December 10, 2025, 07:15:57 07:15
Author Topic: Need help for ICD2 LE  (Read 7238 times)
sohel
-Given: 169
-Receive: 149
« on: October 27, 2007, 05:55:08 17:55 »
 I have MPLAB ICD2 LE which collect from MIcrochip Seminer. they give me a 16bit 28 pin demo board and one MPLAB ICD2 LE. it working fine . when i using only ICD2 for ICSP Progarmming reverse voltege go to the ICD2 and it burn output switcher ic DG411DY . but here i cant find this switcher ic. any procedure to get working mode for only programming?
or something  Huh Huh Huh
Connecting to MPLAB ICD 2
...Connected
Setting Vdd source to target
ICDWarn0020: Invalid target device id (expected=0x447, read=0x0)
...Reading ICD Product ID
Running ICD Self Test
... Failed Self Test.  See ICD2 Settings (status tab) for details.
MPLAB ICD 2 Ready
picture added
« Last Edit: October 27, 2007, 06:40:00 18:40 by sohel » Logged
Soter
-Given: 24
« Reply #1 on: October 28, 2007, 03:12:47 03:12 »
...Connected
MPLAB ICD 2 Ready
picture added
Yes, exist a form to get working, you have to put a 74ls07 and 3 transistors instead of dg411, like this:
Can you put a HD pic of your ICD2 LE?
« Last Edit: October 28, 2007, 03:27:27 03:27 by Soter » Logged
sohel
-Given: 169
-Receive: 149
« Reply #2 on: October 28, 2007, 10:19:15 10:19 »
thanks for ur design i am working on. RA4 will chenge to RA0.
please clear with VDD, ISP-VDD, VPP.
for programming its ok
...Connected
Target Device dsPIC33FJ12GP202 found, revision = Rev 0x3001
...Passed
MPLAB ICD 2 Ready
Programming Target...
...Validating configuration fields
...Erasing Part
...Programming Program Memory (0x0 - 0x37F)
Verifying...
...Program Memory
...Verify Succeeded
...Programming Configuration Bits
.. Config Memory
Verifying configuration memory...
...Programming succeeded
28-Oct-2007, 16:58:45
MPLAB ICD 2 Ready
...Connected
...Passed
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Program Memory
...Verify Succeeded
...Loading DebugExecutive
...Programming DebugExecutive
...Debug Executive
...Programming Debug Vector
...Debug Vector
.. Config Memory
Connecting to debug executive
28-Oct-2007, 17:41:21
MPLAB ICD 2 Ready
Running Target
Halting Target
MPLAB ICD 2 Ready
MPLAB ICD 2 Ready
Stepping Target
MPLAB ICD 2 Ready
Stepping Target
MPLAB ICD 2 Ready
Stepping Target
MPLAB ICD 2 Ready
Stepping Target
MPLAB ICD 2 Ready
Stepping Target
MPLAB ICD 2 Ready
Stepping Target
MPLAB ICD 2 Ready
Stepping Target
MPLAB ICD 2 Ready
Stepping Target
MPLAB ICD 2 Ready
and go on
can u advice how can i make a universal icsp adapter? i want to work with 16f and 18f. with this icd2le
many many thanks  Grin Cheesy
« Last Edit: October 28, 2007, 12:45:58 12:45 by sohel » Logged
Soter
-Given: 24
« Reply #3 on: October 28, 2007, 08:45:49 20:45 »
Hi sohel
Why do you change ra0 instead ra4?, I'm very sure is ra4
VDD: Take it direct from the USB power.
VPP: Take it from the output of the Boost circuit (DC-DC converter). If you show me a Good picture (HD) from your ICD2 I can tell you.
ISP-VDD: Is the output of the Q2 Transistor and the input for the Q4 transistor, and also to power your target.
ISP adapter:
http://www.kmitl.ac.th/~kswichit/ezpic/index.html
Good to know it's working  Wink
you're welcome
« Last Edit: October 28, 2007, 09:09:23 21:09 by Soter » Logged
sohel
-Given: 169
-Receive: 149
« Reply #4 on: October 29, 2007, 01:25:04 13:25 »
but it only work on low voltage programme and debug. like 3.3v dspic, its didnt work on 14 bit core.
 Cry Cry Cry
Xwing
-Given: 616
-Receive: 1537
« Reply #5 on: October 30, 2007, 07:36:13 19:36 »
Verify MCLR pin, if forced to logical 0 (gnd) DG411DY burn.
sohel
-Given: 169
-Receive: 149
« Reply #6 on: October 30, 2007, 08:16:07 20:16 »
Can some one help me to get one DG411DY by mail. i cant find here. Cry
i can pay for one.
maxim  not faster for send something.
« Last Edit: October 30, 2007, 08:25:54 20:25 by sohel » Logged
Soter
-Given: 24
« Reply #7 on: October 30, 2007, 09:43:53 21:43 »
HI masud
I give you all the tools to correct the problem and none of them you are using. Study the diagrams that I send you and so you can solve this problem.
It is not complicated.
« Last Edit: October 31, 2007, 04:24:43 04:24 by Soter » Logged
sohel
-Given: 169
-Receive: 149
« Reply #8 on: October 30, 2007, 09:50:01 21:50 »
its three night and four day i have tested, if u think another couple day then i will die. u know that.  thanks Roll Eyes
Soter
-Given: 24
« Reply #9 on: October 30, 2007, 09:58:43 21:58 »
Yes but i say you to take ra4 And you do not believe me  Wink.
« Last Edit: October 30, 2007, 10:02:16 22:02 by Soter » Logged
sohel
-Given: 169
-Receive: 149
« Reply #10 on: October 31, 2007, 03:29:16 03:29 »
Gracias
for ur hard work give me the light. many many thanks.  with live chat video.  wow nice guies   Grin
Soter
-Given: 24
« Reply #11 on: October 31, 2007, 03:33:02 03:33 »
Gracias
dhonnobad
Enjoy your new programmer and thanks for you gift  Wink .
« Last Edit: October 31, 2007, 04:20:45 04:20 by Soter » Logged
sohel
-Given: 169
-Receive: 149
« Reply #12 on: October 31, 2007, 03:37:23 03:37 »
please rego dont banned me because he helped me a lot. whole night and day he work for me without any cost. he also use my mother language dhonobad, (thanks)
« Last Edit: October 31, 2007, 03:41:09 03:41 by sohel » Logged
9thwonder
« Reply #13 on: November 20, 2007, 10:13:36 10:13 »
Dear Shoel
The Icd2 you collected from GURGAON Microchip seminar works well I have tested .
Icd2 must be attached to usb port after opening the mplab if you connect before it may give trouble because of driver settings pl go to the help mplab and search icd2.
the power supply should be of 5 volts. which is provided with a usb cable supplied.
thanks
