December 10, 2025, 07:18:33 07:18
Author Topic: Hyperterminal  (Read 5689 times)
pinoytsikboy
-Given: 68
« on: October 24, 2007, 02:49:31 02:49 »
Hi. i'm trying to use hyperteminal to simulate a project using a modem. But i'm a newbie on this. How to implement any links or tutorial will be appreciated. thanks is advance.
mcr
-Given: 218
-Receive: 23
« Reply #1 on: October 24, 2007, 07:26:39 07:26 »
Please explain more your needs, what do you have? What are you trying to do?
Math
« Reply #2 on: October 24, 2007, 06:57:50 18:57 »
This is not even a question, just some text he had in mind to type down here. Be more concrete and say what u need ..
gem1144aaa
-Given: 134
-Receive: 27
« Reply #3 on: October 24, 2007, 09:21:23 21:21 »
hi pinoytsikboy
pls try to explain more about what you want to do so i can help
donno
« Reply #4 on: November 08, 2007, 04:04:45 16:04 »
There are better terminal programs available but you need to provide more info on your
intended application.
Telnet?
Porttalk?
Please provider more detail.
microled
-Given: 15
« Reply #5 on: November 20, 2007, 09:50:58 21:50 »
ZOC is also a good emulator.
building
« Reply #6 on: November 21, 2007, 03:08:23 03:08 »
you test comport by connect 2 serial port to. and open 2 hyperteminal
1. Open hyperterminal 1 set is reciver. etc. com1
2. Open hyperterminal 2 set is send. etc. com2
And you typing data to com2 and com1 will character show.. you comport good.
FlvAnm
-Given: 29
« Reply #7 on: November 21, 2007, 07:58:17 07:58 »
To do this you need a cross cable to connect com port 1 to 2.
For more information on cable, visit "Data Interface a Tutorial on Data Interface and cables" (http://www.arcelect.com/rs232.htm).
Flv
zuisti
-Given: 242
-Receive: 780
« Reply #8 on: November 21, 2007, 09:00:55 09:00 »
Hi pinoytsikboy,
If you are working in Proteus, use the COMPIM model in the DSN and a terminal program to communicate with it.
To do this, yes, you must be using a cross cable:
But if your PC doesn't have two COM ports OR you don't wish to make any cables, you can be using a virtual serial port program, it can to make this without any cables.
You can download it (for ex.) here (the RS link is working, tested):
http://www.sonsivri.com/forum/index.php?topic=5875.msg27815#msg27815
Hope this helps.
zuisti
remromgab15
« Reply #9 on: December 10, 2007, 06:14:07 06:14 »
If you need some help please email me at space_abyss(at)yahoo.com. We're of the same blood so I can even give you some source code if you need it.
rov1976
-Given: 594
« Reply #10 on: December 13, 2007, 09:20:05 09:20 »
hi there sir, i'm also interested in dwelling w/ this project i'm planning to communicate w/ it to a mobile phone for sms project i'm planning to build... cam you give me a shed regarding this projects... regards, rov1976
