April 29, 2026, 06:03:25 06:03
Author Topic: How to multiplex 4 Anode Com Seven Segement with one port of 8051 in assembly ?  (Read 5820 times)
saber
-Receive: 53
« on: January 09, 2006, 12:04:30 12:04 »
Hi to all
I build following circuit in the Proteus VSM
I want use this circuit for multiplexing 4 Anode Com Seven Segement
with one port of AT89C51 microcontroller in assembly language
That showing  the " 2006 " number in the seven segement
I write the program in the assembly language but it not working properly
and I not see the " 2006 " number in the seven segements fixedly
and the seven segements are on and off alternately
I upload the my project's files ( .ASM - .HEX - .DSN ) in following address
http://rapidshare.de/files/10706839/AT89C51_Multiplex_Displays.zip.html
You can download it and see my project
Anybody can write this program in the assembly language ?
Please help me
Thanks a lot Smiley
xatax
-Receive: 69
« Reply #1 on: April 16, 2007, 02:30:54 14:30 »
File not found. Please re-upload !!!
Best regards.
zuisti
-Given: 242
-Receive: 780
« Reply #2 on: April 17, 2007, 04:18:34 16:18 »
Please to consider the multiplexed displaying works in the "human eyes" only, beacuse it displays one digit at a time. Press "pause" at times in the Proteus simulation...
zuisti
Dom
-Given: 65
-Receive: 32
« Reply #3 on: April 17, 2007, 04:35:53 16:35 »
Yes, as zuisti said, you must take the 4 seven segment panel especially used for the multiplexed display like in the example of Proteus (read the help of the four digit component).
Dom
sukumar
-Receive: 47
« Reply #4 on: June 26, 2007, 01:48:27 13:48 »
Use the following code, The diagram should be modified as per the following code.
ie:PORT2 is DATA port (all the 8 bits) P0=control bits
#include<reg51.h>
void send_seg(int,int,int,int);
unsigned char n=1;
unsigned char thou=2,hun=0,ten=0,single=6;
unsigned char a[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void DelayMs(unsigned char);
void main()
P0=P2=0;
while(1)
send_seg(thou,hun,ten,single);
void send_seg(int thou,int hun,int ten,int single)
if(n==1)
P0=0x08;
P2=a[single];
n=2;
DelayMs(5);
else if(n==2)
P0=0x04;
P2=a[ten];
n=3;
DelayMs(5);
else if(n==3)
P0=0x02;
P2=a[hun];
n=0;
DelayMs(5);
else
P0=0x01;
P2=a[thou];
n=1;
DelayMs(5);
void DelayMs(unsigned char Ms)
int i;
for(i=0;i<Ms*48;i++);
}[/code
M.Sukumar
Never say No
