March 07, 2026, 05:56:33 05:56
Author Topic: Req:how to communicate GSM modem using FPGA?  (Read 7954 times)
mcglacy
« on: November 24, 2007, 01:35:07 01:35 »
Anyone here knows how to communicate GSM modem using FPGA?
terval
-Given: 15
« Reply #1 on: November 24, 2007, 10:32:48 22:32 »
First you will need a serial port i believe ,and a micro ip core to probabily send at code to modem,i can“t see other way to do that task,free ipcores : Huh
http://www.freecores.org    and    http://www.opencores.org
Better using low cost fpga board eg. Grin
http://www.xess.com    (xilinx boards)
building
« Reply #2 on: November 28, 2007, 08:12:30 08:12 »
Yes, GSM Modules use serial port communication. you have ipcores of FPGA connect between FPGA and GSM Module. After you write program give FPGA send AT command send to GSM Module.  Cool
Note : Why you don't MCU Control it.  Huh
mcglacy
« Reply #3 on: November 30, 2007, 02:49:58 14:49 »
Yes, i already done controlling GSM devices using PICMicro but for the thesis purposes i will use FPGA.
bogdantk
-Given: 40
« Reply #4 on: December 01, 2007, 07:51:46 07:51 »
Please post information about PIC and GSM modem. I would like to connect two PIC boards
with GSM modems to transfer some files (~400K).
Bogdan
pcapelo
« Reply #5 on: December 08, 2007, 02:22:18 02:22 »
Hello. Can you share the information about GSM modems and PIC micro ? what kind of gsm modems are you using?
Thanks ind advance
building
« Reply #6 on: December 08, 2007, 04:12:07 04:12 »
and FPGA HAVE MCU free ipcores You can use it.
malli_1729
« Reply #7 on: January 23, 2008, 01:07:54 13:07 »
here iam giving the required commands in pdf
elektrom
« Reply #8 on: November 12, 2008, 07:40:51 07:40 »
For Xilinx FPGA, you can use Microblaze MCU. (www.xilinx.com/microblaze)
For Altera FPGA, you can use NIOS MCU. (www.altera.com/nios)
For Actel FPGA, you can use ARM CortexM MCU (http://www.actel.com/products/mpu/CortexM1/default.aspx)
