April 26, 2026, 01:41:28 01:41
Author Topic: mmc format  (Read 6276 times)
94491203
-Given: 8
-Receive: 21
« on: November 21, 2007, 05:43:18 17:43 »
/*** MMC Unlocker *************************************************************
 * File Name  : mmcfmt.c
 * Title      : Multi-Media Card Unlocker
 *  Description: Reset locked MMC cards (and wipes all data) allowing them
 *                to be used again
 * Created    : 2004 / 01 / 27
 * Version    : 0.1
 * Target MCU : STK500 (can be used w/any AVRs with enough pins for
                 the MMC card (4) plus any switches/LEDs you want)
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License
 * as published by the Free Software Foundation; either version 2
 * of the License, or (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
#include <stdio.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/signal.h>
#include <avr/pgmspace.h>
#include <ctype.h>
#include <inttypes.h>
#include <string.h>
#define MMC_PORT PORTC
#define MMC_PIN PINC
#define MMC_DDR DDRC
#define MMC_CS      PC0
#define MMC_MISO    PC2
#define MMC_MOSI    PC1
#define MMC_CLK     PC6
#define LED_PORT PORTB
#define LED_PIN PINB
#define LED_DDR DDRB
#define SW_PORT PORTA
#define SW_PIN PINA
#define SW_DDR DDRA
#define BAUDRATE 115200
#define BAUD_REG ((uint16_t)((F_CPU / (16.0 * (BAUDRATE))) + 0.5) - 1) // if above .5 mark, round up; replace 16 with 8 for double
#define BAUD_H  ((uint8_t)(0xFF&(BAUD_REG>>8)))
#define BAUD_L ((uint8_t)(0xFF&BAUD_REG))
#define spi_response() spi_byte(0xFF) // read response
#define spi_busywait() while(spi_byte(0xFF) == 0) // wait for non-zero response to continue
uint8_t spi_cmd[5]; // 6 is CRC, which we won't be using here (or should be generated indide spi_command())
uint8_t reg_csd[16];
uint8_t reg_cid[16];
uint16_t block_len;
uint32_t block_cnt;
/*** SIG_UART_RECV ************************************************************
 * interrupt on receive byte; for now just echo if any char received
SIGNAL (SIG_UART_RECV) {
uint8_t temp;
temp = UDR; // read
LED_PORT = ~temp; // show the current command on the LEDs
if(temp=='\r' || temp == '\n') {
printf_P(PSTR("\n\r"));
else
UDR = temp; // write (just echo what the user types)
uint8_t uart_tx(uint8_t uart_tx) {
while(!(UCSRA & _BV(UDRE))); // wait for empty tx buffer
UDR = uart_tx; // put data in buffer, init send
return 0;
// uint8_t uart_tx(uint8_t uart_tx)
uint8_t uart_rx(void) {
while(!(UCSRA & _BV(RXC))); // wait for full rx buffer
return UDR;                   /* return the new c */
// uint8_t uart_rx(void)
/*** delay ********************************************************************
 * rough delay; 65k loops, 4 instr each, +over head: 65536*4 = 262144,
 * round up tp 300000 clks (time: 300000/F_CPU seconds)
void delay(void) {
uint8_t i, j;
for(i=0; i<255; i++) {
for(j=0; j<255; j++) {
asm volatile("nop"::);
// void delay(void)
/*** show_resp ****************************************************************
 * show value in response on LEDs and wait for keypress; for debugging only
void show_resp(uint8_t retval) {
LED_PORT = ~(retval); // light leds 0-7 according to error,
// and show that system is waiting (led7)
loop_until_bit_is_clear(SW_PIN, 0); // wait for sw0 to be pressed
delay(); // debounce delay
loop_until_bit_is_set(SW_PIN, 0); // wait for sw0 to be released
LED_PORT = 0xFF; // clear all leds
// void show_resp(uint8_t retval)
/*** spi_byte *****************************************************************
 * Send one, receive one (happens simultaneously)
uint8_t spi_byte(uint8_t spi_tx) {
uint8_t i, spi_rx = 0;
for(i=8; i>0; i--) {
    i--;
if( bit_is_set(spi_tx,i) )
    MMC_PORT |= _BV(MMC_MOSI);  // set mosi pin
else
    MMC_PORT &= ~_BV(MMC_MOSI);  // clr mosi pin
// read MISO
    spi_rx <<= 1; // x2, shift left to create space for next
if( bit_is_set(MMC_PIN,MMC_MISO) )
spi_rx++;
MMC_PORT |= _BV(MMC_CLK); // clk high
    MMC_PORT &= ~_BV(MMC_CLK); // clk low
    i++;
return spi_rx;
// uint8_t spi_byte(uint8_t spi_tx)
/*** spi_command **************************************************************
 * Send contents of command structure, get (first) response byte
uint8_t spi_command(void) {
uint8_t retval, i;
MMC_PORT &= ~_BV(MMC_CS); // cs low (select, spi mode)
spi_byte(0xFF);
// send command struct
spi_byte(spi_cmd[0] | 0x40); // make 2 MSBs '01' (01xxxxxx, where x represents command bit)
spi_byte(spi_cmd[4]); // address
spi_byte(spi_cmd[3]); //    "
spi_byte(spi_cmd[2]); //    "
spi_byte(spi_cmd[1]); //    "
spi_byte(0x95); // CRC (from spec; calculate?)
// spi_byte(0xFF);
i=0;
do { // Flush Ncr (1-8 bytes) before response
retval = spi_byte(0xff);
i++;
} while(i<8 && retval == 0xFF);
return retval; // return R1 response (or first byte of any other command)
// uint8_t spi_command(void)
/*** get_slice ****************************************************************
 * get the requested portion of the given register
uint16_t get_slice(uint8_t *ptr_reg, uint8_t start, uint8_t stop) {
uint8_t upper, lower, lower_s, count, i;
uint32_t rval=0;
lower = stop / 8.0;
upper = start / 8.0;
// merge all used bytes into on large var
count = upper - lower;
for(i=0; i<=count; i++) {
rval <<= 8;
rval |= ptr_reg[upper-i];
// shift data down so it starts at zero
lower_s = stop - (lower * 8);
rval >>= lower_s;
// clear upper bits (all bits before start)
start -= stop;
start++;
//for(i=start; i<32; i++)
for(i=start; i<16; i++) // clear bits 15-start
rval &= ~(1<<i);
rval &= 0x0000FFFF; // clear bits 31-16
return (uint16_t)rval;
// uint16_t get_slice(uint8_t ptr_reg[], uint8_t start, uint8_t stop)
/*** get_regs *****************************************************************
 * read the contents of the CSD + CID registers from the card
void get_regs(void) {
uint8_t i, c_size_mult, read_bl_len;
spi_cmd[0] = 9;
printf_P(PSTR("\n\rResponse to CMD9: 0 / %d"), spi_command());
while(spi_byte(0xFF) != 0xFE); // wait for data start token; add time-out?
for(i=0; i<16; i++)
reg_csd[15-i] = spi_byte(0xFF); // fill in from MSB
printf_P(PSTR("\n\r Contents of CSD Register:")); // defaults from SanDisk 32MB card / read values
printf_P(PSTR("\n\r  CSD_STRUCTURE: 1 / %x"), get_slice(reg_csd,127,126) );
printf_P(PSTR("\n\r  MMC_PROT: 1 / %x"), get_slice(reg_csd,125,122) );
printf_P(PSTR("\n\r  Reserved: 0 / %x"), get_slice(reg_csd,121,120) );
printf_P(PSTR("\n\r  TAAC: 26 / %x"), get_slice(reg_csd,119,112) );
printf_P(PSTR("\n\r  NSAC: 0 / %x"), get_slice(reg_csd,111,104) );
printf_P(PSTR("\n\r  TRAN_SPEED: 2a / %x"), get_slice(reg_csd,103,96) );
printf_P(PSTR("\n\r  CCC: 1ff / %x"), get_slice(reg_csd,95,84) );
read_bl_len=get_slice(reg_csd,83,80);
printf_P(PSTR("\n\r  READ_BL_LEN: 9 / %x"), read_bl_len );
printf_P(PSTR("\n\r  READ_BL_PARTIAL: 1 / %x"), get_slice(reg_csd,79,79) );
printf_P(PSTR("\n\r  WRITE_BLK_MISALIGN: 0 / %x"), get_slice(reg_csd,78,78) );
printf_P(PSTR("\n\r  READ_BLK_MISALIGN: 0 / %x"), get_slice(reg_csd,77,77) );
printf_P(PSTR("\n\r  DSR_IMP: 0 / %x"), get_slice(reg_csd,76,76) );
printf_P(PSTR("\n\r  Reserved: 0 / %x"), get_slice(reg_csd,75,74) );
block_cnt=get_slice(reg_csd,73,62); // this var is c_size, not block count; just using the block cnt to save space (instead of creating new var)
printf_P(PSTR("\n\r  C_SIZE: - / %x"), block_cnt );
printf_P(PSTR("\n\r  VDD_R_CURR_MIN: 4 / %x"), get_slice(reg_csd,61,59) );
printf_P(PSTR("\n\r  VDD_R_CURR_MAX: 4 / %x"), get_slice(reg_csd,58,56) );
printf_P(PSTR("\n\r  VDD_W_CURR_MIN: 5 / %x"), get_slice(reg_csd,55,53) );
printf_P(PSTR("\n\r  VDD_W_CURR_MAX: 5 / %x"), get_slice(reg_csd,52,50) );
c_size_mult=get_slice(reg_csd,49,47);
printf_P(PSTR("\n\r  C_SIZE_MULT: - / %x"), c_size_mult );
printf_P(PSTR("\n\r  SECTOR_SIZE: 0 / %x"), get_slice(reg_csd,46,42) );
printf_P(PSTR("\n\r  ERASE_GRP_SIZE: - / %x"), get_slice(reg_csd,41,37) );
printf_P(PSTR("\n\r  WP_GRP_SIZE: 1f / %x"), get_slice(reg_csd,36,32) );
printf_P(PSTR("\n\r  WP_GRP_ENABLE: 1 / %x"), get_slice(reg_csd,31,31) );
printf_P(PSTR("\n\r  DEFAULT_ECC: 0 / %x"), get_slice(reg_csd,30,29) );
printf_P(PSTR("\n\r  R2W_FACTOR: 4 / %x"), get_slice(reg_csd,28,26) );
printf_P(PSTR("\n\r  WRITE_BL_LEN: 9 / %x"), get_slice(reg_csd,25,22) );
printf_P(PSTR("\n\r  WRITE_BL_PARTIAL: 0 / %x"), get_slice(reg_csd,21,21) );
printf_P(PSTR("\n\r  Reserved: 0 / %x"), get_slice(reg_csd,20,16) );
printf_P(PSTR("\n\r  Reserved: 0 / %x"), get_slice(reg_csd,15,15) );
printf_P(PSTR("\n\r  COPY: 1 / %x"), get_slice(reg_csd,14,14) );
printf_P(PSTR("\n\r  PERM_WRITE_PROTECT: 0 / %x"), get_slice(reg_csd,13,13) );
printf_P(PSTR("\n\r  TEMP_WRITE_PROTECT: 0 / %x"), get_slice(reg_csd,12,12) );
printf_P(PSTR("\n\r  Reserved: 0 / %x"), get_slice(reg_csd,11,10) );
printf_P(PSTR("\n\r  ECC: 0 / %x"), get_slice(reg_csd,9,8) );
printf_P(PSTR("\n\r  CRC: - / %x"), get_slice(reg_csd,7,1) );
printf_P(PSTR("\n\r  Not Used (Always 1): 1 / %x"), get_slice(reg_csd,0,0) );
block_cnt++;
block_cnt *= (1<<(c_size_mult+2));
block_len = (1<<read_bl_len);
printf_P(PSTR("\n\r Card Size:  %ld blocks @ %db = %ldmb\n\r"),
block_cnt, block_len, block_cnt*block_len/1000000 );
spi_cmd[0] = 10;
printf_P(PSTR("\n\rResponse to CMD10: 0 / %d"), spi_command());
for(i=0; i<16; i++)
reg_cid[15-i] = spi_byte(0xFF); // fill in from MSB
printf_P(PSTR("\n\r Contents of CID Register:"));
printf_P(PSTR("\n\r  Product Name: "));
for(i=0; i<7; i++)
uart_tx(reg_cid[12-i]);
printf_P(PSTR("\n\r  Mfg Month: %d"), get_slice(reg_cid,15,12)); // ??? card returns 12/2005
printf_P(PSTR("\n\r  Mfg Year: %d"), 1996+get_slice(reg_cid,11,8)); // ??? .. unless it's 12/2004?
// void get_regs(void)
/*** init_spi *****************************************************************
 * init card
void init_spi(void) {
uint8_t tries, retval;
MMC_PORT |= _BV(MMC_CS); // cs high (deselect)
spi_byte(0xFF); // spec says to clock at least 74 high bits into the
spi_byte(0xFF); // MMC; we'll do 80 here, it's easier ;)
spi_byte(0xFF);
spi_byte(0xFF);
spi_byte(0xFF);
spi_byte(0xFF);
spi_byte(0xFF);
spi_byte(0xFF);
spi_byte(0xFF);
spi_byte(0xFF);
// send CMD0 (reset/idle)
// send CMD0 (reset) continuously until out of idle
// loop until return == 00 0001 (idle); ?after timeout there's an error
tries = 0xFF;
while(( (retval=spi_command())==0) && tries!=0) // (less space than checking !=1) all vals in array already 0, no need to mod spi_command
tries--; // all vals in array already 0, no need to mod
printf_P(PSTR("\n\rResponse to CMD0: 1 / %d"), retval); // get rid of retval assignment in while when done debugging
if(tries == 0)
return;
// send CMD1 (init) continuously until ready
// loop until return == 00 0000 (ready); ?after timeout there's an error
spi_cmd[0] = 1;
tries = 0xFF;
while(( (retval=spi_command())!=0) && tries!=0) //
tries--;
printf_P(PSTR("\n\rResponse to CMD1: 0 / %d"), retval);
if(tries == 0)
return;
spi_cmd[0] = 13;
retval = spi_command();
printf_P(PSTR("\n\rResponse to CMD13: 0,0 / %d,%d"), retval,spi_byte(0xff));
    // show 1st and 2nd bytes of R1b response
get_regs();
// void init_spi(void)
/*** init_io ******************************************************************
 * init io ports
void init_io(void) {
// init ports
/* PORT C pins connected to MMC
0 / CS - out, high (inactive)
1 / DO - out from MMC (MISO, only read on clock)
2 / DI - in to MMC (MOSI)
4 / GND - 2nd ground; make output and ground pin
6 / CLK - in to MMC
// C G MMC
// K   IOS
MMC_DDR = 0b01010011; // 1011 1111: all outputs except Din (PA6); PA7 unused
MMC_PORT = 0b10101101; // 1100 1011: gnd, clk, MOSI low, others high (pull-up on Din)
LED_DDR = 0xFF; // all leds are outputs
LED_PORT = 0xFF; // all leds off
SW_DDR = 0x00; // all switches are inputs
SW_PORT = 0xFF; // pull-ups active
// init USART
// UCSRC &= ~_BV(UMSEL); // make sure we're in async mode
// UCSRA |= _BV(U2X); // set double speed, change 16 to 8 below
// set baud rate: UBRR = (F_CPU/(16*BAUDRATE)) - 1
UBRRH = BAUD_H;
UBRRL = BAUD_L;
UCSRB = _BV(RXEN) | _BV(TXEN) | _BV(RXCIE); // enable tx, rx //and rx int
sei();
// void init_io(void)
/*** init_vars ****************************************************************
 * init vars
void init_vars(void) {
spi_cmd[0] = 0; // command
spi_cmd[4] = 0; // 31-24 (MSB)
spi_cmd[3] = 0; // 23-16
spi_cmd[2] = 0; // 15-08
spi_cmd[1] = 0; // 07-00 (LSB)
// void init_vars(void)
int main(void) {
// uint8_t retval;
init_vars();
init_io();
FILE * stdio_dev;
stdio_dev = fdevopen(uart_tx, uart_rx, 0);
printf_P(PSTR("\n\r\n\r\n\rLocked Card Fixer (build 050831017), by Muhammad J. A. Galadima.\n\r\n\r"));
init_spi();
printf_P(PSTR("\n\r\n\r\n\rPlease remove your card now, or press a key to wipe."));
show_resp(128);
printf_P(PSTR("\n\rPerforming card WIPE..."));
// now do something (ie. erase card!)
// set block length to 1
spi_cmd[0] = 16; // set block length / R1
spi_cmd[4] = 0; // set size to 1
spi_cmd[3] = 0; // "
spi_cmd[2] = 0; // "
spi_cmd[1] = 1; // "
spi_command();
// send the send forced erase command
spi_cmd[0] = 42; // LOCK_UNLOCK / R1b
spi_cmd[4] = 0; //
spi_cmd[1] = 0; // "
spi_command();
spi_busywait(); // wait for busy
// send the data byte (1 byte, as defined in block length)
spi_byte(0b11111110); // data start token
spi_byte(0b00001000); // forced erase
spi_byte(0xFF); //
spi_byte(0xFF); // CRC
printf_P(PSTR("\n\r\n\rData Response: 0x%x"), 0b00011111 & spi_byte(0xFF)); // read data response
spi_busywait();
printf_P(PSTR("\n\rCard Erased!"));
uint32_t i;
uint8_t block[512];
for(i=0; i<512; i++)
block[i] = 0;
// loop forever
    for (;;);
« Last Edit: May 23, 2008, 06:55:49 18:55 by metal » Logged
khan_yousaf
-Given: 33
-Receive: 89
« Reply #1 on: May 14, 2008, 07:40:02 19:40 »
Would it work with an SD card or the commands need to be trimmed for that interface??
bugmike25
-Given: 15
« Reply #2 on: May 16, 2008, 06:16:58 18:16 »
It should work since they use the same commands and this program is using the SPI interface and not the MMC format or SD format.
