Tom1234
« on: August 10, 2014, 11:58:50 11:58 » |
I would like to built a programmer for dspic33 series microcontroller.Where can i find any resources?
-Receive: 4459
« Reply #1 on: August 10, 2014, 01:03:06 13:03 » |
Tom1234
« Reply #2 on: August 10, 2014, 01:42:01 13:42 » |
I am looking for any shematic
« Reply #3 on: August 10, 2014, 02:55:44 14:55 » |
sarah90
« Reply #4 on: August 10, 2014, 06:22:09 18:22 » |
-Given: 239
-Receive: 1055
« Reply #5 on: August 10, 2014, 07:56:11 19:56 » |
Why do you not get your self a PICKIT 3. If it is over your budget why not a clone? This would make your life much more simple. Just saying
TucoRamirez
-Given: 257
-Receive: 115
« Reply #6 on: August 11, 2014, 03:08:12 03:08 » |
even a cheapo chinese PK3 clone would work (i have mine from wide dot hk and 2 years and still alive and dancing mambo). even a pk2 as far as i remember could program your baseline dspics... anyway in worst case , ast k to your local friends to program your dspic with any light bootloader available and have fun by using bootloader ... assumming that you have friends
Tom1234
« Reply #7 on: August 11, 2014, 01:47:22 13:47 » |
I have already a programmer which i can use it to program dspic33 series.
I would like to create a project in which i will use a surface mound component of dspic33 , so i think is a good idea instead to program the microcontroller and then to soldering to pcb to have a minus circuit (part of the project in the same board) which will be able (with a change of a position of the jumper )to program the microcontroller.
That's why i would need the circuit of the programmer instead to buy a programmer.
-Receive: 4459
« Reply #8 on: August 11, 2014, 02:13:25 14:13 » |
so why not use ISP mode? or as others have said a bootloader.
« Reply #9 on: August 11, 2014, 03:27:07 15:27 » |
I can't believe that you have written a code for dsPIC and you are just thinking this way, smartass : ) you can simply use a bootloaders, which is why people created them in the first place, to avoid putting a programmer on the same PCB, or even using the programmer when off-site. SMD has nothing to do with the necessity of adding a programmer on your PCB and not using a bootloader, you sound very ridiculous... You can even put a 5-pin header on your PCB and use the programmer when ever you want... this section started sounding like www.picfreaks.net
-Given: 239
-Receive: 1055
« Reply #10 on: August 11, 2014, 07:00:52 19:00 » |
Ok let us start this over, as it clearly has taken the wrong direction. You have a programmer that is working. Can you provide any link for this unit? Many(most) PIC32 demoboard also provide an ICSP port that can be used to program off board ICs.
« Reply #11 on: August 11, 2014, 11:44:24 23:44 » |
Gee metal? Angry much?  Bootloaders for the dspic33 are pretty easy to come by. I agree this would be the best approach unless you need debugging functionality for some reason.
krishna.velu
« Reply #12 on: August 12, 2014, 07:28:19 07:28 » |
I think you are going in a wrong direction of putting the programmer & the DSpic in the same PCB. Use Jtag/ISP header in the PCB & and use the working programmer you have.
adelgado
« Reply #13 on: September 07, 2014, 08:53:55 08:53 » |
Take a look at this programmer, it's very easy to build it by yourself (due to the 1 layer PCB), it supports dspic family and has ICSP connector to program pics without extracting of the PCB or Socket http://openprog.altervista.org/OP_eng.htmlBest Regards.
joebazoka
-Given: 45
-Receive: 32
« Reply #14 on: October 11, 2014, 07:10:06 07:10 » |
You can try Pickit 2 or Pickit 3.Maybe is a good solution buy Pickit 3, is low expensive programmer.
