baoshi
« Reply #25 on: August 23, 2014, 03:13:40 15:13 » |
I have a logic 8 clone and it works all the way up to 1.1.20 (beta). The particular feature I needed since 1.1.19 is USB low speed analyzer. This is super handy for V-USB debugging.
ficho
« Reply #26 on: September 27, 2015, 03:50:45 15:50 » |
Hi, Additionally, each Spartan-3A FPGA contains a unique, factory-programmed Device DNA identifier useful for tracking purposes, anti-cloning designs, or IP protection. Some MATH and comparing to magic bytes in eeprom content should be the protection mechanism. Maybe reversing the software can help, just for curiosity.
Regards Ficho
Marcustv
-Given: 224
-Receive: 15
« Reply #27 on: October 06, 2015, 05:09:35 17:09 » |
I have a logic 8 clone I tested the new standalone version 1.23 and work very well Now you can analyze many more standard of older versions
ficho
« Reply #28 on: October 08, 2015, 10:43:28 22:43 » |
Logic 8 works with all version's, logic 16 is the problem, since logic 16 has an FPGA inside... regards ficho
markus_7
« Reply #29 on: November 19, 2015, 03:28:31 15:28 » |
Can someone give me old version of logic 16 which came with CD. unfortunately I lost my CD. With 1.1.15 I always get error "not able to keep up with the rate". As ficho said "Logic 8 works with all version's, logic 16 is the problem, since logic 16 has an FPGA inside"
« Last Edit: November 19, 2015, 03:37:10 15:37 by markus_7 »
towlerg
-Given: 474
-Receive: 104
What is this for?
« Reply #30 on: November 19, 2015, 08:06:08 20:06 » |
You can stil download 1.1.15 from Saleae website.
George
Win 7 Ult x64 SP1 on HP2570p
markus_7
« Reply #31 on: November 20, 2015, 12:17:58 00:17 » |
Download 1.1.15 from Saleae website doesn't work with Saleae 16 FPGA(Xilinx). I have tried different OS(windows, Linux distributions), USB2, USB3 without success  . On CD there was a crack. Someone who owns old CD please upload the crack. Thanks in advance.
cadence
-Given: 103
-Receive: 430
« Reply #32 on: November 20, 2015, 02:31:03 02:31 » |
Link to the files originally supplied on CD (untested as I don't have a clone device to test it with).
markus_7
« Reply #33 on: November 20, 2015, 01:54:07 13:54 » |
Thanks for Links. I tried this folder on my VM (Windows 7, Windows XP). Unfortunately I get same error "not able to keep up with the rate".
peacemaker
« Reply #34 on: November 22, 2015, 02:09:43 14:09 » |
maybe the VM is the problem. Did it worked before in the VM? Is there any usbhub used? I dont have a Logic 16, only the Logic 8. You can try sigrok to test if it would work in the VM, its supported. http://sigrok.org/wiki/Saleae_Logic16phil
markus_7
« Reply #35 on: November 25, 2015, 02:20:00 02:20 » |
No, I didn't try before on VM. No there is no usbhub. Sigrok is nice, but no good instructions available yet.
I also tried on Windows 10 machine without VM. Unfortunately I get same error "not able to keep up with the rate".
« Last Edit: November 26, 2015, 12:20:56 12:20 by markus_7 »
sarah90
« Reply #36 on: December 17, 2015, 05:02:39 17:02 » |
Download 1.1.15 from Saleae website doesn't work with Saleae 16 FPGA(Xilinx). I have tried different OS(windows, Linux distributions), USB2, USB3 without success  . On CD there was a crack. Someone who owns old CD please upload the crack. Thanks in advance. Have you tried the newest beta versions? My problems with the logic 16 clone started when they changed the protocol in the 1.1.19 and 1.1.20 versions. May be yours works correctly with the newer software and just not with the old 1.1.15 version.
