December 10, 2025, 07:17:34 07:17
Author Topic: usb connect - need help  (Read 5577 times)
terval
-Given: 15
« on: November 20, 2007, 08:52:12 20:52 »
any one can help me on :
i need usb connectivity to pc (pic18f2550 or pic18f4550) to everything ,port(x), i2c, serial ,adc ?
any idea or soft.
Best regards to all.
8K51
-Given: 86
-Receive: 40
« Reply #1 on: November 20, 2007, 09:00:33 21:00 »
If you don't want to developp your own firmware UBW board is an answer :
http://greta.dhs.org/UBW/
FlvAnm
-Given: 29
« Reply #2 on: November 20, 2007, 09:09:50 21:09 »
Perhaps this link (http://www.alanmacek.com/usb/) - USB and PIC Microprocessors 16C745 and 18F2455 could be usefull.
it's quite old, but interesting.
Best Regards,
FLV
microled
-Given: 15
« Reply #3 on: November 20, 2007, 09:40:12 21:40 »
If you check the picbasic forum you will find all the answers you need, plus quite a few more!!
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #4 on: November 21, 2007, 02:32:51 02:32 »
@terval
All suggestions given already are ok but maybe you get confused analyzing already made examples that are more complicated than needed.
I would say , try to keep it always as simple as the proyect at hands permits.
1.- First establish a clean link between PIC and Pc , that you can accomplish easy with CDC ( USb Serial )  or HID ( Both supported by MS Visual  on Pc and BASIC for PIC )
2.- Develop an communication code to talk between both platforms wich includes the commands and type of info you want to share.
3.- Write the code to handle the messages on both sides based on 2.-
For example , one message coming from Pc to PIC could be the string "AAAC01XXX" where AAA = Flag to announce message start , C01 = Command for PIC to sample analog port 1 , XXX = Flag to indicate termination off message. To this , PIC could answer with another message "AAAV010985XXX" . In this mesage , AAA and XXX can have the same meaning as before and V010985 will indicate V01 = value of variable 01 , 0985 = value 985
On Pc side it will be easy to manage the polling of serial port with function OnCom() ( prescence of data on com port ).
On PIC side it can be more tricky but you will soon find a way to poll the port with needed timing and let the code handle the messages from there on.
Hope this simple description helps you as a very basic startpoint
For CDC and HID see examples in Proteus,Proton and PBPro
Greetings
terval
-Given: 15
« Reply #5 on: November 27, 2007, 08:12:22 20:12 »
Hi frasenci
Now i understand much more about, using your information,and it seem“s not so dificult,this protocol looks an easy way to work.
aj49m
-Given: 36
-Receive: 41
« Reply #6 on: November 27, 2007, 08:57:58 20:57 »
Certainly class CDC is easier for working with transfer data usb, Programming PC Simplifies
drovik
« Reply #7 on: November 28, 2007, 11:06:17 11:06 »
www.microchip.com Smiley or Proteus 7.2 (samples CDC, HID, GeneralUSB with temperature sensor for 18F4550)
bogdantk
-Given: 40
« Reply #8 on: November 28, 2007, 02:25:19 14:25 »
Hello
The easy way is to coonect via the serial port and an FT245R adapter to USB
Check http://www.ftdichip.com/Products/FT245R.htm
you will find the driver also it will map the usb to a com port very easy to use
micro_2000
-Given: 28
« Reply #9 on: November 28, 2007, 07:20:28 19:20 »
Hi.. The FT232R also easy to used as USB to serial converter too.
Need not additional external component.
