April 22, 2026, 09:09:06 21:09
Author Topic: Looking for firmware for u-blox TIM-4H (ANTARIS Firmware V5.00)  (Read 5489 times)
knave
-Given: 30
-Receive: 102
« on: July 26, 2025, 02:19:18 14:19 »
Hi everyone,
I'm trying to locate the firmware for a ~20-year-old u-blox TIM-4H-0-000 GPS module that is built into an older instrument I'm working with. Unfortunately, the original firmware seems to have vanished from the internet.
I'm specifically looking for:
    ANTARIS Firmware V5.00 for LEA-4H / TIM-4H / AEK-4H Evaluation Kit
    Filename: ANTARIS_Fw_5.00_MOD-4H-Setup_963.exe
    Date: ~2006-01-18
If anyone still has an old LEA-4H, TIM-4H, or AEK-4H Evaluation Kit, there's a chance the firmware installer might be sitting in your archive or CD-ROM.
Would greatly appreciate if someone could share the file or point me to a source.
Thanks in advance!
-Given: 239
-Receive: 1057
« Reply #1 on: July 27, 2025, 10:34:45 10:34 »
Hi everyone,
    Date: ~2006-01-18
Thanks in advance!
Have you heard about wayback machine, It can be helpful in cases like this
https://web.archive.org/web/20090203090557/http://u-blox.com/customersupport/antaris4_fw.html
I found your file in the 2009 version of the site. Before that the firmware was hidden behind registration. So a few cut and try may be needed
knave
-Given: 30
-Receive: 102
« Reply #2 on: July 27, 2025, 04:31:05 16:31 »
Thanks, I had already tried that. I was able to find the file name there, but unfortunately, it's not available anywhere.
https://web.archive.org/web/20090403204306/http://www.u-blox.com/customersupport/antaris4_fw.html
-Given: 239
-Receive: 1057
« Reply #3 on: July 28, 2025, 06:01:03 06:01 »
It worked for me. And I managed to download the file without no problem from your link and the link I provided.
knave
-Given: 30
-Receive: 102
« Reply #4 on: July 28, 2025, 01:09:12 13:09 »
Yes, the 4P can be downloaded, but the one I'm looking for, the 4H, unfortunately cannot.
    Date: ~2006-01-18
-Given: 239
-Receive: 1057
« Reply #5 on: July 28, 2025, 02:40:42 14:40 »
can you combine these two links and get something working?
https://web.archive.org/web/20140714153555/https://www2.u-blox.com/ko/gps-modules/pvt-modules/previous-generations/antaris-4.html
https://web.archive.org/web/20051015000000*/http://www.u-blox.com/products/u_center.html
Edit sorry you need a small exe file for that in addition
« Last Edit: July 28, 2025, 02:51:40 14:51 by Sideshow Bob » Logged
yahoo
-Given: 56
-Receive: 114
« Reply #6 on: July 28, 2025, 03:51:55 15:51 »
I was able to download 4H from the above links. In case you cannot, I can set another way to download this fw: ANTARIS_Fw_5.00_MOD-4H.zip
But there is no exe file in the archive, just one binary: ANTARIS_Fw_5.00_MOD-4H.bin
-Given: 239
-Receive: 1057
« Reply #7 on: July 28, 2025, 04:19:04 16:19 »
I think I have the last file needed
Go here www.famosastudio.com/download/democode/SF_u-center_5.07_Installer.zip But the whole thing was kind of on the dodgy side. As the archive was packed and repacked many times. I did upload the u-center_5.07_Installer.exe file here https://virusscan.jotti.org/ came back negative. But to be on the safe side use 7zip to extract this file. The content can be run from any folder by the look of it.
knave
-Given: 30
-Receive: 102
« Reply #8 on: July 28, 2025, 04:37:28 16:37 »
I think it'll be fine. Thanks for your help  Smiley
