May 10, 2025, 01:52:26 13:52
Author Topic: how to program 8086 Microprocessor  (Read 7238 times)
shaiqbashir
-Given: 16
Instrumentation..My Extreme Passion
« on: November 22, 2007, 12:32:39 12:32 »
Hi guys!
it looks like a silly question but since i dont know its answer so i have to ask you people about it.
If i want to program 8086 microprocessor, what softwares and hardwares would i require?
I mean is there any Programmer required for this purpose? Is there any schematic available so that i can use it on my own. Is there its software? where i can get it to download? Where i can get its code editor and assembler?
kindly help me out
thanks
zetd
-Receive: 32
« Reply #1 on: November 22, 2007, 12:43:23 12:43 »
hi check this, may help u, and as a starting point to answer your question
   The prototype of C186SBC V1.0
   The C186SBC V1.0 features,
    * CPU:    80C186EB 16MHz
    * MEMORY:    29C010x2, 128kBx2 even and odd Flash
    *                    628128x2, 128kBx2 even and odd SRAM
    * MEMORY and I/O Decoder: GAL16V8D
    * Debug LED: single dot LED connected to P1.7
    * Host terminal interface: RS232 9600 8n1
    * I/O processors interface: half-duplex RS485
    * Expansion connectors: 8-bit buffered cpu bus for peripheral interface and GPIO
    * Monitor Program: x86Bug V1.0
    http://www.kmitl.ac.th/~kswichit/c186/c186sbc.htm
   for the programming, maybe you can google masm32 , flat assembler http://flatassembler.net/ (.. for dos
   maybe), and just an idea how to use turbo c 3, to build your program, and upload obj file to its flash
   gud luk
Dreams really do come true, when home robots do the dirty work for me. everythink is free, no war, no poison on my earth, everyone share thinks but not with my pretty girls,powered by science and humanity not by "dazzle think" - welcome to the planet of earth -
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1298
« Reply #2 on: November 22, 2007, 04:30:41 16:30 »
The 8086 is the first INTEL microprocessor. It can not be programmed because it is a microprocessor. you need to make a circuit that contains RAM and Eprom and the interfaces. you need to program the assembly file on the Eprom Cheesy
« Reply #3 on: November 22, 2007, 07:25:29 19:25 »
HT-Soft has a free compiler for this, http://www.htsoft.com/products/compilers/PACIFICc.php but old Turbo-C as mentioned before is more common.
I don't know if it is the first one or not, but MCS-8 or Intel 8008 is much much more antique than 8086, and yes they don't have internal program memory.
Regards, Ichan.
shaiqbashir
-Given: 16
« Reply #4 on: November 23, 2007, 01:05:56 13:05 »
Dear Ahmed!
thanks for ur support.
But can u tell me about that RAM, EPROM and Interfaces circuits more? I shall be thankful to u for this. Can u provide me some schematics?
Marineland
-Receive: 124
« Reply #5 on: November 24, 2007, 06:24:44 18:24 »
Hi shaiqbashir,
Look around on this web site: http://www.kmitl.ac.th/~kswichit%20/C188/c188sbc.htm
I think you find what you looking for Wink
Marineland
