April 08, 2026, 06:45:41 06:45
Author Topic: LCD error on portd  (Read 16729 times)
8051
-Receive: 14
« on: January 29, 2006, 04:43:36 16:43 »
Hi , Im new and trying to working on picbasic pro
i using pic16F877A
This is my running led code.
led is running.
but lcd not working
please help where i wrong.
lcd connection is
RS BIT  -- PORTD.0 (PIN 19)
R/W BIT -- PORTD.1 (PIN 20)
E BIT   -- PORTD.2 (PIN 21)
D4  ---  PORTD.3  (PIN 22)
D5  ---  PORTD.4  (PIN 27)
D6  ---  PORTD.5  (PIN 28)
D7  ---  PORTD.6  (PIN 29)
DEFINE LCD_DREG PORTD
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTD
DEFINE LCD_RSBIT 0
DEFINE LCD_EREG PORTD
DEFINE LCD_EBIT 2
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
CMCON = 7
ADCON1 = 7
OUTPUT PORTD
OUTPUT PORTB
LOW PORTD.1
PAUSE 500
LOW PORTD.1
LCDOUT $FE,1
LCDOUT "RUNNING LED"
LOOP:
        HIGH PORTB.0
        PAUSE 50
        LOW PORTB.0
        PAUSE 50
        HIGH PORTB.1
        PAUSE 50
        LOW PORTB.1
        PAUSE 50
        HIGH PORTB.2
        PAUSE 50
        LOW PORTB.2
        PAUSE 50
        HIGH PORTB.3
        PAUSE 50
        LOW PORTB.3
        PAUSE 50
        HIGH PORTB.4
        PAUSE 50
        LOW PORTB.4
        PAUSE 50
        HIGH PORTB.5
        PAUSE 50
        LOW PORTB.5
        PAUSE 50
        HIGH PORTB.6
        PAUSE 50
        LOW PORTB.6
        PAUSE 50
        HIGH PORTB.7
        PAUSE 50
        LOW PORTB.7
        PAUSE 50
        GOTO LOOP
        END
tasosstr
-Given: 96
-Receive: 14
« Reply #1 on: January 29, 2006, 05:44:37 17:44 »
Try  R/W BIT to put direct to ground.
Best Regards,
Tasosstr
« Reply #2 on: January 29, 2006, 06:08:57 18:08 »
The coorect way is to connect this way
'D4 --- PORTD.4
'D5 --- PORTD.5
'D6 --- PORTD.6
'D7 --- PORTD.7
'Not
'D4 --- PORTD.3
'D5 --- PORTD.4
'D6 --- PORTD.5
'D7 --- PORTD.6
No need to use Output PortD/PortB, use this instead:
TRISB = [COLOR=Red]0[/COLOR]
TRISD = [COLOR=Red]0[/COLOR]
Also LCDOUT takes care of TRISD any way, and make the used Port bits as outputs already.
Don't forget to define the crystal speed:
[B]Define[/B] Osc [COLOR=Red]4[/COLOR]
I don't know why you are using so many Pause statemnets as long as they have the same delay, use this way in order to make it easier for you to examine your firmware:
Delay:
[B]Pause[/B] [COLOR=Red]50[/COLOR]
[B]Return[/B]
You can use this as follows:
[B]GoSub[/B] Delay
I also see that you use High Port.Bit, this is not nes\cessary, provided you have cleared TRISB:
[COLOR=Navy]' Now use this:[/COLOR]
PortB.[COLOR=Red]0[/COLOR] = [COLOR=Red]0[/COLOR]
[B]GoSub[/B] Delay
PortB.[COLOR=Red]0[/COLOR] = [COLOR=Red]1[/COLOR]
[B]GoSub[/B] Delay
Another way that makes your code much smaller:
i [B]Var[/B] [B]Byte[/B]
[B]For[/B] i = [COLOR=Red]0[/COLOR] [B]To[/B] [COLOR=Red]7[/COLOR]
PortB.[COLOR=Red]0[/COLOR][i] = [COLOR=Red]0[/COLOR]
[B]GoSub[/B] Delay
PortB.[COLOR=Red]0[/COLOR][i] = [COLOR=Red]1[/COLOR]
[B]GoSub[/B] Delay
[B]Next[/B] i
This will go through all PortB pins and make what you are doing.
Ph1l
« Reply #3 on: January 29, 2006, 06:09:00 18:09 »
Your LCD should be connected to PortD.4 to PortD.7 (not PortD.3 to PortD.6)
(The upper 4 bits)
-Receive: 14
« Reply #4 on: January 30, 2006, 12:11:02 12:11 »
Thanks tasosstr , metal & PH1 for HELP,
Now it is working.
and special thanks to GREAT metal for Deeply explain code.
I also see that  code size also redused to use "TRIS"  and  "for/next"  command.
dideco
« Reply #5 on: February 01, 2006, 09:06:54 09:06 »
Also, don't forget to diasable bidirectional parallel slave register for port D. Otherwise a simple parasitic osscillation may interrupt your LCD display.
-Receive: 14
« Reply #6 on: February 02, 2006, 02:54:50 02:54 »
Thanks dideco but what is the command line to disable ?
