April 25, 2026, 05:46:39 05:46
Author Topic: Disassemble 8051  (Read 10090 times)
94491203
-Given: 8
-Receive: 21
« on: January 08, 2008, 03:34:18 15:34 »
who have the Disassemble 8051 software?
mayler
Roger that!
« Reply #1 on: January 08, 2008, 04:07:17 16:07 »
Try this...
http://www.programmersheaven.com/download/19841/download.aspx
Computer Engineer.
glenjoy
« Reply #2 on: January 18, 2008, 11:26:59 11:26 »
Search google for disassemblers.
yahoo
-Given: 56
-Receive: 114
« Reply #3 on: January 19, 2008, 01:29:24 01:29 »
IDA is a better choice. Learn one IDE and you have an interactive disassembler for so many micros.
http://rapidshare.com/files/55320315/IDA_Pro.rar
Password: www.riverdownloads.com
« Last Edit: January 19, 2008, 02:04:40 02:04 by yahoo » Logged
vsmGuy
-Given: 11
« Reply #4 on: January 26, 2008, 04:29:39 16:29 »
If you have the hexcode from the mcu, then you can use the excellent disasm to get the ASM back.
However, you need to annotate the ASM back into something useful.
This has to be done manually.
IDA will help you by making this process easier, but it's very expensive !
demorphica
« Reply #5 on: January 29, 2008, 07:07:43 07:07 »
check out IDAPro, you will need to set up the embedded target, and you will be able to use this to disassemble a variety of micros, not only 8051
pramodjaipur
-Given: 17
« Reply #6 on: March 06, 2008, 11:19:38 11:19 »
visit at www.8052.com and search disassembler
joaler
« Reply #7 on: March 07, 2008, 01:52:21 13:52 »
Dear friends
the dis assemblers are not so worth
they can be used to decode the hex to asm
but if the actual program was written on C, the disassembled code will be heavy and very difficult to understand.
and when there are more NOP instructions, the disassembler will show " truncated"
so after disassembling you must take care of it
jo
derwish
« Reply #8 on: March 19, 2008, 03:07:38 15:07 »
Try these ;
http://www.sixca.com/tool/download/data_syn51_dis.html
http://www.8052.com/users/disasm/
http://home.earthlink.net/~davesullins/software/dis51.html
dhana
« Reply #9 on: April 06, 2008, 01:58:26 01:58 »
This link
hhh4h
« Reply #10 on: April 20, 2008, 05:04:12 17:04 »
Disassemblers are useful on small code, written in asm.  Large projects using a higher level lang. are much tougher due to the branch prediction adn optimisation stuff that the compiler inserts
