March 27, 2026, 07:34:03 07:34
Author Topic: Interfacing External SRAM with ATmega128?  (Read 6433 times)
xpress_embedo
-Given: 122
-Receive: 254
« on: June 28, 2014, 05:21:58 17:21 »
Hello!! Everyone!!
I want to interface External SRAM with ATmega128 Micro-controller, after searching on internet i found this link.
http://www.scienceprog.com/adding-external-memory-to-atmega128/
I want to achieve the same thing, but the problem is that i don't know how to change linker setting in AVR Studio 5.1.
It is written in the link to add this in Linker Option
-Wl,--section-start,.data=0x801100,--defsym=__heap_end=0x8030ff
But i did not get where to change this.
schisanoa
« Reply #1 on: July 09, 2014, 10:10:02 22:10 »
If I understand you are looking for the location of the linker option menu, right? If yes it should be under the project option menu. Or try with menu Project -> properties, toolchain, AVR/GNU linker, miscellaneous.
xpress_embedo
-Given: 122
-Receive: 254
« Reply #2 on: July 10, 2014, 05:22:40 05:22 »
I know where is the linker option is available, it present in
Project->Project Properties
After that select AVR/GNU C Linker
But i dont know how to modify it to use external sram.
If someone can upload the snapshot of this process, it will help me alot.
h0nk
-Given: 302
-Receive: 272
« Reply #3 on: July 10, 2014, 06:01:44 06:01 »
Hello xpress_embedo,
if the options are flagged with a: -Wl as Your example, they are used in the context of the
compiler driver. So You must add them to the compiler options (and not as expected
to the linker options.)
Best Regards
krishna.velu
« Reply #4 on: July 30, 2014, 10:42:14 10:42 »
"gcc" is a compiler.
"ld" is a linker, in the GCC world.
-Wl says the gcc compiler to pass the following option to the linker. The thing is you can call the linker through the compiler indirectly.
So when you invoke "gcc main.o" this will compile & link (internally calls ld also) will give the final executable.
If you call gcc with option -C it will just compile wont link. So if you want to pass a flag to linker ld through compiler you should use -Wl
example
gcc main.o -Wl,lgcc
In this lgcc will be passed on to linker saying that linker to use the library "gcc" (here gcc is library libgcc.a not the compiler "gcc.exe"  Cool Tongue)
@xpress_embedo if you explain the whole process or all the compiler/linker options you use, then I can help you.
