April 25, 2026, 06:12:05 06:12
Author Topic: CoreChart P18 v2.2.35  (Read 6908 times)
Thiru09
-Given: 412
-Receive: 1188
« on: September 22, 2007, 10:47:26 10:47 »
Applciation Name:
Links:
http://rapidshare.com/files/57413681/CC18.rar.html
Program Info:
http://www.elabtronics.com/products_cat_CoreChart16Lib.htm
Installation Info:
1. Install the application.
2. Launch the application. It will run in trial mode.
3. Replace the original executable with cracked one.
4. To see your name in about dialog box, do the following.
(If you have installed CoreChart (uploaded in this forum), this step is not necessary)
    Open registry.
    Locate HKEY_LOCAL_MACHINE\SOFTWARE\eLABTRONICS\
    Create new STRING value and name it Owner and give your name as its value.
    Close registry.
   Re open the target and check about dialog box. Your name will be appeared as registered user.
With best regards,
-Thiru
