March 03, 2026, 05:21:21 05:21
Author Topic: CNC PCB Machine  (Read 9992 times)
dayar
« on: November 26, 2007, 08:18:16 08:18 »
Hello, anyone knows an economic CNC PCB machine for routing a PCB. I find the colimbus and LPKF machines but it's too expensive.
fmssp
-Given: 42
-Receive: 109
« Reply #1 on: November 26, 2007, 09:17:43 09:17 »
1. http://www.elektor.com/extra/profiler-milling-machine-from-a-kit.91274.lynkx
2. http://www.tebi.nl/highz_s400_nl.html
« Last Edit: November 26, 2007, 02:12:04 14:12 by fmssp » Logged
From Russia with love... ;-)))
dayar
« Reply #2 on: November 26, 2007, 11:35:27 11:35 »
Sorry but I can´t view anything... if you posted a link please type it because I´m in a group of Inactive users and i can´t view links.
Thanks.
-Given: 405
-Receive: 545
« Reply #3 on: November 26, 2007, 05:26:05 17:26 »
I've read bad thing's about the colimbus and profiler.If your serious the  LPKF machines are the ones to get,but if your looking for an entry level cnc look at this
h**p://www.fireballcnc.com./
http://www.fireballcnc.com./
Ret12_12
-Given: 104
-Receive: 32
« Reply #4 on: November 26, 2007, 06:20:36 18:20 »
They give you all the parts for only $299.00 ?
-Given: 405
-Receive: 545
« Reply #5 on: November 26, 2007, 06:37:13 18:37 »
I think if you e-mailed them they would tell you what you get,but I think theirs no motor's
user112
-Receive: 139
Salut tuturor(hello to all)
« Reply #6 on: November 26, 2007, 07:33:22 19:33 »
see  this topic last post for cnc pcb machine             http://www.sonsivri.com/forum/index.php?topic=4966.0
knave
-Given: 30
-Receive: 102
« Reply #7 on: November 26, 2007, 09:38:47 21:38 »
A good home made CNC site: http://www.hobbycnc.hu/
dayar
« Reply #8 on: November 26, 2007, 10:27:47 22:27 »
I take a look for this machine. Thanks.
I already read bad think's about profiler. Thanks for the link but i'm searching for better cnc machine with software and precision motor.
Sorry but I can´t view links... I´m in a group of Inactive users.
Thanks.
dave
« Reply #9 on: January 31, 2008, 07:12:01 07:12 »
  Look at FireballCNC dot com.  They also have a Yahoo Group.  You have to add your own steppers and controller and power supply.  But, there are recommended units.  It reportably has been used for PCB routing.  I just got one and intend to do that also.  Even with the recommended steppers and controller and Dremel Tool, the total was less than $800.
RsX
-Given: 16
« Reply #10 on: February 05, 2008, 12:41:45 12:41 »
i'm building my cnc but i'm stuck at the x axis :°
user112
-Receive: 139
« Reply #11 on: February 05, 2008, 02:29:05 14:29 »
maybe this will help you
http://www.fullnet.com/~tomg/gooteecn.htm
http://storm.ca/~rheslip/cnc.htm
« Last Edit: February 09, 2008, 08:57:03 20:57 by user112 » Logged
RsX
-Given: 16
« Reply #12 on: February 05, 2008, 03:03:22 15:03 »
i like the second one...the fixed bridge is the common solution and it seems the easiest way
unfortunately i've pick the hard way of floating bridge and i'm building a very big cnc... about 50x50cm ... :/
fastlink30
-Given: 15
« Reply #13 on: February 23, 2008, 10:49:43 10:49 »
look here, cheap mechanics, but very good...
http://cgi.ebay.it/Meccaniche-CNC-Per-Pantografo-Fresa-Fresatrice_W0QQitemZ320220065459QQihZ011QQcategoryZ633QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
i-nick007
« Reply #14 on: March 02, 2008, 03:00:02 03:00 »
nice thank for all shared
READ THE RULES YOU HAVE BEEN WARNED
WIZPIC
« Last Edit: March 02, 2008, 07:15:31 07:15 by Wizpic » Logged
tuvoj
« Reply #15 on: March 19, 2008, 09:20:42 09:20 »
We use a Roland PNC-2300 for routing PCBs. You can get one VERY cheap on the used market, and all kinds of software is available since the controller uses HPGL type language...Can do sub 5 mil traces easily with perfect double sided results
Cheers-Tuvo
jherasmus
« Reply #16 on: March 22, 2008, 08:19:21 20:19 »
if u are going to biuld a cnc yourself
there r nice servo controllers like the dspic-servo for homemade projects http://members.shaw.ca/swstuff/dspic-servo.html
The Navigator
-Given: 20
-Receive: 117
« Reply #17 on: May 12, 2008, 01:28:59 01:28 »
CNC machine project
http://rapidshare.com/files/23948774/maquina_cnc_con_todas_sus_medidas.pdf
