April 29, 2026, 07:13:45 07:13
Author Topic: Serial datacomms over DC power line  (Read 4978 times)
philsat
« on: September 28, 2007, 08:45:46 08:45 »
Hello all,
I'm starting a project to control motors via a serial interface. It should look something like this :
Powersupply 20V/10A ------+------------2wire------------+--- Serialdata receiver 1
                                      ¦                                         Â¦    and controller for motor-----------> Motor 1
                                      ¦                                         Â¦
    serial data --------------¦                                         Â¦
        2 wire
        +--- Serialdata receiver 2
        ¦    and controller for motor----> motor 2
        2 wire
        Â¦
        +--- Serialdata receiver 3
        ¦    and controller for motor-----------> Motor 3
                                                               ....... (up to max 8 units)
The controller for the motor (PIC) and serial data comms is not a problem.
The only thing I am struggeling with, is how to mix the serial data with the DC power lines (2 wire)
Is there a chip avaiable for ?
Has anybody has any idea to solve this problem ?  Huh
Thanks in advance !!!
bozzalla
« Reply #1 on: September 28, 2007, 09:44:36 09:44 »
Hello, a good idea is AN2346 Cypress application note:
This project describes a low-cost, intelligent sensor network. The proposed network can be used for home and office automation, remote monitoring and control, securing and fire alarm systems, remote lighting control, and other applications that require low-cost, low-speed, bidirectional data communication.
This network is Power+data using AC modulation technique bui I think that is possible to modify versus DC power.
Regards all
GM Bozz
bogdantk
-Given: 40
« Reply #2 on: September 28, 2007, 12:26:35 12:26 »
Hello
A HART modem will do the work
Check Google for HART modems and you will find a lot o IC's
All the best
Bogdan
proton
-Given: 32
-Receive: 159
« Reply #3 on: October 29, 2007, 02:27:20 14:27 »
Use a modulated carrier freq of say 100khz with your serial signals using any nice modulation technique then use an inductior or may be an LC to isolate your carrier from DC.It is not any hard to design.
proton
Trishool
« Reply #4 on: November 01, 2007, 09:38:46 09:38 »
Hello all,
                                      ¦                                         Â¦
        2 wire
        2 wire
        Â¦
Philsat , have a look at this link http://www.yamar.com/DCB500.html
I havnt tried such thing on DC lines , but only on AC lines PLMs which tend to be very unreliable
Is this DC supply comming from your battery or converter? makes a difference .
TrIsHooL
