April 18, 2026, 01:58:13 13:58
Author Topic: any one know?  (Read 5407 times)
yohanescalvinus
« on: November 25, 2007, 01:58:39 13:58 »
Hello, i have a question...
how to implemented Fuzzy system to Robotic Artificial Intelligent ?
if i using a micro controller, how to implemented to it ? micro controller use a sequential program ? Doesn't it need parallel processing ?
thanks...   Huh
ashrafhafezg
-Given: 96
-Receive: 364
« Reply #1 on: November 29, 2007, 08:00:42 20:00 »
Fuzzy logic can be implemented using microcontroller not essentially need parallel processing. there is an IEEE paper on the implementation using 8051 but i dont remember the title now!!.
These are some sites and paper on using Fuzzy in robotics
http://iridia.ulb.ac.be/Projects/flar.html
http://www.fujipress.jp/finder/xslt.php?mode=present&inputfile=JACII001100030002.xml
http://cobweb.ecn.purdue.edu/RVL/Projects/FuzzyNav/index.htm
http://www.aass.oru.se/Agora/FLAR/Survey/
http://www.cs.biu.ac.il/~galk/Publications/Papers/fuzzy97.pdf
http://www.techbriefs.com/content/view/2037/34/
http://www.cs.umanitoba.ca/~ckemke/CS-Seminar/posting-25-01-2007.pdf
http://ftp://aass.oru.se/pub/saffiotti/robot/hfc98.ps
http://cobweb.ecn.purdue.edu/RVL/Publications/Pan95FuzzyNav.ps
http://www.iiia.csic.es/~didac/AR/AutonomousRobots.html
http://www.cs.biu.ac.il/~galk/Publications/b2hd-fuzzy97.html
Posted on: November 29, 2007, 08:50:32 20:50 - Automerged
fuzzy+microcontroller
http://www4.ncsu.edu/~chow/Publication_folder/Conference_paper_folder/1999_IECon_FZ_Impl_Tipsuwan.pdf
http://www.depi.itchihuahua.edu.mx/electro/archivo/electro2001/mem2001/articulos/ctl1.pdf
yohanescalvinus
« Reply #2 on: December 04, 2007, 02:08:59 14:08 »
what kind of fuzzy ??
if i wrote like this :
if (statement a) then
   (statement c)
   if (statement b) then
      (statement d)
   else if (statement e)
else if (statement F)
end if
it is one of fuzzy descripted ??
i think that not one of fuzzy category ??
can descripted for me what fuzzy is ?
coz for me fuzzy is one of decision that taken from much condition without if statement..
like a person choose freely but not random.
ashrafhafezg
-Given: 96
-Receive: 364
« Reply #3 on: December 05, 2007, 12:54:05 12:54 »
The difference  between normal variables  a,b,c..etc in the if statement
and the "fuzzy" variable is that in the 1st case they have certain values
but the second are "linguistic" variables.
example:
If all variables are about the value of temperature
normal case:
a=10 degrees
b=20 degrees
c=30 degrees
d=40 degrees
etc.
Fuzzy
a= Low temperature
b= medium temperature
c= high temperature
d=very high  temperature
The decision making using the linguistic values is a long story ..may be stated next!
« Last Edit: December 05, 2007, 04:49:29 16:49 by ashrafhafezg » Logged
