April 29, 2026, 06:03:55 06:03
Author Topic: WTD: Service Manual Kenwood PSR20-18M  (Read 5205 times)
PM3295
-Given: 365
-Receive: 157
« on: April 06, 2015, 03:45:41 15:45 »
I am looking for a service manual for this remote programmable PSU.
http://www.ebay.com/itm/NEW-Kenwood-Texio-PSR20-18MY3-DC-Regulated-Power-Supply-20-VDC-18-A-/131394111385
So far, I was unable to find a copy free or for sale of the manual anywhere.
The problem with my unit is that you can set up the desired voltage and current from the programming unit PSR-600, and that will display on the PSR20.
When you press to enter or output on, the unit goes into "CC" constant current mode with, I and V showing zero. I suspect a problem with the power supply rather than the controller.
Unfortunately, I don't have a spare of either to verify.
The output of the PSR20 is not shorted as to cause this condition.
Any help appreciated.
Thanks.
« Last Edit: April 06, 2015, 03:49:01 15:49 by PM3295 » Logged
norkimo
-Given: 33
-Receive: 71
« Reply #1 on: April 06, 2015, 09:45:54 21:45 »
The output may not be shorted, but have you taken a peek inside the supply yet?  Sometimes failed components are more obvious than you might think and could point to where you should start looking.
Also, and I realize this may sound like a silly or "obvious" answer, have you tried contacting Texio Support yet? http://www.texio.co.jp/en/06cont_00.html
Even though it sometimes feels counter-intuitive, I've had great luck contacting the OEM for service manuals when it comes to power supplies.
PM3295
-Given: 365
-Receive: 157
« Reply #2 on: April 07, 2015, 01:29:52 01:29 »
I had the unit open previously and could not see any blown components. Furthermore, spot checks with a meter did not show any shorted components. It is a very compact unit with the microprocessor and power pcb's stacked on each other. It does not look that service friendly at first glance. I will try to contact the service support and see if I can get any service information.
