April 29, 2026, 08:20:32 08:20
Author Topic: CYWM6935  (Read 5623 times)
kelvar
« on: December 30, 2007, 10:07:40 10:07 »
Anybody here managed to get the Cypress CYWM6935 working with any PIC mcu? It would be great if i can have some sample code to start off with.
samir
-Given: 27
-Receive: 21
« Reply #1 on: December 31, 2007, 04:09:43 04:09 »
this may be helpful
code on ATmega8
http://larsenglund.blogspot.com/2007/04/simple-avr-wireless-communication-using.html
MAXPAYNE
-Given: 517
-Receive: 376
It's a little funny......
« Reply #2 on: December 31, 2007, 06:56:46 06:56 »
Yes I am also desperately looking for CYWM6934 based project....
MAXPAYNE
-Given: 517
-Receive: 376
« Reply #3 on: January 01, 2008, 05:05:30 05:05 »
when u finish please post uor projects here....
Bepo
-Receive: 25
« Reply #4 on: January 04, 2008, 01:04:26 01:04 »
Here are some snippets:
#define SPI_WR    0x80
#define SPI_RD    0x00
#define SPI_INC   0x40
#define SPI_FRZ   0x00
// 0.65 is the implementation specific cal factor for DelayMicroSec();
#define SYNTH_SETTLE           200 * 0.65    // 200usec
#define PREAMBLE                32 * 0.65    // 32usec
#define RECEIVER_READY          35 * 0.65    // 35usec
#define CRYSTAL_STARTUP       2100 * 0.65    // 2100usec
#define RSSI_ADC_CONVERSION     50 * 0.65    // 50usec
#define tPD                     10 * 0.65    // 10usec
#define tPWR_RST              1300 * 0.65    // 1300usec
#define tPDN_X13              2000 * 0.65    // 2000usec
#define tSPI_RDY                 1 * 0.65    // 1usec
// RadioInit table
const BYTE code RadioInitTable[] =
   0x20, 0x45,    //REG_ANALOG_CTL
   0x20, 0x44,    //REG_ANALOG_CTL
   0x2E, 0x80,    //REG_PWR_CTL
   0x26, 0xC0,    //REG_VCO_CAL
   0x33, 0x41,    //REG_CLOCK_ENABLE
   0x32, 0x41,    //REG_CLOCK_MANUAL
   0x24, 0x40,    //REG_CRYSTAL_ADJ
   0x06, 0x0B,    //REG_SERDES_CTL
   0x10, 0xFF,    //REG_TX_VALID
   0x04, 0x06,    //REG_DATA_RATE - 64kbps, CODELEN=32, DATAMODE=DDR
   0x19, 0x03,    //REG_THRESHOLD_L - TH32=3
   0x1A, 0x1D,    //REG_THRESHOLD_H - TH32=3
   0x11, 0xDC,    //REG_PN_CODE, A overwrite default w/ PN Code Index 1 (64kbps table)
   0x12, 0xC0,    //REG_PN_CODE, A
   0x13, 0x6B,    //REG_PN_CODE, A
   0x14, 0xB8,    //REG_PN_CODE, A
   0x15, 0x2B,    //REG_PN_CODE, B
   0x16, 0x09,    //REG_PN_CODE, B
   0x17, 0xBB,    //REG_PN_CODE, B
   0x18, 0xB2,    //REG_PN_CODE, B
   0x23, 0x05,    //REG_PA - PA=5
   0x21, 0x02     //REG_CHANNEL = 2402MHz
// RadioPnCode table
const BYTE code RadioPnCodeTable[] =
   0x6A, 0xE7, 0x01, 0xEA, 0x03, 0xFD, 0x13, 0xD2, //PN Code 0
   0xDC, 0xC0, 0x6B, 0xB8, 0x2B, 0x09, 0xBB, 0xB2, //PN Code 1
   0xA3, 0x1E, 0xF2, 0xA4, 0x31, 0x32, 0x7A, 0xB3, //PN Code 2
   0x44, 0x83, 0x3B, 0xDD, 0x14, 0xCF, 0x8E, 0xC9, //PN Code 3
   0x35, 0x35, 0x4E, 0xC5, 0xF3, 0x52, 0x47, 0xB0, //PN Code 4
   0x7C, 0x23, 0x8A, 0xCE, 0x45, 0x5C, 0x54, 0xD7, //PN Code 5
   0x81, 0xAC, 0xFB, 0x83, 0x7A, 0x9A, 0x61, 0xAC, //PN Code 6
   0x3C, 0x12, 0x5F, 0x9C, 0x39, 0x98, 0xF6, 0x8A  //PN Code 7
BYTE radio_mid[] = {0,0,0,0};
// 16-bytes - data, data, data, data...
BYTE radio_txbuf[] = {0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07 /*,
                      0x08,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F */};
// 48-bytes - data, valid, rssi, data, valid, rssi...
BYTE radio_rxbuf[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
                      0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
BYTE radio_rssi = 0;
BYTE radio_status[] = {0,0,0,0,0,0};
   // 0 - REG_TX_INT_STAT
   // 1 - SPARE
   // 2 - REG_RX_INT_STAT
   // 3 - REG_RX_DATA_A
   // 4 - REG_RX_VALID_A
   // 5 - REG_RSSI
// prototypes for radio snippets
void DelayMicroSec(WORD microsec);
void RadioReset(void);
void RadioInit(void);
void RadioSetPnCode(BYTE index);
void RadioGetMid(void);
BYTE RadioTransmit(BYTE len, BYTE *txbuf);
BYTE RadioReceive(BYTE *rxbuf);
void RadioSleep(void);
void RadioWake(void);
BYTE RadioGetRssi(void);
   WORD i;
   for(i=0;i<microsec;i++) {
      // toggle SCK (w/o asserting nSS) to measure DelayMicroSec() w/scope
      SCK_HI;
      SCK_LO;
   nRST_LO; nPD_LO;  nSS_HI;  SCK_LO;
   DelayMicroSec(tPWR_RST);                  //1300usec min.
   nPD_HI;
   DelayMicroSec(tPDN_X13);                  //2000usec typ.
   nRST_HI;
   DelayMicroSec(tSPI_RDY);                  //1usec min.
   nPD_HI;                                   // not connected to LP
   DelayMicroSec(CRYSTAL_STARTUP);           // ~Xmsec for crystal start to stable - idle
   BYTE i;
   for(i=0;i<sizeof(RadioInitTable);i+=2) {
      SpiWrite(RadioInitTable[i],RadioInitTable[i+1]);
   SpiFileWrite((SPI_INC | 0x11), 8, (&RadioPnCodeTable[0] + (8*index))); //REG_PN_CODE
   SpiWrite((SPI_FRZ | 0x20), 0x64);                  //REG_ANALOG_CTL - enable reads from MID
   SpiFileRead((SPI_INC | 0x3C), 4, &radio_mid[0]);   //REG_MID        - loaded into radio_mid[]
   SpiWrite((SPI_FRZ | 0x20), 0x44);                  //REG_ANALOG_CTL - disable reads from MID
   BYTE i;
   radio_status[0] = SpiRead((SPI_FRZ | 0x0E));       //REG_TX_INT_STAT - clear transmit status
   SpiWrite((SPI_FRZ | 0x0D), 0x01);                  //REG_TX_INT_EN - enable empty flag on IRQ pin
   SpiWrite((SPI_FRZ | 0x03), 0x50);                  //REG_CONTROL - enable tx
   DelayMicroSec(SYNTH_SETTLE);                       // wait for synth to settle
   DelayMicroSec(PREAMBLE);                           // delay in loading txbuf to send extra preamble symbol
   for(i=0;i<len;i++) {
      SpiWrite((SPI_FRZ | 0x0F), txbuf[i]);           //REG_TX_DATA - send data
      while(!IRQ);                                    // wait 'til REG_TX_DATA empty
   SpiWrite((SPI_FRZ | 0x0D), 0x02);                  //REG_TX_INT_EN - enable done flag on IRQ pin
   while(!IRQ);                                       // wait 'til REG_TX_DATA done
   SpiWrite((SPI_FRZ | 0x03), 0x00);                  //REG_CONTROL - return to idle
   return(radio_status[0]);
   BYTE len;
   BYTE i;
   radio_status[2] = SpiRead((SPI_FRZ | 0x08));       //REG_RX_INT_STAT - clear receive status
   SpiWrite((SPI_FRZ | 0x07), 0x03);                  //REG_RX_INT_EN - enable EOFA and FULLA flags on IRQ pin
   SpiWrite((SPI_FRZ | 0x03), 0x90);                  //REG_CONTROL - enable rx
   DelayMicroSec(RECEIVER_READY);                     // wait for receiver afe ready
   i = 0;
   while(1)
      while(!IRQ);                                    // wait 'til either EOFA or FULLA receive flag fires
      radio_status[2] = SpiRead((SPI_FRZ | 0x08));    //REG_RX_INT_STAT - check receive status
      if(radio_status[2]&0x01)
      {                                               //store REG_RX_DATA_A and REG_RX_VALID_A in user's rxbuf
         SpiFileRead((SPI_INC | 0x09), 2, &rxbuf[i]);
         if(rxbuf[i+1] > 3)
            i += 2;
            rxbuf[i] = SpiRead((SPI_FRZ | 0x22));     // store REG_RSSI in user's rxbuf
            i++;                                      // ~75usec of "idle" time between bytes when using 64kbps
      if(radio_status[2]&0x02 && i) break;
   len = i;
   return(len);
   SpiWrite((SPI_FRZ | 0x03), 0x00);         //REG_CONTROL - force idle
   nPD_LO;                                   // force sleep
   DelayMicroSec(tPD);                       //10usec
   // typically takes ~50usec from the time nPD is asserted to low power mode
   nPD_HI;                                   // force idle
   SpiWrite((SPI_FRZ | 0x2F), 0x80);            //REG_CARRIER_DETECT - force radio to manually acquire rssi reading
   SpiWrite((SPI_FRZ | 0x03), 0x90);            //REG_CONTROL - put radio in receive mode - triggers rssi adc
   DelayMicroSec(RECEIVER_READY);               // wait for receiver ready
   DelayMicroSec(RSSI_ADC_CONVERSION);          // wait for 5-bit rssi adc to complete
   radio_status[5] = SpiRead((SPI_FRZ | 0x22)); //REG_RSSI - flush stale rssi reading
   radio_status[5] = SpiRead((SPI_FRZ | 0x22)); //REG_RSSI - get rssi reading
   SpiWrite((SPI_FRZ | 0x2F), 0x00);            //REG_CARRIER_DETECT - manually clear CDET
   SpiWrite((SPI_FRZ | 0x03), 0x90);            //REG_CONTROL - put radio in idle mode
   return(radio_status[5]);
Hope it helps
Bye
Bepo
Posted on: January 02, 2008, 08:55:23 20:55 - Automerged
An italian company, AUREL, has a module which is 100% compatible with the Cypress.
It uses the same ic.
You can find some application notes here:
http://www.aurelwireless.com/rf-wireless-modules/product-info.asp?id=183
Bye
Bepo
