April 29, 2026, 07:13:09 07:13
Author Topic: Reading fan speed with 16F877A  (Read 3965 times)
Van.Helsing
« on: December 01, 2007, 11:41:07 11:41 »
Hi!
  Anyone know how can read the pulses of a three pin fan using the 16F877A ?
  I know how to calculate and find something in ASM, but i need in C.
  []'s
  Ismael
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #1 on: December 01, 2007, 12:01:56 12:01 »
Ismael , I have succesfully done it using an Infrared - Reflective Sensor .
Only need an distinctive ( white over black ... ) line once on the rotating part. Maths are simple.
Sensor must get close to moving part ( about 2 mm )
I have used Protons Pulsein command but that you can do in ASM also.
Good results , I used in a Glow Engine speed control for an R/c Helicopter. ( Governor )
Tell me if this direction is usefull for you
greetings
hemlig
Translator
-Receive: 50
« Reply #2 on: December 01, 2007, 12:32:13 12:32 »
You might get some ideas on how to read the pwm from various types of fans
and then adapt it to a PIC by reading this appnote at this website:
http://www.maxim-ic.com/appnotes.cfm/appnote_number/1784/
If it work don't fix it!
