April 29, 2026, 10:30:49 10:30
Author Topic: square wave rectifier  (Read 7735 times)
free
-Given: 71
« on: December 04, 2007, 01:40:21 01:40 »
I want to convert variable AC square wave voltage to DC.
The max square wave voltage is 24Vpp.
Can you give me some advices, the link, the good way to convert it?
« Last Edit: December 04, 2007, 01:44:00 01:44 by free » Logged
- Soichiro Honda -
user112
-Receive: 139
Salut tuturor(hello to all)
« Reply #1 on: December 04, 2007, 05:21:33 05:21 »
what is the frequency? if is under 100-200Hz you can use normal rectifier bridge if is bigger you must use switching diode like those from switching power supply
free
-Given: 71
« Reply #2 on: December 04, 2007, 09:10:14 21:10 »
The frequency is 75Hz.
If I use normal rectifier bridge, what about with breakdown voltage of diode.
The square wave sometime produces 1 volt or less.
Does the AC to DC converter with opamp work fine for square wave input?
« Last Edit: December 04, 2007, 09:28:37 21:28 by free » Logged
- Soichiro Honda -
aniltandon007
« Reply #3 on: December 05, 2007, 06:46:18 06:46 »
how to use smps ic tl494 to generate pwm for motor driver
user112
-Receive: 139
« Reply #4 on: December 05, 2007, 06:37:27 18:37 »
if you have need of accuracy you must use precision rectifier circuits made with operational amplifiers this d'ont have breakdown voltage
see this link http://sound.westhost.com/appnotes/an001.htm
Kabron
-Given: 71
-Receive: 145
« Reply #5 on: December 06, 2007, 08:13:04 08:13 »
Analog Devices AD736 Low Cost, Low Power,
True RMS-to-DC Converter free samples.
belinao
-Receive: 12
« Reply #6 on: December 09, 2007, 07:19:42 07:19 »
precision rectifiers with op amps might be the answer... what is the output current that u need?
neelandan
« Reply #7 on: December 10, 2007, 11:14:11 11:14 »
Depends ...
If you need to transfer power, you need diode bridge
If you need to measure the amplitude, you need precision rectifier circuits with opamps.
Deep inside the carcass of a dead (short) circuit.
free
-Given: 71
« Reply #8 on: December 10, 2007, 02:06:21 14:06 »
Thanks for your suggestions.
I will build rectifier with single supply opamps.
what type of opamp is ideal for it (precision) ?
- Soichiro Honda -
