December 10, 2025, 08:03:08 08:03
Author Topic: GTP-USB Lite  (Read 4552 times)
greywolf
« on: November 22, 2007, 09:35:26 21:35 »
The schematic for the GTP-USB Lite programmer calls for
a 12mhz. crystal. Does anyone know if this can be replaced with
a 16mhz. crystal . If so, what other changes need to be made.
telfo2007
-Given: 8
« Reply #1 on: November 22, 2007, 10:58:01 22:58 »
It seems that gtp firmware clock configuration and timing is based on external 12MHz. Changing clock frequency would make not to be detected by USB PC hardware (not right timing).
GreenGiant
« Reply #2 on: November 23, 2007, 10:12:57 10:12 »
16mhz is not possible, see the datasheet for the PIC to determine what speeds are possible.
Normally, its a multiple of 6mhz, as the PLL can create a frequency from almost any multiple of 6mhz, and then it gets divided to 24mhz for the USB coms.
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #3 on: November 23, 2007, 11:36:04 11:36 »
Stop Posting about GTP-USB programer there is a lot of post in this forum please read before posting, or reply in existing post.
I ask moderator to close this topic
