April 16, 2026, 09:28:14 21:28
Author Topic: USB Driver for PIC18F4550  (Read 29832 times)
xane
« on: January 10, 2008, 09:25:43 09:25 »
I am looking for some tutorials/help on writing USB device driver for PIC18F4550 based board.
The tools I prefer is VB6, C#, VB.net
If someone knows the links would be helpfull for me
xane
lyk
« Reply #1 on: January 10, 2008, 10:44:06 10:44 »
Look on http://www.microchip.com
memed500
« Reply #2 on: January 10, 2008, 11:58:36 11:58 »
http://www.create.ucsb.edu/~dano/CUI/
http://www.microchipc.com/sourcecode/
setoy
« Reply #3 on: January 10, 2008, 12:03:40 12:03 »
IMHO, writing your driver (in VB!) if you haven't any experience with writing drivers is senseless and too heavy. On http://www.microchip.com you will find nothing, look on microsoft -> MSDN -> DDK. But better way, use someone of microchip otr CCS drivers or libusb (open source USB driver)
J1M
« Reply #4 on: January 10, 2008, 02:22:31 14:22 »
Hi there, here you have articles that I´ve published on my webpage:
- PicWinUSB: PIC18F2550 USB Example with CCS, VC#, WinUSB, Win Vista & XP (x64 and x86 versions)
http://www.hobbypic.com/index.php?option=com_content&task=view&id=31&Itemid=1&lang=en
- PicUSB: PIC18F2550 USB Example with CCS, VC#, MCHPUSBAPI, Win XP & 98
http://www.hobbypic.com/index.php?option=com_content&task=view&id=14&Itemid=27&lang=en
- PicUSBNut: PIC18F2550 USB Example with CCS, VC#, MCHPUSBAPI, Win XP & 98
http://www.hobbypic.com/index.php?option=com_content&task=view&id=23&Itemid=27&lang=en
- PicUSB Stuff: PIC18F2550 USB Example with CCS, VC++, VB, Delphi, Labview and Linux, MCHPUSBAPI
http://www.hobbypic.com/index.php?option=com_content&task=view&id=24&Itemid=1&lang=en
Best regards
xane
« Reply #5 on: January 11, 2008, 05:48:52 05:48 »
Hi I am not quite looking to write a driver (in vb or ..) from scratch, rather I am looking for generic (USB-Serial kind of) code/driver in which i can change PID/VID to identify my own device then use simple data transfer like serial port.
setoy
« Reply #6 on: January 11, 2008, 12:56:14 12:56 »
It's different Smiley In this case I really  recommend you libusb. http://libusb.sourceforge.net/. It's simple, cross-platform and stable universal driver
shibuv
« Reply #7 on: January 14, 2008, 09:28:37 09:28 »
See this one
http://electronicfr.com/index.php/Microcontrollers-and-USB/Part-1-How-to-build-a-USB-device-with-a-PIC-18F4550-or-18F2550.html
fb2007
« Reply #8 on: January 15, 2008, 11:14:11 11:14 »
Hi, after some "tries and errors" i used the following components to have a working USB-communication between a PIC18F4550 and my PC:
- MikroC for the PIC
- HIDLIBRARY.DLL from Mike Obrian
- Visual Studio 2005
i had to fight a little bit with the documentation... but in the end the following code did the trick:
- Exchange data with my USB device:
Private Sub ReadInternalADC()
        Dim InputData As HIDLibrary.HidDeviceData
        Dim i As Integer
        Dim OutputText As String
        Dim uInput As Integer
        '--> Enumerate the devices with the Vendor Id
        '--> and Product Id of the DDS Stuff
        HidDeviceList = HIDLibrary.HidDevices.Enumerate(&H1235, &H1)
        If HidDeviceList.Length > 0 Then
            HidDevice = HidDeviceList(0)
            '--> Check if connected...
            HidDevice.OpenDevice()
            Dim OutData As Byte()
            ReDim OutData(HidDevice.Capabilities.OutputReportByteLength - 1)
            '--> Send a report to Device (8888888 is command to PIC to answer with data..)
            OutData(1) = Asc("8")
            OutData(2) = Asc("8")
            OutData(3) = Asc("8")
            OutData(4) = Asc("8")
            OutData(5) = Asc("8")
            OutData(6) = Asc("8")
            OutData(7) = Asc("8")
            OutData(Cool = Asc("8")
            HidDevice.Write(OutData)
            InputData = HidDevice.Read
            OutputText = ""
            For i = 1 To 5
                OutputText = OutputText + Chr(InputData.Data(i))
            Next
            uInput = Int((Val(OutputText) * 4.7 / 1.024) + 0.5)    ' convert Text answer (ADC) to Voltage
        End If
    End Sub
have fun!
iphone
-Given: 115
« Reply #9 on: January 16, 2008, 04:00:58 16:00 »
can you share the complete code (schematic, mikroC source, hex and VC code )?
Thks
kathir
« Reply #10 on: January 19, 2008, 01:02:06 01:02 »
Ihave developped with toools easyhid ,delphi
if u want mail me i will give all
mnasabir
-Given: 31
-Receive: 51
« Reply #11 on: January 19, 2008, 10:38:23 10:38 »
best source known to me , downloads master's conference 2007 CD from this site and read tutorial in it
iphone
-Given: 115
« Reply #12 on: January 21, 2008, 03:46:51 15:46 »
Yes, please share it over here, so anybody would be benefit !!! ... thanks for your kindness
my email ... [email protected].
Thanks mate.
incubus22
-Given: 23
« Reply #13 on: January 22, 2008, 04:49:55 04:49 »
Please also mail me your files. My email address: [email protected]
Thanks in advance!
BRANCA
-Given: 127
-Receive: 68
« Reply #14 on: January 24, 2008, 10:51:00 10:51 »
Please also mail me your files. My email address:[email protected]
Thanks in advance!
actionstk
« Reply #15 on: January 26, 2008, 12:31:17 12:31 »
Thanks in advance!
strolch
« Reply #16 on: February 08, 2008, 04:43:10 16:43 »
I could send you the Source code of the PDFSUSB.exe. It a good bootloader and aplication Software from Microchip.
It's written in C++ 6.0 from Borland!
Greetings
mabd
-Receive: 16
« Reply #17 on: February 15, 2008, 04:45:51 16:45 »
microchip forum the usb section contains a lot of usefull material
Posted on: February 15, 2008, 08:40:08 08:40 - Automerged
here is the link
http://forum.microchip.com/tt.aspx?forumid=102
xiaofan and DarioG are good contributors
ata_tr
-Given: 28
« Reply #18 on: February 20, 2008, 10:30:38 10:30 »
I tried so much, but I could not manage to get my 18F2550 work properly.  Undecided
setoy
« Reply #19 on: February 20, 2008, 03:42:12 15:42 »
... and what exactly tried??
