April 11, 2026, 10:50:35 22:50
Author Topic: CodeLobster v3.3.0  (Read 7251 times)
o2
-Given: 41
-Receive: 405
« on: September 20, 2007, 04:01:12 04:01 »
Codelobster is a web code editor, that supports TXT, CPP, JAVA, JSP, PHP, PL, ASP, HTML, CSS, XML, XSL, JS, VBS and SQL. It offers all the standard editing tools, as well as built-in online and offline preview, syntax highlighting, spell-checking, code collapsing, as well as auto-complete and context help for JavaScript, CSS and ASP code. It can also convert HTML files into JSP, PHP, PL, ASP ones and vice versa.
Codelobster's main features:
Autocomplete for HTML, PHP, JavaScript, CSS, Perl, Python, Action Script, SQL, ASP, VBScript, Ruby
Bookmarks are easily navigated owing to ad hoc window where all of them are grouped by files
Case converting for tags and attributes
Context help for HTML, PHP, JavaScript, CSS, Perl, Python, Action Script, VBScript, Ruby allows to work with local sources as well as with online references (e.g. local MSDN and msdn.microsoft.com for HTML, JavaSript and VBScript; php_manual_en.chm and www.php.net for PHP; local MSDN and www.w3c.org for CSS)
Code collapsing like the one in MS Visual Studio for all supported languages including HTML and XML
Code comment/uncomment for all supported languages
Advanced code formatting allows to put any code in typical order, which is particularly helpful when working with HTML files
Conversion of chars to entities and vice versa
Conversion of HTML code to ASP, JSP, Perl, PHP functions and back to HTML
Support of different text encodings and WIN/UNIX/MAC text format
Execution of scripts: JavaScript, VBScript and Windows Script Host
Easy-to-use file explorer dockable control with FTP/SFTP support and output window
Find & Replace combined dialog
HTML validator on W3C
HTML Tidy tool with output window
Macro recording
Project Manager enables simple handling of whole projects
Quick selection of current block and navigation along it is eminently useful when working with HTML files
Spell-checking with English dictionary
Supported formats: Text, HTML, CSS, JavaScript, VBScript, PHP, ASP, C#, Perl, Python, Java/J#, Jsp, XML, XSL, C/C++, SQL, Action Script, Ruby
Templates for all supported file types
Transliteration allows to aviod repeated input when you forget to switch keyboard layout
Visual style customization : Windows 2000, Windows XP, Office 2003, Visual Studio 2005 and Classic styles
http://rapidshare.com/files/56739650/CodeLobster.v3.3.0.Incl.Keymaker-ARN.zip
TirthankarMukherjee
« Reply #1 on: September 13, 2008, 03:42:48 15:42 »
thanks a lot dude ..
