April 28, 2026, 06:02:31 18:02
Author Topic: Atmel studio 4 new parts addition  (Read 172 times)
max
-Given: 1817
-Receive: 52
« on: April 26, 2026, 07:30:48 07:30 »
How to add new parts to atmel studio 4 ?
avrlover
-Given: 59
-Receive: 244
« Reply #1 on: April 26, 2026, 06:47:59 18:47 »
Adding new parts to Atmel Studio 4 (AS4) is often required when using newer AVR microcontrollers that were released after the final version of AS4. Because AS4 is an outdated, legacy IDE, it does not support modern device pack updates.
Here are the primary methods to add support for a new part:
Method 1: Update the AVR Toolchain (For Compiler Support)
To make the compiler recognize a new chip, update the AVR-GCC Toolchain.
Download a newer version of the AVR Toolchain (e.g., 4.9.2 or later) from the Microchip website. When setting up a project, you will use the new -mmcu= option for the new part.
AVR Freaks link Method 2: Manually Edit/Create Part Support
If the part is very similar to an existing one (e.g., trying to use an ATmega328PB on a project set up for an ATmega328P), you may be able to force it to work.
Locate include files: New assembler include files can be found and sometimes placed into the \Atmel\AVR Tools\AvrAssembler\Appnotes directory. From Google AI you can use also codevisition avr
External Makefile: Create a project for a similar, older AVR, tick the "use external Makefile" option, and manually edit the Makefile to reflect the new part number for the -mmcu switch.
Note on Limitations: While this allows compilation, the simulator and debugger in AS4 will not recognize the new part. Alternatively, use a command-line tool like avrdude to flash the hex file generated by the newer toolchain, bypassing the need to have the device listed in
AVR Freaks
AVR Freaks
 +1
