thetrueman
-Given: 24
« on: December 19, 2007, 11:16:42 11:16 » |
Hi All,
I need a constant current source which can be operatable as low as 3.5V. I used 2 transistors current source which works fine but not below 4.5V.
Actually I want to drive a white LED with small 6V battey and want it to glow uniformly from 3.5V to 6.5V. Is there any solution? Please Help!
Shahzad
8K51
-Given: 86
-Receive: 40
« Reply #1 on: December 19, 2007, 11:38:49 11:38 » |
Hi please could you be more precise to allow better answers ? what's your Led voltage and current requirements ? do you need good efficiency ? regards
thetrueman
-Given: 24
« Reply #2 on: December 19, 2007, 11:52:20 11:52 » |
LED voltage are 3.5V and current is 20mA.
Shahzad
8K51
-Given: 86
-Receive: 40
« Reply #3 on: December 19, 2007, 12:04:23 12:04 » |
If you want to drive a 3.5V LED from a 'small battery' even when battery delivers 3.5V there is a solution with a small ready made buck-boost regulator with serial mounting white led with inductor. (constant current) I have no precise chip reference but Maxim, Linear, NS... and maybe Microchip have such buck-boost switching regulators. http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2590¶m=en528261Your current need is low so another solution could be 'charge pump constant current' Regards
« Last Edit: December 19, 2007, 12:14:16 12:14 by 8K51 »
bogdantk
-Given: 40
« Reply #4 on: December 19, 2007, 12:07:37 12:07 » |
-Given: 499
« Reply #5 on: December 19, 2007, 10:31:47 22:31 » |
Look at LM78XX series datasheet there will be a simple constant current circuit that use one capacitor, one LM78XX and one resistor.
pama
-Receive: 28
« Reply #6 on: December 20, 2007, 12:53:08 12:53 » |
hi,
i used webench for special led applications selections, it's good tool for national semi. parts, and you can get easily samples:
hxxp://www.national.com/appinfo/webench/led/pled.html;
but for low powered applications i tried some parts from prema:
hxxp://www.prema.com/Application/whiteleddriver.html;
but it's depend on your requirements, it can be solved also with discret components.
best wish pama
belinao
-Receive: 12
« Reply #7 on: December 20, 2007, 11:42:26 23:42 » |
if dimensions are not your problem you can use an op amp. i can send you the circuit if you want
thetrueman
-Given: 24
« Reply #8 on: December 21, 2007, 04:20:02 04:20 » |
Yes please. I'll be thankful.
Once again I want to clear my requirement that when the battery is charged fully the LED should be glow at 20mA and when the battery discharges gradually till 3.5V (because the LED voltage is 3.5V) it should provide constantly 20mA to LED throughout.
In this way I want to get most from small battery for long time at same brightness of LED. Thank you.
Shahzad
pama
-Receive: 28
« Reply #9 on: December 21, 2007, 06:30:20 06:30 » |
hi,
also something interesting, but this is for a 1,5 V. It's again a working circut, tested by me.
hxxp://www.emanator.demon.co.uk/bigclive/joule.htm
good luck
8K51
-Given: 86
-Receive: 40
« Reply #10 on: December 21, 2007, 10:29:16 10:29 » |
Hi You want to get 'the most' from a small battery, it's an interesting challenge !! I googled with ' low drop white led constant current'. Among many good answers I choose this one : http://radiolocation.tripod.com/LEDdimmer/LEDlampDimmer.html- only 0.2V lost (voltage drop) vs 0.6V with 2 transistor solution, - well explain so you can adapt it to your exact requirements, (single led, 20mA) -easy removable dimmer components, -no special, hard to find, components ..... no inductor, -does some temperature compensation usefull for white led safe use, -article links towards others solution like that ones : http://electronicdesign.com/Articles/Index.cfm?ArticleID=4703Regards
« Last Edit: December 21, 2007, 11:35:15 11:35 by 8K51 »
igq
« Reply #11 on: December 22, 2007, 10:32:58 22:32 » |
How many LED you want to drive?
twonuts
-Given: 55
-Receive: 42
« Reply #12 on: December 22, 2007, 11:39:26 23:39 » |
I'd go with this solution. Almost any fixed voltage 3 leg regulator can be used this way, I use this method very often.
piclover
-Given: 27
-Receive: 98
« Reply #13 on: December 23, 2007, 01:29:02 13:29 » |
Look for LM317, You need only 1.25 volts voltage difference input-output. For low current u can use LM317L (TO92 package).
thetrueman
-Given: 24
« Reply #14 on: December 24, 2007, 03:05:24 15:05 » |
8K51 showed enhanced example of simple two transistor with one resistor circuit version. I'll give it a try.
78xx and LM317 are good but voltage drop between input output is minimum 1.25V and when we add 3.5V of LED voltage drop then voltage drop becomes 4.75 volts which is not acceptable at low voltage.
Any body have any idea with PWM. I tried 555 with some success but output is something non-linear. I directly drived LED through a transistor without any current limit resistor. But yet feedback is not controlled to Pin 5 of 555 control voltage. Can anybody have any idea such above circuit i.e. with op-amps etc. like SMPS...
« Last Edit: December 26, 2007, 05:05:46 05:05 by thetrueman »
twonuts
-Given: 55
-Receive: 42
« Reply #15 on: December 24, 2007, 04:17:49 16:17 » |
There should always be the same volts drop across the diode, ~3.5V depending on type, no matter what system you use, assuming you are driving the LED at its normal current rating.. This means there will always be ~2.5 volt drop across your regulator, when supplied from a 6V battery.
Multiply that by the current required to drive the LED, ~25mA, and you should get the same power loss no matter what constant current system you use.
vayupak_01
« Reply #16 on: January 02, 2008, 06:27:13 18:27 » |
For low voltage try to you this (Linear topology)
LDO = Low voltage drop out
many company that have this product
I think LDO is very simple to design because that design same another linear power supply ummmm
surachai
« Reply #17 on: January 03, 2008, 06:04:16 06:04 » |
This is simple circuit constant current source for led.
anemon06
-Given: 32
-Receive: 34
« Reply #18 on: January 06, 2008, 07:17:48 07:17 » |
