April 29, 2026, 06:46:48 18:46
Author Topic: i2c  (Read 7375 times)
mrnitigon
i2c
« on: January 08, 2008, 05:05:16 05:05 »
can i use pic basic to program communication 2 pic
creatv
« Reply #1 on: January 08, 2008, 08:19:39 20:19 »
Yes, you can use picbasic proton for comunicate with 2 pic.
You can use the I2C bus or RS232 standard
mrnitigon
« Reply #2 on: January 09, 2008, 10:17:01 10:17 »
thank but i dont know how can i program slave address
Roshan
« Reply #3 on: January 09, 2008, 12:55:01 12:55 »
check sspadd,sspcon & sspstat register. Read carefully & you can use pic as slave devices.
Roshan
creatv
« Reply #4 on: January 09, 2008, 06:44:43 18:44 »
Hi, you can use this program for slave I2C
' PicBasic Plus I2C slave program - PIC16F877
        Device 16F877
        XTAL = 4
' Alias pins
      Symbol SCL = PORTC.3                  ' I2C clock input
      Symbol SDA = PORTC.4                  ' I2C data input
' Define used register flags
      Symbol SSPIF   PIR1.3             ' SSP (I2C) interrupt flag
      Symbol BF      SSPSTAT.0          ' SSP (I2C) Buffer Full
      Symbol R_W      SSPSTAT.2          ' SSP (I2C) Read/Write
      Symbol D_A      SSPSTAT.5          ' SSP (I2C) Data/Address
      Symbol CKP      SSPCON.4           ' SSP (I2C) SCK Release Control
      Symbol SSPEN   SSPCON.5           ' SSP (I2C) Enable
      Symbol SSPOV   SSPCON.6           ' SSP (I2C) Receive Overflow Indicator
      Symbol WCOL      SSPCON.7           ' SSP (I2C) Write Collision Detect
' Allocate RAM
      Dim datain  as     Byte              ' Data in
      Dim dataout as     Byte              ' Data out
        Goto main                       ' Jump over the subroutines
' I2C slave subroutine
i2cslave:
        SSPIF = 0                        ' Clear interrupt flag
        If R_W = 1 Then i2Crd            ' Read data from bus
        If BF = 0 Then Return              ' Nothing in buffer so exit
        If D_A = 1 Then i2cwr            ' Data for bus (not address)
        If SSPBUF != 2 Then Return           ' Clear the address from the buffer
        Return
' I2C write data to bus
i2cwr:   datain = SSPBUF                   ' Put data into datain
        Return
' I2C read data from bus
i2crd:  SSPBUF = datain                   ' Get data from datain
        CKP = 1                          ' Release SCL line
      Return
' Main program loop
Main:
' Initialise ports and directions
        ADCON1 = 7                       ' All PORTA, PORTE pins to digital
' Initialise I2C slave mode
        SSPADD = 2                       ' Make our address 2
        SSPCON2 = 0                      ' General call address disabled
        SSPCON = $36                     ' Set to I2C slave with 7-bit address
Again:  If SSPIF = 1 Then Gosub i2cslave   ' Check for I2C interrupt
' Clear any I2C collisions or errors
        SSPOV = 0
        WCOL = 0
        Goto Again                       ' Do it all forever
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #5 on: January 09, 2008, 11:33:08 23:33 »
Nice code CREATV
It works for me.
I interconnected two 16F877 PICS per SDA and SCL.
heres the testing Code.
' PicBasic Plus I2C Master program - PIC16F877
        Device 16F877
        XTAL = 4
' Alias pins
      Symbol SCL = PORTC.3                  ' I2C clock line
      Symbol SDA = PORTC.4                  ' I2C data line
' Allocate RAM
      Dim dataout As     Byte              ' Data out
' Main program loop
Main:
dataout = 0                      ' Will use this byte as signal
Again:
        Toggle PORTA.0                         ' Just to show PIC is Runing
        I2Cout  SDA,SCL,  2 , [ dataout ]      ' Send data
        DelayMS 10                             ' I always use this delay after I2Cwrite
        DelayMS 100                            ' Pause for watching response on second pic
        dataout = dataout + 1                  ' increment value of
        GoTo Again                       ' Do it all forever
On the Slave side i did a litlle variation , to see the data that was incoming ,...
        SerOut PORTC.6,84,[ "In: ",DEC4 datain,13]                ' added line
        Return
Simulate it in Proteus .
All Ok.
Greetings
mrnitigon
« Reply #6 on: January 10, 2008, 02:14:33 02:14 »
 Cheesy thank for all post it is best for me
