March 14, 2026, 07:45:44 07:45
Author Topic: Suggest a low cost microcontroller development board.  (Read 8011 times)
itp
-Given: 225
-Receive: 20
« on: January 10, 2014, 10:08:11 10:08 »
Hi All,
Kindly suggest a low cost microcontroller development board for remote controlling of a power supply.
The development board should have:
1.  Ethernet and USB connectivity for remote control
2.  4 Channels of Analog Input with 12bit resolution
3.  2 Channels of Analog Output with 12bit resolution
4.  10 Digital I/O's
5.  PIC or 8051 based boards are preferable.
Thanks and Regards
Itp
TucoRamirez
-Given: 257
-Receive: 115
« Reply #1 on: January 10, 2014, 10:13:11 10:13 »
check for any pinguino board for pic, maybe this will be interesting for your budget (in olimex page)
Mentor
-Given: 61
« Reply #2 on: January 11, 2014, 03:33:03 03:33 »
There aren't many PICs with 12 bits ADCs and 12+ bit DACs, this may be a problem. Do you mind to use a dsPIC or a PIC24?
What about using some Arm Cortex-M board?
edeca
« Reply #3 on: January 13, 2014, 07:29:32 19:29 »
Do you definitely need that much resolution in your analogue input and output?  You will almost certainly need an external DAC to get this close with a small microcontroller.
How about something like the Analog ADuC range (datasheet)?  These are designed as precision ADC and DAC devices with a uC core.
What power supply are you trying to remote control?
h0nk
-Given: 300
-Receive: 272
« Reply #4 on: January 14, 2014, 12:41:55 00:41 »
Hello Itp,
the Silabs C8051F020 has a 12 bit ADC with 8 inputs and 2 12 bit DAC's
and lots of 5 V-tolerant IO's.
JTAG for debugging is also available.
XRAM for data can be extern extended up to 64 kbyte.
It is based on the (One-Cycle-)8051 core and can run at 25 MHz.
But no USB and no Ethernet.
Evalboards and JTAG-Adapters are available at ebay.
Best Regards
itp
-Given: 225
-Receive: 20
« Reply #5 on: January 14, 2014, 01:02:38 01:02 »
Any ADuC or dsPIC development board with Ethernet port and TCP/IP stack available.
What is your opinion of using the low cost single board computers Raspberry PI and BeagleBone Black in such application?  I don't have any experience on Linux environment.
Thanks and regards
Itp
mike_au
« Reply #6 on: January 14, 2014, 05:24:25 05:24 »
As far as I can see the only requirements that the RPi meets are ethernet and probably the the 2 output channels.
The USB interface is capable of device mode operation but sits behind a hub so it isn't easily accessible.
It doesn't have any analogue inputs.
It only has 8 digital IO pins.
Add to that a lack of Linux experience and it doesn't seem like a terrific fit your your requirements.
I'm not as familiar with the Beaglebone so maybe that has a few more peripherals and would be a better option but personally I would tend towards a larger uC.
« Reply #7 on: January 14, 2014, 03:46:52 15:46 »
No PIC with 12 bit ADC & DAC, but recently microchip announce their new PIC24 GC series which is very interesting - 16 bit sigma delta ADC + 12 bit 10 MSPS Pipeline ADC + 10 bit 1 MSPS DAC + USB Device/Host/OTG.
Have a look, i ordered some recently including the Dev. Kit (not fit with the requirement as it has no ethernet).
centiane
« Reply #8 on: February 10, 2014, 09:41:13 09:41 »
Hi Itp, Silabs C8051F340 is same of C8051F020 and add USB module, the development kit round as 35$.
This is a very good choose.
Regards Centiane.
h0nk
-Given: 300
-Receive: 272
« Reply #9 on: February 10, 2014, 10:52:50 10:52 »
in the last few days i got my hands on the STM32F107VC.
This beast has it all.
- 12 bit A/D
- 12 bit D/A
- USB Client/Host/OTG
- Ethernet MAC (but without PHY)
- SPI/I2C/CAN/UART/USART/TIMER
- GPIO's
With the 'de'-evaled Version of the CMX MicroNet Library i was able to get up a
small NTP Server in some hours.
Buts its a beast. It will bite You :-)
Best Regards
Stokni
-Given: 21
-Receive: 12
« Reply #10 on: February 23, 2014, 07:56:02 07:56 »
have you looked at the mikroe site? they have boards for PIC and 8051, can be extended with small cards to use any functionality.
i use the easypic 6 and 7 and am very happy with it.
PaulC
-Given: 3935
« Reply #11 on: February 23, 2014, 12:34:49 12:34 »
MikroElektronika Boards http://www.mikroe.com/
have had the rounds from me to i use :
easy avr5 ,easy avr5a , bigavr, easy pic, with my son as learning tools.
they are reliable and have had some stick..also the small board add-ons are useful to.
i have had boards & add-ons from  http://www.futurlec.com/index.shtml
these are better priced and also reliable..
Cain
-Given: 170
-Receive: 102
« Reply #12 on: March 16, 2014, 11:54:11 23:54 »
I'm looking for a TCP/IP stack for 8051 so I wonder if the one you used are specific for STM32? If not is this 'de'-evaled version available somewhere?
