April 28, 2026, 04:22:27 04:22
Author Topic: CCS SD CARD FAT.C- MMC.C  (Read 10179 times)
Tom1234
« on: March 17, 2014, 08:36:37 20:36 »
I try to program a dspic33 series microcontroller with ccs compiler.
I try to use FAT.c, MMC.c  drivers which are provided by the compiler but unfortunately these codes are buggy.
I know that there are a lot of thread here about this issue but all the links are deads.
Is anyone who has a bug free code drivers(fat.c,mmc.c)Huh
Old_but_Alive
-Given: 840
-Receive: 122
« Reply #1 on: March 17, 2014, 08:47:01 20:47 »
you would be much better off trying the CCS bulletin board.
I tried to implement CCS's drivers, and they are rubbish.
But, there is loads of good info on the board, search "SDcard" amongst others
user asmallri has a website where he sells working drivers.
« Reply #2 on: March 18, 2014, 06:01:21 06:01 »
Give microchip's FAT and SD driver a try.  They were a little shaky a few years ago but most of the issues had been fixed and I used it in a production environment without any issue for data logging and bootloading.
Tom1234
« Reply #3 on: March 19, 2014, 01:12:31 01:12 »
Gallymimu what is the compiler version did you use (and it was fine)??
Ak_embedded
« Reply #4 on: March 19, 2014, 09:58:01 09:58 »
I good implementation that works is available at http://www.dharmanitech.com/2009/01/sd-card-interfacing-with-atmega8-fat32.html
For PIC controllers you need to port and cross compiler the available source.
Also you can have a look at http://www.sonsivri.to/forum/index.php?topic=52381.0
danifox
-Given: 38
« Reply #5 on: January 10, 2015, 11:27:06 11:27 »
While using CCS I would recommend you to either implement your own driver or use a freeware/shareware one, because CCS built-in SD driver doesn't work with SD v2 cards.
