April 29, 2026, 07:13:24 07:13
Author Topic: Circuit Simulator Applet  (Read 4840 times)
gainsbarre
« on: December 10, 2007, 03:37:41 03:37 »
I would like to share this link to the Paul Falstad's "Circuit Simulator Applet".
http://www.falstad.com/circuit/.
This java applet is an electronic circuit simulator.  When the applet starts up you will see a simple LRC circuit.  The green color indicates positive voltage.  The gray color indicates ground.  A red color indicates negative voltage.  The moving yellow dots indicate current.
To turn a switch on or off, just click on it.  If you move the mouse over any component of the circuit, you will see a short description of that component and its current state in the lower right corner of the window.  To modify a component, move the mouse over it, click the right mouse button (or control-click if you have a Mac) and select “Edit”.
The "Circuits" menu contains a lot of sample circuits for you to try, including filters, oscillators, amplifiers, logic gates and circuits, phase-locked loops, etc.
If the applet stops responding, try resizing the window. This can happen with Microsoft java; the applet works best with the Java plugin.
You can also check this one  http://www.falstad.com/fourier/. (Fourier Series, i love this one)
Well, i hope this applets are as useful to you as they have been to me.
