April 12, 2026, 03:07:52 03:07
Author Topic: CBL Web Application Builder V 8.02  (Read 6489 times)
o2
-Given: 41
-Receive: 405
« on: January 04, 2008, 06:34:11 06:34 »
With CBL Web Application Builder you can builds sophisticated, secure ASP/PHP Web Database Apps  without programming, but unlike many wizards, it does not sacrifice flexibility for advanced users/programmers.
CBL Web Application Builder has been setting  standards in automated Web Application creation  since 2002.  Without writing a single line of code, you can create a flexible application with full  sophisticated Search, Add, Edit and Delete  facilities in pure Microsoft Classic ASP or PHP  code - so you can also edit the code to add even more features.
It's perfect for creating administration areas,  prototyping and the foundation of larger Web  Applications.   Builds sophisticated, secure Classic ASP/PHP Web Database Apps without programming, but unlike  many wizards, it does not  sacrifice flexibility for advanced users/programmers....
With these applications you can  add/search/edit/delete data in your web database. Data Entry forms have full vallidation, prevent  alpha characters being entered in numeric fields, has a calendar for dates, and can lookup relational data in other tables.
The security wizard lets you decide which user(s) have access to which tables/fields. For example, you may wish to allow anonymous users to search  your product table, but you wouldn't want them to see the trade price, nor add/edit records.
Customers may need to be allowed to update their own record, but not that of other customers. All these scenarios can be handled effortlessly.
The search form allows multiple field searches,  with full support for Equals, Contains, Begins With and Between type searches. The paged data grid allows ordering by a particular field. Using APWAB, novice users can create  sophisticated web applications without any  programming, whilst programmers have complete  control over the templates and the finished code - it produces 100% pure ASP/PHP code - no server plugins are required. Using a companion product, it is possible to  build a PHP web application using your existing  Access database, that will run on a Linux/Unix server.
zam
« Reply #1 on: January 18, 2008, 05:59:36 17:59 »
thank you
walok
« Reply #2 on: June 12, 2009, 02:17:14 14:17 »
downloading...
