April 29, 2026, 08:20:05 08:20
Pages: [1] 2  All
Author Topic: Microcontroller controlled power supply  (Read 18649 times)
cesurcelik
« on: March 30, 2006, 10:48:40 10:48 »
hi all,
i'd like make  digital power supply,
does anyone have a microcontroller controlled power supply's  schematics and softwares( about 3a-25v)
thank you in advance
Zexy
-Given: 28
« Reply #1 on: March 30, 2006, 02:10:23 14:10 »
I have the same idea, but don't have time Sad I uploaded some digitally controlled PSU found somewhere in circuit cellars. It was with 8051 familly uC...
http://rapidshare.de/files/16789544/psu.zip.html
jeanninemtv
-Given: 57
-Receive: 25
« Reply #2 on: March 30, 2006, 03:23:45 15:23 »
interesting!!!  thankss----
-Given: 582
« Reply #3 on: March 30, 2006, 08:27:59 20:27 »
Here is another one that a PIC16F84 and you can control it by PC aswell it was pulished in elektor electonics.
http://rapidshare.de/files/16819909/Digital_power_supply.rar.html
I was in the process of converting it into Proton Basic but never got to finishing it of as ohter work kept me busy Cheesy
enjoy
wizpic:o
-Given: 405
-Receive: 545
« Reply #4 on: March 30, 2006, 11:46:02 23:46 »
I don't suppose you ever thought of finnishing it,I can't make head or tail out of the original code but in proton or pic basic maybe Smiley
Lumos
-Given: 74
« Reply #5 on: March 31, 2006, 07:24:27 07:24 »
One finds the origin
  http://www.tldp.org/linuxfocus/Deutsch/November2002/article251.shtml
  my variation with PIC into Proteus and Proton+
best regards
« Last Edit: March 31, 2006, 07:58:14 07:58 by Lumos » Logged
-Given: 405
-Receive: 545
« Reply #6 on: March 31, 2006, 11:18:02 11:18 »
thank's Lumos
I'll give this a try
cesurcelik
« Reply #7 on: March 31, 2006, 03:21:09 15:21 »
hi,
thank you for  each response ,i appreciated them.
jeanninemtv
-Given: 57
-Receive: 25
« Reply #8 on: March 31, 2006, 04:16:30 16:16 »
super interesting gadget!!
but, you have any schema & program to program 27xxxeproms  and (important to me) 28XXXeeproms?
thanks guys
Faros
-Given: 141
-Receive: 178
« Reply #9 on: April 01, 2006, 12:42:31 00:42 »
Hi Jeanninemtv
As you sure know that due to large capacity of 27,28 xxx series , its programmer has to be PC interfaced ...
use the link for the schematic, layout and part list for the Eprom Programmer
you can use this link HERE
Hope that it may help in your important task :cool:
jeanninemtv
-Given: 57
-Receive: 25
« Reply #10 on: April 01, 2006, 04:46:32 16:46 »
thanks faros & lumos.
good grabber ...
Hey Lumos,,,
ONe question... one suggestion too
have you tested on board yo' soft.... i tested it on proteus... cool ... workss
there's no matter about the connection between of transformer and out of regulated psu..=?
the author of the article for AVR says no problem but.-- i need another opinion...
and second... you dont have any buttom to change the status to HI-Z  (V=0 I=0 )to enable changes on V and I...
on the real psu's on my faculty's lab this function is enabled... i think i can put any interruption (rbo i e. ) to make available.
Good Good Work friend ...
thanks
« Last Edit: April 01, 2006, 04:50:16 16:50 by jeanninemtv » Logged
Lumos
-Given: 74
« Reply #11 on: April 01, 2006, 06:19:56 18:19 »
Hi Jeanninemtv
not only the software works also...the hardware.
(see my picture)
I use tipping over nonlocking keys for it vote the voltage and the current.
(Picture)
being used two Transformer
Powerpart:
Transformer and Bridge Rectifiers
DC IN  Pin 1 = + 30V
DC IN Pin 2 = Case
DC IN Pin 3 = Ground
DC OUT Pin 1= Ground
DC OUT Pin 3 = regulated Voltage
Regulator Part:
9V AC
-Given: 582
« Reply #12 on: April 01, 2006, 10:38:26 22:38 »
lumos
your power supply looks cool and i like the LED readout one aswell
Is the 7 seg meter done using a PC and  in Proton code if so you want to share it with us
I shall have agoat getting  the power supply up and built soon, I was going to use your code to contorl a power supply that i have already built up 0-30v 0-10amps (velleman kit) and use op-amp has voltage doubler and basicily replace the pots but your design nice and simple
cheers
wizpic
jeanninemtv
-Given: 57
-Receive: 25
« Reply #13 on: April 02, 2006, 01:22:01 01:22 »
thanks 4 the photo....
i still think that the 0V 0A state during the setup of the psu is good...
i'll make an code and i will send you for review...
thanks
another question...
i have a pic proggrammer compatible with epicwin, you know, the 7407 and the transistor on lpt...
if i program an pic 18, i can read and erase an program it normally...?  ther;e no problem?
thanks
Lumos
-Given: 74
« Reply #14 on: April 02, 2006, 06:47:35 06:47 »
Hi Wizpic
my voltmeter as an attachment
to jeanninemtv
everybody is the last adjusted left to himself worth switch on.
pic18 burns my self-made epic without problems
the prog_plug in the shematic is for ICSP with bootloader and level adaptation to rs232 .
bye
« Last Edit: April 02, 2006, 06:54:39 06:54 by Lumos » Logged
-Given: 405
-Receive: 545
« Reply #15 on: April 02, 2006, 01:12:29 13:12 »
Lumos
I think everybody want's to make your power supply which looks really good in your picture very nice job.is it possiable for you to put all the files in one zip so everything is together and easier to keep track off
thank's
Lumos
-Given: 74
« Reply #16 on: April 02, 2006, 02:21:05 14:21 »
hi bbarney
 all this is what I have ...
 http://rapidshare.de/files/17023473/Powersupply_complete.rar.html
-Given: 405
-Receive: 545
« Reply #17 on: April 02, 2006, 04:18:31 16:18 »
Thank's Lumos
jeanninemtv
-Given: 57
-Receive: 25
« Reply #18 on: April 02, 2006, 05:10:21 17:10 »
thanks for share !!!
jeanninemtv
-Given: 57
-Receive: 25
« Reply #19 on: April 03, 2006, 12:37:54 00:37 »
ok
then the 18 series works ok with programmers. ok iwill try i
what about test this soft on 16f877a ?
munaf
« Reply #20 on: April 03, 2006, 03:47:09 15:47 »
Dear Zexy
psu.zip is not available on address blew:
any one who have this file please send me.
thanks.
https://SecreLocal.com - Live Chat Online - No Selfie - Anonymous Adult Dating -   Meet Girls Online
-Given: 405
-Receive: 545
« Reply #21 on: April 03, 2006, 06:49:31 18:49 »
the link works I just tried it
munaf
« Reply #22 on: April 04, 2006, 03:04:09 15:04 »
Dear Lumos
I download schematic of PIC18f252 based power supply.  It seems interesting, but some clarifications are required. I hope you clear them:
1.         Crystal value?
2.         Power transistor No.?
3.         R2 to R17 resister wattage?
4.         if we want to additional current , we add more transistor and what changes will be  made in code?
5.         PIC18f252 is not available; can we replace it with 16f876?
6.         When we compile the code error will be display***Variable FLOAT_DISPLAY_TYPE** not define?
Please help me
Lumos
-Given: 74
« Reply #23 on: April 04, 2006, 05:12:30 17:12 »
Hello Munaf
  for your questions
  1.  Crystal20MHz
2. Powertransistor 2N3055
3. Resistors  250 mW
4. the transistors with the resistors being included parallel to the other transistors ...
  it has to be wondered whether a multiplier resistor would be advisable at the respective Basis for the purpose of operating point
  5.are available two PWM hardwareoutputs  if this is not a problem
  6.Float_display_type is not a Variable. Is a "Declare" of  Proton+
 to increase the precision
 I hope to  have helped you
 bye
« Last Edit: April 04, 2006, 06:33:02 18:33 by Lumos » Logged
munaf
« Reply #24 on: April 05, 2006, 02:20:44 02:20 »
Dear friends
hi,
I upload a basic stamp based digital power suplly link below.
In this suplly used memkey with BS2.
Memkey is very costly, any salution.
try it and enjoy
http://rapidshare.de/files/17226384/digital_power_supply.rar.html
here is I upload a motorola 68HC08 based digital power supply.
http://rapidshare.de/files/17228750/programable_Power_suplly.zip.html
here is good bench top Power suplly. i make it. it is realy good.
http://www.uoguelph.ca/~antoon/circ/ps3010/ps3010a.html
« Last Edit: April 05, 2006, 02:24:03 02:24 by munaf » Logged
Pages: [1] 2  All
