April 29, 2026, 07:15:17 07:15
Author Topic: Home made PCB  (Read 7783 times)
Peter-e
« on: February 23, 2006, 02:34:19 02:34 »
Here are some simple instructions I have put together after reading many web pages on the subject. I hope it is of interest to some of you.
darkore
« Reply #1 on: February 23, 2006, 05:14:29 05:14 »
Interesting. What resolution can you achieve with this? Is it possible to do 0.5mm traces?
Peter-e
« Reply #2 on: February 23, 2006, 05:57:25 05:57 »
Yes .5mm is possible, I have used a hp printer which prints at 1200 dpi.
picstudent
« Reply #3 on: February 23, 2006, 07:28:06 19:28 »
or export your designs to acrobar with 4000Dpi resolutionss
... rego ... who are are you really ?
darkore
« Reply #4 on: February 24, 2006, 04:56:41 04:56 »
It's not about how you export the design, but rather what the printer outputs. It's the first time I find this method described with an inkjet printer, all the other instructions involved a laser printer. And this is a good thing, because I actually HAVE an injket printer Smiley
lillbear
-Given: 223
-Receive: 182
« Reply #5 on: April 05, 2006, 04:13:38 16:13 »
i have made 0.2mm traces Smiley
nice doc
avralam
-Given: 153
-Receive: 30
« Reply #6 on: April 07, 2006, 06:19:49 06:19 »
It is the best method for homemade projects. Results and handling will be better, than with poor blue  film from internet shop. Tested!
 Using this method many years. 1,4mm LQFP was minimal package for me . U can use any half mat paper, example thikcness sheets from Elfa catalogue or any magazine.
Peter-e
« Reply #7 on: April 27, 2006, 08:31:32 08:31 »
After posting the original message we started having problems using this method, we eventually found out our old iron wasn’t getting hot enough.
So as I had an old laser printer I decided to see if you can easily modify the fuser (this one has a quartz lamp inside a roller) to do the ironing part.
This test model is very basic, all I did was strip out as much as possible only leaving the fuser and enough electronics for the printer to maintain the correct temp.
I even have to crank the rollers by hand.
So when I have a bit of time I will put the stepper motor back in an build a little controller to step it very slowly.and to control the temp.
anandsnr
-Given: 15
« Reply #8 on: August 01, 2007, 01:57:02 13:57 »
Haiiiiiiiiiiiiiiiiiiiii,
where is the document
cyber_drifter
-Given: 167
-Receive: 32
« Reply #9 on: August 01, 2007, 05:55:37 17:55 »
I've never been any good at making pcb's. Any help on the subject would be wonderful.
samir
-Given: 27
-Receive: 21
« Reply #10 on: August 02, 2007, 07:19:27 07:19 »
Huh i can't see any instruction?HuhHuhHuhHuh??
puta
-Given: 380
-Receive: 29
« Reply #11 on: August 02, 2007, 11:40:05 11:40 »
Interesting..
-Given: 405
-Receive: 545
« Reply #12 on: August 02, 2007, 03:00:10 15:00 »
what would be interesting is to see the dam thing.do I have to rub my screen with lemon juice or something to make the invisible document appear Huh Huh Huh
smainj
-Given: 70
-Receive: 75
« Reply #13 on: August 03, 2007, 11:35:08 23:35 »
watch this :
http://www.youtube.com/watch?v=snileUK7PQg
http://www.youtube.com/watch?v=Vlui7s4lj7g
http://www.youtube.com/watch?v=8NhNsNw5BfU
http://www.youtube.com/watch?v=urv6jArKp6M
cyber_drifter
-Given: 167
-Receive: 32
« Reply #14 on: August 04, 2007, 12:18:33 00:18 »
Thanks Smainj for the links - I never thought of looking on You Tube. Looking at the video's I guess getting a Laser printer would be the ideal solution for making PCB's. I wonder if there are any budget models online that would do?
patoliyarj
-Given: 22
« Reply #15 on: August 14, 2007, 12:30:02 12:30 »
thanks for the videos..... Kiss
forter
-Given: 1217
-Receive: 28
« Reply #16 on: August 28, 2007, 11:07:58 11:07 »
I am using old photopape, printing on active side, after pressing hot iron, I am place a plate in warm water. 10 minutes and very good PCB is ready.
tanveerriaz
-Given: 55
-Receive: 613
« Reply #17 on: August 28, 2007, 03:14:42 15:14 »
http://www.riccibitti.com/pcb/pcb.htm
forter
-Given: 1217
-Receive: 28
« Reply #18 on: August 30, 2007, 02:41:42 14:41 »
Using old photopaper I ve made PCB for SMS contloller and very complicated PCB for logic analyzer (Elektor), but only single side.
All looks well, connection of component side , I have made with wires/
