March 15, 2026, 10:26:25 22:26
Author Topic: Flowcode Compiler PRO for PIC Microcontroller Development  (Read 28353 times)
8051
-Receive: 14
« on: December 28, 2005, 01:18:25 13:18 »
There is link
http://www.worldcore.net/viewtopic.php?p=5951#5951
arash
« Reply #1 on: December 28, 2005, 02:25:04 14:25 »
What does it do
freddyg
« Reply #2 on: December 28, 2005, 05:27:01 17:27 »
arash, have a look at the company's brochure (PDF):
http://www.matrixmultimedia.com/datasheets/TEFLC-60-2.pdf
Freddy
« Last Edit: December 28, 2005, 07:54:00 19:54 by freddyg » Logged
Acme
« Reply #3 on: February 17, 2006, 02:17:26 14:17 »
I'm looking for the manual for this software v2.1
QUARK
« Reply #4 on: May 09, 2006, 11:17:06 11:17 »
i can't download it
8051 can you update it ??
robban
-Given: 34
-Receive: 38
Warrior
« Reply #5 on: June 16, 2006, 11:53:58 23:53 »
Hi!
Here comes Flowcode 2.2:
1.http://rapidshare.de/files/9949805/TEFLC_021_by_WC.rar.html
2. run serial
3. http://rapidshare.de/files/10080371/Flowcode_Update_V2_2_0.zip.html
Pass: www.worldcore.net
At least rapidshare use the Latin alphabet...  Wink
Code Warrior
Yuriy
« Reply #6 on: June 17, 2006, 02:34:37 02:34 »
OMG this is great, robban is the win!!!  Thanks robban for the GREAT share.Smiley
meax98
-Given: 1376
-Receive: 52
« Reply #7 on: June 19, 2006, 01:53:21 01:53 »
Thanx robban!
robban
-Given: 34
-Receive: 38
Warrior
« Reply #8 on: June 19, 2006, 02:33:11 14:33 »
Dax!
Everybody has to start somewhere..
Code Warrior
robban
-Given: 34
-Receive: 38
Warrior
C
« Reply #9 on: June 20, 2006, 03:44:10 15:44 »
Hi Dax!
Thanx for the Embedded C. I don't agree with You that C is easy, especially if You are used to BASIC. The whole concept of functions are totally different, for one thing. But, if one takes the time to learn it, it bloody well pays. No more spaghetti code...
Code Warrior
Zaphod Beeblebrox
-Given: 27
-Receive: 105
« Reply #10 on: June 20, 2006, 05:37:59 17:37 »
From another old-schooler -  I completely agree with your opinion Dax Wink
Anyway, if somebody wants to play with such a toy it's all right (still far better than sitting in front of a TV). But, it's not a tool for a serious design. I bet you...
Black holes are where the God divided by zero...
Don't panic!
robban
-Given: 34
-Receive: 38
Warrior
« Reply #11 on: June 20, 2006, 06:46:48 18:46 »
I forgive u, under one condition; vote for Sweden against England in soccer tonite...
Code Warrior
robban
-Given: 34
-Receive: 38
Warrior
« Reply #12 on: June 21, 2006, 03:19:24 03:19 »
Good!
We all rely on stupid and clever Americanos. Did You know that Bill Gates started out as a BASIC programmer?, and that Windows and DOS is founded upon that stupid language? That is probably the reason for 32-bit windows being so fragile... By the way, 2-2 is an acceptable score and we(sweden) must face Germany on their own turf in the next game...
Code Warrior
8052
« Reply #13 on: June 23, 2006, 11:51:37 11:51 »
Soccer? I thought a Form of big ball Played by two teams of 11 players with a round ball which may not be handled  during play even by the goalkeepers.
and Start just like
and played just like
and
daydreamer
« Reply #14 on: September 26, 2006, 06:39:37 06:39 »
Hi  , Iam new to C and found it eassy to go with the below given tutorial as a beginer could any body pls share full tutorial thanks.
http://www.softwaretrainingtutorials.com/c-programming.php
verde321
-Given: 79
-Receive: 40
« Reply #15 on: October 02, 2006, 09:01:25 21:01 »
Thanks Robban for the greates post
Dax thanks for the books
Thank great guys Wink
thoroide
-Receive: 72
« Reply #16 on: October 03, 2006, 01:50:00 13:50 »
The s/n is not correct. The installation program ask for a set of 4 field that must contain 3 chr. The supplied serial have 4 field with 4 chr. The S/N doesn't fit the fields.
There are a valid s/n around ?
Thanx
thoroide
-Receive: 72
« Reply #17 on: October 03, 2006, 01:53:00 13:53 »
"It all the same but different."
A loop is a loop, an assignment is an assignment and an "if" is an "if.
FOR I = 1 TO 100
    A = A + 1
NEXT I
or
for ( I = 1; I <= 100; I = I + 1 )
    A = A + 1;
Basic started out as an introductory programming language for students, like training wheels for a bicycle. It is maladjusted, IMHO, to continue using Basic after a very brief initial learning period. Today, an embedded systems student should start only with C. It's only a little harder and will be a valuable skill in the commercial market for years to come. If you even have a suspicion that you may ever one day make a living programming embedded systems, learn C now.
You don't have to be smarter or more educated to use C. It's just a simple procedural language.
Remember, if you start programming with Basic, it will be your "first language" for the rest of your life. You will think in Basic and will have to learn other languages as a second language. People should do the wise thing and start with C or switch to it ASAP.
(Don't belive me? Fine, why should I care? But later, don't say you weren't warned.)
As I remember in C  a = a + 1;  is not truly correct and can give unexpected results between various compiler, normally it is a++; that give the same result between compilers.
Smiley
Bye Lips sealed
chandra2sekhar2000
« Reply #18 on: August 02, 2007, 05:31:34 17:31 »
hello robban
thank u, i downloaded v2.1 and installed whwn i run it, it says  "wrong disc inserted".what is the solution,and also plese upload v2.2 update or evennewer version
Arjen
« Reply #19 on: August 14, 2007, 02:20:09 14:20 »
Update link
http://www.matrixmultimedia.com/support/viewtopic.php?p=1093&sid=8a819bfc13456a0cf19deedca7071745
 Grin
iphone
-Given: 115
« Reply #20 on: August 14, 2007, 04:46:28 16:46 »
update to version 2.1 / version 2.2    Huh
« Last Edit: August 14, 2007, 04:53:41 16:53 by iphone » Logged
