April 26, 2026, 12:07:14 00:07
Author Topic: avr + 1wire  (Read 7784 times)
max_buddy
« on: May 19, 2008, 06:46:47 18:46 »
hi
i'm having a problem with a ds18b20 sensor and an atmega8l @ 4mhz (tested at 8 too).
 testing using bascom and the device enumeration (1wirecount function) returns 0 devices. also the err value is 1.
the exact problem appears on bascom's website but without a solution. i have tested with 2 sensors so i't not likely both are broken.
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=762&highlight=1wirecount
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=1673&highlight=1wirecount
http://www.serasidis.gr/forums/forum_posts.asp?PN=1&TID=70
the sensor is properly connected, there is a pull-up resistor and so on. anyone has another idea?
many thanks
karthikeyan_sw
« Reply #1 on: May 19, 2008, 07:19:06 19:19 »
put a scope to grab the signals if you dont have scope then create the same circuit in proteus simulator and then try debugging using the oscilloscopes.
max_buddy
« Reply #2 on: May 20, 2008, 09:35:00 09:35 »
too bad i don't have a scope... it works in proteus
so probably i've got 2 broken sensors.... damn
bugmike25
-Given: 15
« Reply #3 on: May 20, 2008, 06:16:37 18:16 »
Because it works in Proteus deos not mean it works on your hardware.  I designed and tested an 8051 MCU interfaced with a DS18S20 temp. sensor.  It worked fine on the hardware but didnt work when tested using proteus.  The best way to check if the sensors are damaged is by using a scope and see if the output voltage is changing on the data line.
max_buddy
« Reply #4 on: May 21, 2008, 11:12:12 11:12 »
ok, thanks for replys
i'll try to get my hands on a scope to check the sensors
