap good ready built one anywhere.?
« Reply #1 on: March 05, 2010, 10:59:36 22:59 »
Better to have a built-in programmer as well on the same board, in order to avoid buying a programmer.
sputnik
-Receive: 39
« Reply #2 on: March 06, 2010, 12:44:54 00:44 »
I have a design with basically those features. I will dig it out and post ASAP.
-Receive: 4459
« Reply #3 on: March 06, 2010, 03:31:37 15:31 »
To start this project off,
this is a pickit2 clone, parts used in proteus selected to show circiut, but parts used for original where through hole type.
some notes on use.
you need to use the *.hex file from microchip.
J2 fitted if usb powers programmer
J5 fitted if 12v power is used, this is the better option as it can power the board.
http://www.blueroomelectronics.com/ some thing to think about.
« Last Edit: March 16, 2010, 02:05:28 14:05 by pickit2 » Logged
samir
-Given: 27
-Receive: 21
« Reply #4 on: March 11, 2010, 10:07:53 10:07 »
Better you can have ICD2 clone or PICkit 2 clone available on net,both free and commercial version are available,get or build one board as per your requirement.
-Receive: 4459
« Reply #5 on: March 18, 2010, 10:05:59 22:05 »
so you build a clone and want to program the chip with the *.hex code, then try this.
http://www.finitesite.com/d3jsys/
draggy
-Given: 8
« Reply #6 on: April 13, 2010, 01:32:02 13:32 »
You could try:
http://www.olimex.com/dev/pic-lcd3310.html
and you may want to modify it Smiley
EDIT: done we don't code links
Posted on: April 13, 2010, 01:38:05 13:38 - Automerged
Here another one EasyPIC6:
http://www.mikroe.com/en/tools/easypic6/
Smiley
microled
-Given: 15
« Reply #7 on: April 13, 2010, 04:04:32 16:04 »
Sounds like an interesting project that I would like to be involved in.
I would say to use the PicKit3 programmer as the base for the PIC dev board since it is the newest available.
I will gladly do the schematic and PCB layout.
kalpakchiev
-Given: 34
-Receive: 68
« Reply #8 on: April 13, 2010, 05:38:15 17:38 »
 I also would like to paticipate to the project and to help .
About using PICKT3 - I read a lot of complaints about it.
".... didn't seem to take advantage of the new MCU and many of the features available for the PICkit 2 were not present on the PICkit 3....."
« Last Edit: April 13, 2010, 05:40:39 17:40 by kalpakchiev » Logged
« Reply #9 on: April 14, 2010, 06:01:54 18:01 »
It is on purpose.. Microchip knows what it is doing, so that's fine for them, PICKit3 should fail for now, later on you will see what happens if what on my mind is true, let's just wait and see.
