April 22, 2026, 12:20:47 00:20
Pages: [1] 2  All
Author Topic: ccs pcwhdV4.068.exe  (Read 18490 times)
ramyses
-Receive: 66
« on: February 22, 2008, 01:15:38 01:15 »
for update
pcwhdupdV4.068.exe only
http://rapidshare.com/files/93829518/pcwhdupd_V4_068.exe.html
join!
Ramyses, Manaus, AM
wnmaximino
-Given: 47
-Receive: 202
Homer
« Reply #1 on: February 22, 2008, 01:41:04 01:41 »
Working 100%
Recent Changes:
 4.068  RS232 software timing improved a little
 4.068  A math error (since 4.067) when mixing ints and floats is fixed
 4.067  An addressmod bug has been fixed
 4.067  A problem with LCD_SYMBOL when using more than 8 segments per symbol is fixed
 4.067  An undeserved syntax error some users got in #bit is fixed
 4.067  A number of PCD problems have been fixed
 4.066  New PCD built in functions have been added
 4.066  A problem with Vista access violations is fixed
« Last Edit: February 22, 2008, 01:44:46 01:44 by wnmaximino » Logged
OleRuffo
-Given: 36
« Reply #2 on: February 22, 2008, 02:21:48 02:21 »
Interesting!
Same project compiled with this new incarnation is about 20 bytes shorter than before, maybe they do a housekeeping to the core? anyway i will do a check in the ICD to be sure, if i found anything wrong i will let you know.
this is a good one for this compiler!
TigerX
« Reply #3 on: February 22, 2008, 08:31:37 08:31 »
Can anyone say what is the difference form the earlier versions?. Version history says only fixed problems..
OleRuffo said an intersitng point. If it is true, well..
fmssp
-Given: 42
-Receive: 109
« Reply #4 on: February 22, 2008, 04:37:38 16:37 »
Alternative link:
http://w13.easy-share.com/1699661039.html
pcwhdupd_V4_068.rar (13,91 MB)
From Russia with love... ;-)))
fabric77
-Receive: 31
« Reply #5 on: February 22, 2008, 08:18:13 20:18 »
Could somebody explain how should we apply this update?
Do we need seperate patch or an installation will be enough on a prior CCS version, such as 4.065?
here is another mirror:  http://www.zshare.net/download/7971700b3728a3/
« Last Edit: February 22, 2008, 08:55:49 20:55 by fabric77 » Logged
cepa
-Given: 208
-Receive: 708
« Reply #6 on: February 22, 2008, 08:47:52 20:47 »
I have a version 4.065
and just i click on a pcwhdupd_V4_068.exe. autamatique install 4.068
OleRuffo
-Given: 36
« Reply #7 on: February 22, 2008, 10:39:36 22:39 »
Hi fabric:
Just install it over the old one and you will be fine  Wink
BTW i just check the behavior of my project and it works fine, i will install the old version in another computer to compare the assembler code, cause i don't have an old asm file saved.  Sad
Cheers
jzaghal
-Given: 508
-Receive: 55
« Reply #8 on: February 23, 2008, 07:32:12 07:32 »
This link is with a working Keygen:
http://rapidshare.com/files/94058811/CCS-PCWHD_v4.068_KeyGen.rar.html
Enjoy.
fabric77
-Receive: 31
« Reply #9 on: February 23, 2008, 10:19:41 10:19 »
No, need to double download files:
Just apply keygen to this new update. That's it.
The Puma
-Given: 75
-Receive: 75
« Reply #10 on: February 23, 2008, 12:48:14 12:48 »
See for the keygen my link
http://www.sonsivri.com/forum/index.php?topic=10822.0
xzb
-Given: 16
« Reply #11 on: February 24, 2008, 04:38:46 04:38 »
this is keyfilegen
Kombinator
-Given: 40
-Receive: 33
« Reply #12 on: February 24, 2008, 11:13:58 11:13 »
and instal pcwhdupd_V4_068.exe.
but don't create new project.
TigerX
« Reply #13 on: February 25, 2008, 08:06:32 08:06 »
I have installed 6.068 onto 4.065 and everything is OK.
NO need to keygen also. But I didn't find any code compression advantage.
I had a project %99 ROM usage with 4.065 and also I have complied 4.068 and same ROM %99 usage. No advantage I didn't obsve.
xzb
-Given: 16
« Reply #14 on: February 25, 2008, 09:08:51 09:08 »
update 6.068 onto 4.065 is not need keygen.
working is Ok!
OleRuffo
-Given: 36
« Reply #15 on: February 28, 2008, 05:27:26 05:27 »
TigerX:
You are right! my mistake, sorry, i was looking an old asm listing before an optimization i did at hand over a "built in" CCS function, the code length is the very same....sorry  Sad
Cheers
MAXPAYNE
-Given: 516
-Receive: 376
It's a little funny......
« Reply #16 on: February 29, 2008, 06:29:41 18:29 »
I am getting this error...!!!
wnmaximino
-Given: 47
-Receive: 202
Homer
« Reply #17 on: February 29, 2008, 07:28:40 19:28 »
Install CCS PCWHD 4.065.
Use the keyfilegen for create license file (CRG).
Install CCS PCWHD 4.068 Update.
100% working with me!!
Tested with Windows XP SP2 and Windows Vista Ultimate!!
I did a test with only 4.068 and worked!
« Last Edit: February 29, 2008, 07:39:02 19:39 by wnmaximino » Logged
etm503
« Reply #18 on: March 02, 2008, 06:40:08 06:40 »
There is no code compression advantage for me neither for ROM or RAM usage over 4.065.
Maybe there are a few specific routines that have been optimised.
OleRuffo
-Given: 36
« Reply #19 on: March 03, 2008, 04:44:00 04:44 »
nope, as i stated before, i was looking an old asm file and was my fault, there are no code optimization in this release
Cheers
MAXPAYNE
-Given: 516
-Receive: 376
« Reply #20 on: March 03, 2008, 06:28:48 18:28 »
Copy the crg files to installed directory.
No need of CCS PCWHD 4.065 Grin Grin Grin
The Puma
-Given: 75
-Receive: 75
« Reply #21 on: March 03, 2008, 09:12:31 21:12 »
The procedure MAXPAYNE descripted worked fine
You can install 4.068 version, no need to upgrade from older version
The latest version is now 4.069
Is someone can upload it, we all have a nice day  Wink
A new release of the CCS C compiler for PICmicro(r) microcontrollers
has been released. The new version is: 4.069
Recent changes include:
4.069  Compiler R/W files are now kept in the windows APPDATA directory
4.069  An interrupt bug on many PCD devices is fixed
4.069  A PCD optimization error is fixed
Updated:  PIC16F688
Updated:  PIC16F886
« Last Edit: March 03, 2008, 09:16:39 21:16 by The Puma » Logged
cjeffries1
-Given: 253
-Receive: 176
« Reply #22 on: March 06, 2008, 04:02:44 16:02 »
Does reason appear this message?((You are not allowed to view links, check the Announcements Board ))
and don't I get to unload the files.
Did u check the announcement board? Have u posted something useful? Are you an active participant? No? Then u don't enjoy the benefits of this board.
ata_tr
-Given: 28
« Reply #23 on: March 07, 2008, 11:03:49 23:03 »
I think CCS working mostly on PCD updates nowadays. PIC C v4.068 works fine, waiting for 4.069  Cheesy
Denthe777
« Reply #24 on: March 27, 2008, 11:04:42 11:04 »
I have been use for serial interface in microchip c30 compiler but is not working So thank you for post this compiler
Pages: [1] 2  All
