April 12, 2026, 06:24:13 06:24
Author Topic: Req. PIC programmer  (Read 7233 times)
godblessu
-Given: 133
-Receive: 297
« on: November 23, 2007, 01:56:34 01:56 »
I need MPLAB compatible PIC programmer.
Which is the best?
Does anybody have the programmer's project?
nismo
Translator
-Receive: 14
« Reply #1 on: November 23, 2007, 10:19:25 10:19 »
Hello
You can use PicKit 2 for programming and debuging some pic.
Otherwise you can use ICD2 but the price isn't the same
 Smiley
suptus
« Reply #2 on: November 26, 2007, 08:17:02 20:17 »
Can you make one by yourself?
I can supply you schematic for simple one, I already made, and it work well with MPLAB.
Parts are minimum cost.
kcwcc
-Given: 37
« Reply #3 on: November 26, 2007, 08:58:20 20:58 »
If you can't make one, you can always use the PicStart Plus...it's supported automatically thru MPLab and is a well made unit....I used one for years until it died from neglect after I discovered AVRs...
suptus
« Reply #4 on: November 27, 2007, 08:44:25 20:44 »
If you decide to build a programmer, you also may like to build ICD2 clone, programmer and in-circuit-debugger.
Complete information you will find here:
http://stolz.de.be/
I made that one also, two years ago, it work very well with MPLAB.
If you need any additional information, just write a note.
bliviudaniel
« Reply #5 on: November 29, 2007, 08:58:05 08:58 »
I use PICkit2 and it works very nice. Before PICkit2, I used a home made programmer based on AN589(application note 589) from Microchip. But this programmed it was not very reliable(because I couldn't find proper components and I built it quick&not carefull).
If you want to have a good&cheap programmer that will work anytime and with almost all PICs, I advice you to buy PICkit2.
BLD
chyun3
-Given: 43
« Reply #6 on: December 05, 2007, 02:01:45 14:01 »
Hi...here is the link to PICKIT2 schematic & its' user guide...
http://ww1.microchip.com/downloads/en/DeviceDoc/PICkit%202%20User%20Guide_51553D.pdf
murof
« Reply #7 on: December 06, 2007, 10:14:56 10:14 »
Hi !
Pickit2 schematic and user guide :
http://www.modtronix.com/products/prog/pickit2/pickit2%20datasheet.pdf
mr_sri
-Given: 47
« Reply #8 on: December 16, 2007, 06:02:45 06:02 »
I use ICD2 for programming and debuging under MPLAB IDE
peet3kabo
« Reply #9 on: January 04, 2008, 08:51:19 20:51 »
If you can make a pcb for yourself, maybe this is an idee.
http://www.picbasic.nl/frameload.htm?http://www.picbasic.nl/galvawisp2.htm
lek05134
« Reply #10 on: January 10, 2008, 02:58:19 02:58 »
http://www.wara.com/modules.php?name=project&file=showproject&sid=191&PHPSESSID=439d34c8c8d92290412a90d8772b0ec1
beetlemaniac
« Reply #11 on: January 13, 2008, 05:17:02 05:17 »
Here are the el-cheapo programmer schematics: http://www.rentron.com/Myke4.htm
Although if you have the cash, you could invest in a USB programmer.
fb2007
« Reply #12 on: January 15, 2008, 11:32:59 11:32 »
hi... although i´ve started with mplab compatible proggers... i´m now using the Brenner8 from
www.sprut.de
...a fancy USB device... running like a charm
msnm4
-Given: 41
« Reply #13 on: April 07, 2008, 07:12:08 19:12 »
I tested several programmers according to AN-589 and the ONLY one which worked for me was the WINPIC: see link at http://www.qsl.net/dl4yhf/winpicpr.html
because for some strange reason, it was the only one who could make use of the parallel port of my old notebook where I make this kind of experiments.
In other programmer´s software, the prog. operation just failed. I am not saying they are doing something wrong, just my pc with win98 is fooling around the parallel port when the programmer wants to make use of it.
Besides the AN-589 type, the winpic supports most of available hardwares, it is possible to define new devides to program and best of all...is free and the support from the developer is top class.
Angor
« Reply #14 on: April 10, 2008, 12:16:56 12:16 »
PicKit2 is very cheap and fully compatible with MPLAB
trace
« Reply #15 on: April 25, 2008, 12:20:44 00:20 »
http://www.icd2clone.com/wiki/Main_Page
jack12345
-Given: 59
-Receive: 134
Happy diy
« Reply #16 on: April 25, 2008, 09:47:49 09:47 »
ICD2 is a very good tool, and with MPLAB!
nerone2007
« Reply #17 on: April 25, 2008, 09:23:13 21:23 »
I need an economic pic programmer, can you help me? thanx
dimolin
-Given: 73
-Receive: 31
« Reply #18 on: May 28, 2008, 10:16:56 10:16 »
www.5v.ru  interesting site for those which understand russian Grin
