You think I am funny guy huh?
December 10, 2025, 07:16:16 07:16
Author Topic: Req:Low cost 16bit uninterrupted baseband analog signal recorder/player  (Read 4438 times)
www20000
-Given: 76
-Receive: 75
« on: November 16, 2007, 06:51:11 06:51 »
I need a Low cost 16bit uninterrupted baseband analog signal recorder/player (Data logger) PC based or stand alone.
The most important features required is the uninterpretablity, I need the played signal to be identical to the original one.
Best Regards.
Place for everything & Everything in place!
tae
« Reply #1 on: December 01, 2007, 02:01:46 02:01 »
you go with analog.com (they provide samples for amny countries ) or similar makers of 16 bits adc  (and more ) then any 8 bit micro (but you have not mentioned the sampling rate - that could be a big constraint) and may be sd or mmc card to things within nonvolatile. There are ready to use libraries for MMC for different micros and adc connection should not be a problem but layout must be done properly to get all 16 bits. Pay attention to signal conditioning before ADC as it must provide performance for 16 bit aquisition .
BTW analog has nice application documents concerning subject  .
www20000
-Given: 76
-Receive: 75
« Reply #2 on: December 05, 2007, 10:57:17 10:57 »
Hi tae
-What I need is a ready-made on-shelf product.
-About the sampling rate, in my case the sampled signal is within the voice band.
-Can you please post the link for the analog application document?
