-Given: 582
« Reply #1 on: June 14, 2006, 11:15:34 23:15 » |
Them are my fingers on that photo:D I uploaded that ages ago and i still have got the full article and my own PCB layout for that:D Did you know they have discontinued that power supply now they do no sell it any ore :mad: After all i find it the best power supply i have used. The best part about it is that it does not cost a lot at all I have got to add that i know longer use the panel meter now i have designed my own using pic hoping to add digtial control soon. the best part about building your own PSU ifit breaksdown you can repair it, good look wizpic:)
babisko
-Given: 491
-Receive: 85
« Reply #2 on: June 16, 2006, 03:50:19 15:50 » |
to be continue:)
Can you continue this post Mr. gevv please? This Velleman's kit is very good power supply. Thanks for sharing.
-Given: 582
« Reply #3 on: June 16, 2006, 06:25:37 18:25 » |
do you want the PCB layout for it wizpic
-Given: 405
-Receive: 545
« Reply #4 on: June 16, 2006, 10:18:10 22:18 » |
I'am interest in a pcb layout
thank's
babisko
-Given: 491
-Receive: 85
« Reply #5 on: June 17, 2006, 04:44:46 04:44 » |
do you want the PCB layout for it wizpic Yes, if you have the pcb layout, please share it for us. Thanks!
Ante
« Reply #6 on: June 17, 2006, 10:42:31 10:42 » |
Hi All, Does anybody know why one of the two LM723 is called `VK7200` in the part list? Can it be to protect the kit or is it just a typo? :cool:
babisko
-Given: 491
-Receive: 85
« Reply #7 on: June 17, 2006, 08:12:51 20:12 » |
Hi All, Does anybody know why one of the two LM723 is called `VK7200` in the part list? Can it be to protect the kit or is it just a typo? :cool: I think so that Velleman wants to protect the kit and in the part list of the manual the two ICs 723 are called VK7200. Any PCB for this project?
Ante
« Reply #8 on: June 18, 2006, 09:15:07 09:15 » |
Ok thanks, that’s what I suspected.
Sorry no PCB, you could use Eagle to make a circuit board. You only need the main board; the meters are too expensive to build. I would use ready made modules which are much cheaper and easy to find.
-Given: 582
« Reply #9 on: June 18, 2006, 10:39:05 10:39 » |
I have got the PCB saved on disc some where but i had to reformat computer so lost all data but i have a copy saved some where i see if i can sort out wizpic
gevv
-Given: 161
-Receive: 537
« Reply #10 on: June 18, 2006, 06:04:57 18:04 » |
 pass:gevv not test to check
Umarım gelmez ilham perilerimin sonu... ! Modifiye uzmanı web üzerinde 320volt.com ile yaktı mumu....
-Given: 582
« Reply #11 on: June 18, 2006, 06:49:49 18:49 » |
Here is my Hack that i started to do but i never got round to finish it off fully but all info is there Now this is a fully tested and working designed i have built it and it's in my workshop working well wizpic enjoy
gevv
-Given: 161
-Receive: 537
« Reply #12 on: June 19, 2006, 01:14:43 13:14 » |
Thanks wizpic
gevv
-Given: 161
-Receive: 537
« Reply #13 on: June 19, 2006, 06:09:01 18:09 » |
  volt and amp metter pcb:D not test to check pass:gevv
-Given: 405
-Receive: 545
« Reply #14 on: June 19, 2006, 09:55:12 21:55 » |
can't read the file Gevv it say's file corrupeted?
babisko
-Given: 491
-Receive: 85
« Reply #15 on: June 20, 2006, 04:56:59 04:56 » |
Many thanks for the pdf WizPic.
I have a question: What is the value of the current resistors; (in the Velleman's 7200 kit manual marked as R37-R40 with four pieces of nichrome wire). In your pdf is marked as current resistors and in the silkscreen is reference like 7/10W (4X). What does means? 7 Ohms / 10W is very high value for this. Can you help me please?
-Given: 582
« Reply #16 on: June 20, 2006, 05:17:50 05:17 » |
I used for mine 2 10wat 0R1 which made it 0R5 because they are doubled up, i went fro terminial bloack on my design because I did have an original design and found over the years and long use the resistor wire became bad and made it have bad coonections onto PCB. wizpic
babisko
-Given: 491
-Receive: 85
« Reply #17 on: June 21, 2006, 04:49:08 04:49 » |
Thanks a lot Wizpic.
gevv
-Given: 161
-Receive: 537
« Reply #18 on: June 21, 2006, 09:19:31 09:19 » |
wizpic where R29 1k R30 220k:)
« Last Edit: June 21, 2006, 10:06:12 10:06 by gevv »
-Given: 582
« Reply #19 on: June 21, 2006, 06:49:50 18:49 » |
i will have a look it may have been i made a mistake i'll also open up my psu to make sure aswell wizpic
-Given: 582
« Reply #20 on: June 22, 2006, 06:35:25 06:35 » |
R29 was removed in my design and I forgot to remove it from parts list R29 was to do with devider for the meter PCB but i did not use that i used my own wizpic
sohel
-Given: 169
-Receive: 149
« Reply #21 on: October 16, 2006, 05:22:49 17:22 » |
first thanks to mr.gevv
who has best collection.
can u share with working project Velleman K7200 0-30v 0-10a Hack
thanks masud
mizk_electro
« Reply #22 on: October 16, 2006, 06:49:04 18:49 » |
Wizpic, Can you share again the schematic ( the working one ! )  Thks Mizk
-Given: 582
« Reply #23 on: October 16, 2006, 09:25:52 21:25 » |
Here you go the PCB
mizk_electro
« Reply #24 on: October 17, 2006, 05:41:54 05:41 » |
Thankssssssssss very much ...... Wizpic. Mizk
