April 28, 2026, 07:01:18 19:01
Author Topic: 18pin DIP microcontroller identification (Not PIC)  (Read 7842 times)
medik
-Given: 76
« on: September 04, 2014, 07:36:37 19:36 »
I am trying to identify an 18pin DIP microcontroller in a circuit.  The details I know about the chip from the circuit are thus:
VDD @ pin 12, VSS @ pin 9, reset @pin 11, pins 7&8 were used for ADC input. other pins as I/o ports.
I know that PIC microcontroller has pin14 as vdd and vss at pin 5, reset / MCLR at pin 4 for 18pin configuration.
Anyone know the family of this microcontroller with the pin details. Physically,  it looks like regular 18pin dip picmicro eg pic16f628.
CocaCola
-Given: 170
« Reply #1 on: September 04, 2014, 08:02:38 20:02 »
Any idea on the date of manufacture, that might help limit the manufactures down as well as series...
Also it could be proprietary...
« Last Edit: September 04, 2014, 08:59:40 20:59 by CocaCola » Logged
-Receive: 4460
« Reply #2 on: September 04, 2014, 10:08:16 22:08 »
microchip and others will & do supply custom wire from ic die, to chip header/carrier.
CocaCola
-Given: 170
« Reply #3 on: September 04, 2014, 11:38:59 23:38 »
Yep, quite common so that parts are universal for legacy products aka drop in replacement for out of production (or shared production) parts so that a board re-design isn't necessary...
medik
-Given: 76
« Reply #4 on: September 05, 2014, 01:32:00 01:32 »
I never thought of the possibility of  custom wire of pins from a manufacturer like microchip. Now i know it's possible.
I forgot to add that the chip uses an internal oscillator to function.
underneath the chip, LQ7A1023N is printed while "GO" is embossed centrally.
PICker
-Given: 208
-Receive: 110
« Reply #5 on: November 22, 2014, 10:00:16 22:00 »
Did you find the IC as part of a specific circuit?
medik
-Given: 76
« Reply #6 on: November 27, 2014, 09:28:21 09:28 »
Yes, it was part of a specific circuit board. I've studied it and implemented with Microchip pic. obviously,  was a custom chip
