May 16, 2025, 12:46:49 00:46
Pages: [1] 2  All
Author Topic: Velleman K7200 0-30v 0-10a Hack:)  (Read 34298 times)
gevv
V.I.P
-Given: 156
-Receive: 534
« on: June 14, 2006, 04:03:45 16:03 »
K7200 Not pcb difficult way:)Cheesy
All files schema photo
Download Linki: http://www.hemenpaylas.com/download/956581/K7200.rar.html
pass:gevv
Photo change video
Download Linki: http://www.hemenpaylas.com/download/956073/photo_modi.rar.html
pass:gevv
start:) Sprint-Layout 4.0 video
Download Linki: http://www.hemenpaylas.com/download/956136/dev2.rar.html
pass:gevv
programs:)
Sprint-Layout 4.0
PhotoShop
to be continue:)
Umarım gelmez ilham perilerimin sonu... ! Modifiye uzmanı web üzerinde 320volt.com ile yaktı mumu....
-Given: 562
-Receive: 409
« Reply #1 on: June 14, 2006, 11:15:34 23:15 »
Them are my fingers on that photo:D
I uploaded that ages ago and i still have got the full article and my own PCB layout for that:D
Did you know they have discontinued that power supply now they do no sell it any ore :mad:
After all i find it the best power supply i have used. The best part about it is that it does not cost a lot at all
I have got to add that i know longer use the panel meter now i have designed my own using pic hoping to add digtial control soon.
the best part about building your own PSU ifit breaksdown you can repair it,
good look
wizpic:)
babisko
-Given: 486
-Receive: 85
« Reply #2 on: June 16, 2006, 03:50:19 15:50 »
Quote from: gevv
to be continue:)
Can you continue this post Mr. gevv please?
This Velleman's kit is  very good power supply.
Thanks for sharing.
-Given: 562
-Receive: 409
« Reply #3 on: June 16, 2006, 06:25:37 18:25 »
do you want the PCB layout for it
wizpic
bbarney
-Given: 405
-Receive: 545
« Reply #4 on: June 16, 2006, 10:18:10 22:18 »
I'am interest in a pcb layout
thank's
babisko
-Given: 486
-Receive: 85
« Reply #5 on: June 17, 2006, 04:44:46 04:44 »
Quote from: Wizpic
wizpic
Yes, if you have  the pcb layout, please share it for us.
Thanks!
Ante
« Reply #6 on: June 17, 2006, 10:42:31 10:42 »
Hi All,
Does anybody know why one of the two LM723 is called `VK7200` in the part list? Can it be to protect the kit or is it just a typo? :cool:
babisko
-Given: 486
-Receive: 85
« Reply #7 on: June 17, 2006, 08:12:51 20:12 »
Quote from: Ante
Hi All,
I think so that Velleman wants to protect the kit and in the part list of the manual the two ICs 723 are called VK7200.
Any PCB for this project?
Ante
« Reply #8 on: June 18, 2006, 09:15:07 09:15 »
Ok thanks, that’s what I suspected.
Sorry no PCB, you could use Eagle to make a circuit board. You only need the main board; the meters are too expensive to build. I would use ready made modules which are much cheaper and easy to find.
-Given: 562
-Receive: 409
« Reply #9 on: June 18, 2006, 10:39:05 10:39 »
I have got the PCB saved on disc some where but i had to reformat computer so lost all data but i have a copy saved some where i see if i can sort out
wizpic
gevv
V.I.P
-Given: 156
-Receive: 534
« Reply #10 on: June 18, 2006, 06:04:57 18:04 »
pass:gevv
not test to check
-Given: 562
-Receive: 409
« Reply #11 on: June 18, 2006, 06:49:49 18:49 »
Here is my Hack that i started to do but i never got round to finish it off fully but all info is there
Now this is a fully tested and working designed i have built it and it's in my workshop working well
wizpic
enjoy
gevv
V.I.P
-Given: 156
-Receive: 534
« Reply #12 on: June 19, 2006, 01:14:43 13:14 »
Thanks  wizpic
gevv
V.I.P
-Given: 156
-Receive: 534
« Reply #13 on: June 19, 2006, 06:09:01 18:09 »
volt and amp metter pcb:D
not test to check
pass:gevv
bbarney
-Given: 405
-Receive: 545
« Reply #14 on: June 19, 2006, 09:55:12 21:55 »
can't read the file Gevv it say's file corrupeted?
babisko
-Given: 486
-Receive: 85
« Reply #15 on: June 20, 2006, 04:56:59 04:56 »
Many thanks for the pdf WizPic.
I have a question: What is the value of the current resistors; (in the Velleman's 7200 kit manual marked as R37-R40 with four pieces of nichrome wire).
In your pdf is marked as current resistors and in the silkscreen is reference like 7/10W (4X). What does means? 7 Ohms / 10W is very high value for this.
Can you help me please?
-Given: 562
-Receive: 409
« Reply #16 on: June 20, 2006, 05:17:50 05:17 »
I used for mine 2 10wat 0R1 which made it 0R5 because they are doubled up, i went fro terminial bloack on my design because I did have an original design and found over the years and long use the resistor wire became bad and made it have bad coonections onto PCB.
wizpic
babisko
-Given: 486
-Receive: 85
« Reply #17 on: June 21, 2006, 04:49:08 04:49 »
Thanks a lot Wizpic.
gevv
V.I.P
-Given: 156
-Receive: 534
« Reply #18 on: June 21, 2006, 09:19:31 09:19 »
wizpic  where R29 1k R30 220k:)
« Last Edit: June 21, 2006, 10:06:12 10:06 by gevv » Logged
-Given: 562
-Receive: 409
« Reply #19 on: June 21, 2006, 06:49:50 18:49 »
i will have a look it may have been i made a mistake i'll also open up my psu to make sure aswell
wizpic
-Given: 562
-Receive: 409
« Reply #20 on: June 22, 2006, 06:35:25 06:35 »
R29 was removed in my design and I forgot to remove it from parts list R29 was to do with devider for the meter PCB but i did not use that i used my own
wizpic
sohel
-Given: 169
-Receive: 149
« Reply #21 on: October 16, 2006, 05:22:49 17:22 »
first thanks to mr.gevv
who has best collection.
can u share with working project Velleman K7200 0-30v 0-10a Hack
thanks
masud
mizk_electro
« Reply #22 on: October 16, 2006, 06:49:04 18:49 »
wizpic
Wizpic,
Can you share again the schematic ( the working one ! )  Smiley
Thks
Mizk
-Given: 562
-Receive: 409
« Reply #23 on: October 16, 2006, 09:25:52 21:25 »
Here you go the PCB
mizk_electro
« Reply #24 on: October 17, 2006, 05:41:54 05:41 »
Thankssssssssss very much ...... Wizpic.
Mizk  Smiley
Pages: [1] 2  All
