April 20, 2026, 08:46:52 20:46
Author Topic: SmartDraw All Versions  (Read 13588 times)
cad24
« on: November 27, 2007, 09:05:19 21:05 »
SmartDraw Suite Edition 2007 v8.16
http://rapidshare.com/files/24514676/SmartDraw.Suite.Edition.2007.v8.16.zip
EDIT: Dead Links
« Last Edit: January 21, 2009, 12:03:58 00:03 by pickit2 » Logged
micropar
-Given: 44
« Reply #1 on: May 14, 2008, 02:46:17 02:46 »
Hi Zokij or any User,
Does SmartDraw 2008 support ActiveX programming or VBA programming? I mean to say Can I use it from VB or Delphi to create my Drawing Program?
I am looking for ActiveX or VCL components which I can use to create my own Drawing programs at minimum of programming without starting from scratch or using boring, complicated windows GDI.
Thanks in advance with regards,
--micropar--
zokij
-Given: 272
-Receive: 700
Nice time :)
« Reply #2 on: May 14, 2008, 05:50:59 05:50 »
As I know Smart Draw is like diagram flow charting program, that mean you have library with symbols which you can use to make flow diagram - you can export your drawing to office but cant use like ocx ...
I will try to found some ocx for you... but that will not be easy ...
zokij
-Given: 272
-Receive: 700
Nice time :)
« Reply #3 on: May 15, 2008, 05:35:09 05:35 »
Huh Sorry  Undecided
 Embarrassed I don't use this program that mean I don't download them ...
 Roll Eyes I found resource on net and forward for you...
probably on in archive somewhere you must have some key gen...
 Shocked I found this comment for this archive... Shocked
CLEAR install and register Information
-before installing - do explore of CD and copy CORE folder to Desktop - run Key-Gen
-disconnect from internet or use a firewall BEFORE launching the install
- enter your users name into KeyGen
-use first serial to install the software
-after installation completes,
-enter your system id in the ID field (on the SmartDraw registration box)
from the keygen System ID line (line #2)
- then copy the code on line #4 of Key-Gen to the Activation Box of SmartDraw
-Activate the software
Roll Eyes
if you still have problem there are
in http://rapidshare.com/files/114997102/LekzaSDraw.rar 23KB
some cure which I found on net for you   Grin
pass:www.sonsivri.com   Wink
incubus22
-Given: 23
« Reply #4 on: May 16, 2008, 03:00:20 03:00 »
Huh Sorry  Undecided
 Roll Eyes
Thank you! I will try your solution and give comments later.
zokij
-Given: 272
-Receive: 700
Nice time :)
« Reply #5 on: May 16, 2008, 05:48:17 17:48 »
This is CD image file.
When you burn a CD, you will see a keygen into directory.
well as I say
That mean have nice time Smiley
50caliber
-Given: 174
-Receive: 863
« Reply #6 on: May 17, 2008, 03:38:49 03:38 »
It's a very nice application.  However - Do not install any updates to it.
LazBoy
-Given: 79
-Receive: 25
« Reply #7 on: May 18, 2008, 01:09:34 13:09 »
And disable internet access before installation!
PICOL
« Reply #8 on: January 18, 2009, 12:16:31 00:16 »
*SmartDraw 2008:
http://rapidshare.com/files/71159180/SmartDraw.2008.ISO-CORE.part4.rar
http://rapidshare.com/files/71159027/SmartDraw.2008.ISO-CORE.part1.rar
http://rapidshare.com/files/71159018/SmartDraw.2008.ISO-CORE.part2.rar
http://rapidshare.com/files/71159016/SmartDraw.2008.ISO-CORE.part3.rar
http://rapidshare.com/files/71159001/SmartDraw.2008.ISO-CORE.part5.rar
http://rapidshare.com/files/71158983/SmartDraw.2008.ISO-CORE.part6.rar
http://rapidshare.com/files/71158768/SmartDraw.2008.ISO-CORE.part7.rar
*Keygen
http://www.mediafire.com/?3mjimxykgyd
*Upgrade to SmartDraw 2009.
http://rs151.rapidshare.com/files/175404504/sd09.rar
EDIT: Do Not CUT&PASTE other users posts. even if it's a cut&paste to begin with.
« Last Edit: January 19, 2009, 07:22:08 19:22 by pickit2 » Logged
-Receive: 4460
« Reply #9 on: January 21, 2009, 02:56:09 14:56 »
This is SmartDraw 2008 with up date to 2009
posted due to cut&paste not being Supported.
Links to download
 SD2008.part1.rar
http://rapidshare.com/files/188213053/SD2008.part1.rar
 SD2008.part2.rar
http://rapidshare.com/files/188250218/SD2008.part2.rar
SD2008.part3.rar
http://rapidshare.com/files/188250220/SD2008.part3.rar
 SD2008.part4.rar
http://rapidshare.com/files/188237460/SD2008.part4.rar
 SD2008.part5.rar
http://rapidshare.com/files/188237466/SD2008.part5.rar
 SD2008.part6.rar
http://rapidshare.com/files/188253511/SD2008.part6.rar
 SD2008.part7.rar
http://rapidshare.com/files/188238955/SD2008.part7.rar
for professional - quality results every time.
EDIT: new links
« Last Edit: January 23, 2009, 04:34:45 16:34 by pickit2 » Logged
gamegurus
-Receive: 64
Oh what a wonderful morning!!!
« Reply #10 on: January 23, 2009, 04:40:48 04:40 »
Instead of burning ISO to CD, option is to load the ISO as a CD DRIVE using virtual drive tool called Daemon Tools
http://forum.daemon-tools.cc/download.php
Indian Gaming Guru
