April 29, 2026, 08:19:20 08:19
Author Topic: Powersupply for Car  (Read 4422 times)
graywolf
-Receive: 19
« on: December 30, 2007, 08:08:59 20:08 »
I am trying to design a power supply to work in all cars voalteges from 12V to 24V and higher. There are many spikes and other singnals that need to be filtered out before suppling the microcontroller. I have used nomral 7805 regulatros but there is a energy problem if the voltage is to high and heats up. Does any one have a design for a good stable X voltage to 5 or 3.3 volts.
Thanks.
avralam
-Given: 153
-Receive: 30
« Reply #1 on: December 30, 2007, 08:59:05 20:59 »
 U need to make voltage down converter like good old LM2576. http://www.elecfree.com/electronic/3v-3a-regulator-switching-supply-with-lm2576/
leptro
-Given: 658
-Receive: 26
« Reply #2 on: January 01, 2008, 12:02:27 12:02 »
yes a step down coverter is the best solution. you also need a well design (coil and caps) filter before the lm2576 and perhaps a voltage limiting device such as a zener diode to avoid spike exceed the lm2576 maximum input voltgage rating.
surachai
« Reply #3 on: January 01, 2008, 07:13:48 19:13 »
The LM2575 supply current up to 1 A. and Lm2576 current up to 3A. See datasheet and application.
http://www.es.co.th/Schemetic/PDF/LM2575-NS.PDF
http://www.es.co.th/Schemetic/PDF/LM2576-NS.PDF
vayupak_01
« Reply #4 on: January 02, 2008, 06:13:02 18:13 »
Why you not change topology from linear to switching power supply, Sir Famous controller such as uc3842 can design easily or you can take controller another such ad NCP1200 Series from onsemiconductor
sir
Posted on: January 02, 2008, 07:08:19 19:08 - Automerged
Oh I remember that have the another controller which intregreted controller and powermosfets, Very simplex to design circuit.
The benefit is that have software for help to design, good work
See this w w w.powerint.c o m
Sir
Bubu62
-Given: 172
« Reply #5 on: January 02, 2008, 06:37:02 18:37 »
LT1070 input voltage 3-60V, Iout 5/10A
Korvo
« Reply #6 on: January 07, 2008, 10:29:10 22:29 »
I use LM350 for 3A. Works very well.  Wink
