December 10, 2025, 07:16:17 07:16
Author Topic: Help needed Universal programmer algorithm  (Read 4405 times)
gem1144aaa
-Given: 134
-Receive: 27
« on: November 20, 2007, 10:22:48 10:22 »
Hi everybody
i've a xeltek 580u programmer its an 48 universal pin driver on an 48 zif socket
just like its big brother 3000u but it programs less devises than the 3000u
note the 3000u alone with no adapters and with no pin driver i mean with its standard 48 zif socket programs much devices than the 580u
is there any means to program the extra devices on the 580u or to adapt the algorithms to run on the 580u?
all opinions are welcome
best regards
« Last Edit: November 20, 2007, 02:43:39 14:43 by gem1144aaa » Logged
localcrack
-Receive: 21
« Reply #1 on: December 08, 2007, 09:05:09 21:05 »
 Huh
It was not possible because hardware and firmware of both is different
However both programmer uses same software for programming.
The software checks each time hardware ID when communicating with hardware then it populates device lists.
so if any one can develope USB emulator for this programmer then it is possible to write more devices withe 580u.
gem1144aaa
-Given: 134
-Receive: 27
« Reply #2 on: December 10, 2007, 09:09:03 09:09 »
hi localcrack
i appreciate your response and let me tell you that the manufacturer supplies a dll called "spoem.dll"
this is the link to the www.iczoo.com/sprom/index/terminal/How_to_use_spoem.pdf
user explanation but the dll file itself is not found do you have any link to that file?
