cesurcelik
« on: March 30, 2006, 10:48:40 10:48 » |
hi all, i'd like make digital power supply, does anyone have a microcontroller controlled power supply's schematics and softwares( about 3a-25v) thank you in advance
Zexy
-Given: 28
« Reply #1 on: March 30, 2006, 02:10:23 14:10 » |
Hi, I have the same idea, but don't have time I uploaded some digitally controlled PSU found somewhere in circuit cellars. It was with 8051 familly uC... http://rapidshare.de/files/16789544/psu.zip.html
jeanninemtv
-Given: 57
-Receive: 25
« Reply #2 on: March 30, 2006, 03:23:45 15:23 » |
interesting!!! thankss----
-Given: 541
-Receive: 408
« Reply #3 on: March 30, 2006, 08:27:59 20:27 » |
Here is another one that a PIC16F84 and you can control it by PC aswell it was pulished in elektor electonics. http://rapidshare.de/files/16819909/Digital_power_supply.rar.html I was in the process of converting it into Proton Basic but never got to finishing it of as ohter work kept me busy enjoy wizpic:o
bbarney
-Given: 405
-Receive: 545
« Reply #4 on: March 30, 2006, 11:46:02 23:46 » |
I don't suppose you ever thought of finnishing it,I can't make head or tail out of the original code but in proton or pic basic maybe
bbarney
-Given: 405
-Receive: 545
« Reply #6 on: March 31, 2006, 11:18:02 11:18 » |
thank's Lumos I'll give this a try bbarney
cesurcelik
« Reply #7 on: March 31, 2006, 03:21:09 15:21 » |
hi, thank you for each response ,i appreciated them.
jeanninemtv
-Given: 57
-Receive: 25
« Reply #8 on: March 31, 2006, 04:16:30 16:16 » |
super interesting gadget!! but, you have any schema & program to program 27xxxeproms and (important to me) 28XXXeeproms? thanks guys
Faros
-Given: 141
-Receive: 178
« Reply #9 on: April 01, 2006, 12:42:31 00:42 » |
Hi Jeanninemtv
As you sure know that due to large capacity of 27,28 xxx series , its programmer has to be PC interfaced ... use the link for the schematic, layout and part list for the Eprom Programmer you can use this link HEREHope that it may help in your important task :cool:
jeanninemtv
-Given: 57
-Receive: 25
« Reply #10 on: April 01, 2006, 04:46:32 16:46 » |
thanks faros & lumos. good grabber ... Hey Lumos,,, ONe question... one suggestion too have you tested on board yo' soft.... i tested it on proteus... cool ... workss there's no matter about the connection between of transformer and out of regulated psu..=? the author of the article for AVR says no problem but.-- i need another opinion... and second... you dont have any buttom to change the status to HI-Z (V=0 I=0 )to enable changes on V and I... on the real psu's on my faculty's lab this function is enabled... i think i can put any interruption (rbo i e. ) to make available. Good Good Work friend ... thanks
« Last Edit: April 01, 2006, 04:50:16 16:50 by jeanninemtv »
Lumos
-Given: 73
« Reply #11 on: April 01, 2006, 06:19:56 18:19 » |
Hi Jeanninemtv
not only the software works also...the hardware. (see my picture)
I use tipping over nonlocking keys for it vote the voltage and the current. (Picture)
being used two Transformer
Powerpart: Transformer and Bridge Rectifiers DC IN Pin 1 = + 30V DC IN Pin 2 = Case DC IN Pin 3 = Ground
DC OUT Pin 1= Ground DC OUT Pin 3 = regulated Voltage
Regulator Part: 9V AC
-Given: 541
-Receive: 408
« Reply #12 on: April 01, 2006, 10:38:26 22:38 » |
lumos
your power supply looks cool and i like the LED readout one aswell Is the 7 seg meter done using a PC and in Proton code if so you want to share it with us I shall have agoat getting the power supply up and built soon, I was going to use your code to contorl a power supply that i have already built up 0-30v 0-10amps (velleman kit) and use op-amp has voltage doubler and basicily replace the pots but your design nice and simple cheers wizpic
jeanninemtv
-Given: 57
-Receive: 25
« Reply #13 on: April 02, 2006, 01:22:01 01:22 » |
thanks 4 the photo.... i still think that the 0V 0A state during the setup of the psu is good... i'll make an code and i will send you for review... thanks another question... i have a pic proggrammer compatible with epicwin, you know, the 7407 and the transistor on lpt... if i program an pic 18, i can read and erase an program it normally...? ther;e no problem? thanks
Lumos
-Given: 73
« Reply #14 on: April 02, 2006, 06:47:35 06:47 » |
Hi Wizpic
my voltmeter as an attachment
to jeanninemtv
everybody is the last adjusted left to himself worth switch on.
pic18 burns my self-made epic without problems
the prog_plug in the shematic is for ICSP with bootloader and level adaptation to rs232 .
bye
« Last Edit: April 02, 2006, 06:54:39 06:54 by Lumos »
bbarney
-Given: 405
-Receive: 545
« Reply #15 on: April 02, 2006, 01:12:29 13:12 » |
Lumos I think everybody want's to make your power supply which looks really good in your picture very nice job.is it possiable for you to put all the files in one zip so everything is together and easier to keep track off thank's
Lumos
-Given: 73
« Reply #16 on: April 02, 2006, 02:21:05 14:21 » |
bbarney
-Given: 405
-Receive: 545
« Reply #17 on: April 02, 2006, 04:18:31 16:18 » |
Thank's Lumos
jeanninemtv
-Given: 57
-Receive: 25
« Reply #18 on: April 02, 2006, 05:10:21 17:10 » |
thanks for share !!!
jeanninemtv
-Given: 57
-Receive: 25
« Reply #19 on: April 03, 2006, 12:37:54 00:37 » |
ok then the 18 series works ok with programmers. ok iwill try i what about test this soft on 16f877a ?
munaf
« Reply #20 on: April 03, 2006, 03:47:09 15:47 » |
Dear Zexy Hi, psu.zip is not available on address blew: http://rapidshare.de/files/16789544/psu.zip.htmany one who have this file please send me. thanks.
bbarney
-Given: 405
-Receive: 545
« Reply #21 on: April 03, 2006, 06:49:31 18:49 » |
the link works I just tried it
munaf
« Reply #22 on: April 04, 2006, 03:04:09 15:04 » |
Dear Lumos
I download schematic of PIC18f252 based power supply. It seems interesting, but some clarifications are required. I hope you clear them:
1. Crystal value?
2. Power transistor No.?
3. R2 to R17 resister wattage?
4. if we want to additional current , we add more transistor and what changes will be made in code?
5. PIC18f252 is not available; can we replace it with 16f876?
6. When we compile the code error will be display***Variable FLOAT_DISPLAY_TYPE** not define?
Please help me
Lumos
-Given: 73
« Reply #23 on: April 04, 2006, 05:12:30 17:12 » |
Hello Munaf
for your questions
1. Crystal20MHz
2. Powertransistor 2N3055
3. Resistors 250 mW
4. the transistors with the resistors being included parallel to the other transistors ...
it has to be wondered whether a multiplier resistor would be advisable at the respective Basis for the purpose of operating point
5.are available two PWM hardwareoutputs if this is not a problem
6.Float_display_type is not a Variable. Is a "Declare" of Proton+
to increase the precision
I hope to have helped you
bye
« Last Edit: April 04, 2006, 06:33:02 18:33 by Lumos »
picstudent
« Reply #25 on: April 06, 2006, 03:14:19 03:14 » |
hello. i changed the processor and burned an 877a.... now its working!!
« Last Edit: April 06, 2006, 04:30:32 16:30 by picstudent »
... rego ... who are are you really ?
mechatron
« Reply #26 on: April 08, 2006, 06:26:51 18:26 » |
thanks
picstudent
« Reply #27 on: April 09, 2006, 02:56:14 02:56 » |
thanks, ì`ll try to make my own board and buttons configuration to use less buttons... thanks a lot lumos
bbarney
-Given: 405
-Receive: 545
« Reply #28 on: April 28, 2006, 01:44:40 01:44 » |
Have you tried to make those changes Picstudent?
gevv
V.I.P
-Given: 145
-Receive: 533
« Reply #29 on: May 10, 2006, 08:06:52 20:06 » |
Umarım gelmez ilham perilerimin sonu... ! Modifiye uzmanı web üzerinde 320volt.com ile yaktı mumu....
-Given: 541
-Receive: 408
« Reply #30 on: December 16, 2006, 11:27:40 23:27 » |
Can anybody re-upload Lumos power supply design the one that is all in one has i lost it and want to start work on it again
cheers
wizpic
bbarney
-Given: 405
-Receive: 545
« Reply #31 on: December 17, 2006, 01:20:54 01:20 » |
-Given: 541
-Receive: 408
« Reply #32 on: December 17, 2006, 10:00:05 10:00 » |
Thanks bbarney just what i wanted cheers wizpic
sohel
-Given: 167
-Receive: 149
« Reply #33 on: December 17, 2006, 01:30:42 13:30 » |
thanks
raham
« Reply #34 on: December 18, 2006, 04:26:12 04:26 » |
nice powersupply and function generator.Thanx Bbarney
bbarney
-Given: 405
-Receive: 545
« Reply #35 on: December 18, 2006, 05:00:24 05:00 » |
All the thank's should be directed at Lumos,this is his baby thank's again Lumos
sohel
-Given: 167
-Receive: 149
« Reply #36 on: December 19, 2006, 07:37:08 07:37 » |
can u share ur 16f877a sorce code where u make change, thanks
-Given: 541
-Receive: 408
« Reply #37 on: December 19, 2006, 06:32:31 18:32 » |
can u share ur 16f877a sorce code where u make change, thanks Basicily because it's PDS you change device I.E Device 18F252 to Device 16F877A and that's it PDS very good for this good luck wizpic
sohel
-Given: 167
-Receive: 149
« Reply #38 on: December 20, 2006, 08:30:21 20:30 » |
I dont know where is my fault. I can find full scamitic diagramme . where to cunnect J2 adc port. please share full.
please help me
thanks
-Given: 541
-Receive: 408
« Reply #39 on: December 20, 2006, 10:51:19 22:51 » |
Shoel sorry i don't understand what you mean but here goes anyway the file contains all the information to build the PSU there are 2 parts the Mother board and the power baord
J2 is the connector for all the push button switches which are not shown on the shcematic common all one side of the push button to +5V and the other side to the pins on J2, I would also use something like a 4K7 resistor on the J2 pins to ground this just stops any interferance in pic
hope that helps
wizpic
sohel
-Given: 167
-Receive: 149
« Reply #40 on: December 21, 2006, 06:21:55 18:21 » |
sorry for my mistake
declare all_digital
its disable adc. thats why i am confused.
thanks
Faros
-Given: 141
-Receive: 178
« Reply #41 on: January 30, 2007, 03:09:04 03:09 » |
Hi Jeanninemtv
vacsaa
-Given: 45
« Reply #42 on: April 18, 2008, 03:00:32 15:00 » |
Help!
I' am declare all input digital.
The tranzisztor is hot.
The board is good?
