October 13, 2025, 06:50:26 18:50
Author Topic: ON/OFF timer using PIC with simulation  (Read 7938 times)
micropcb
-Given: 53
-Receive: 390
« on: August 02, 2013, 02:50:23 14:50 »
Hello everyone.
Here is an accurate ON/OFF timer using PIC16F877. The simulation is included. The times in simulation are obviously not accurate but the real hardware does a good job.
The howto file included explains how to use it.
Best regards.
--micropcb
micropcb
-Given: 53
-Receive: 390
« Reply #1 on: August 02, 2013, 03:56:22 15:56 »
I remember it was generated using CCS C . It is an old project and I am trying to find the source.
Cheers.
« Last Edit: August 02, 2013, 04:51:44 16:51 by bbarney » Logged
« Reply #2 on: August 02, 2013, 04:12:30 16:12 »
How accurate is it?
-Given: 405
-Receive: 545
« Reply #3 on: August 02, 2013, 04:53:23 16:53 »
Hey Solutions
I made Reply # 2 easier for you to see so you don't report it again  Wink
micropcb
-Given: 53
-Receive: 390
« Reply #4 on: August 03, 2013, 04:29:43 04:29 »
@Solutions,
The timer was not implemented using software loops but we had used the internal timer of the pic to get  the programmable timings generated. It was made for an application (air conditioner) in which the client was happy with even +/- 10 sec for a 10 min delay. He was more interested in having a programmable timer. However  I remember we landed up with +/- 1 sec for around 20 min. We did not improve the code further.
@bbarney
It was a fairly simple program and I am no more tied up with my then employer . Please give me a day or two and I will surely provide the source the moment I locate it.
Best regards.
gan_canny
-Given: 101
-Receive: 26
« Reply #5 on: August 03, 2013, 01:35:08 13:35 »
With PIC timers there are things to be aware of. The accuracy of the timer can't be more accurate than the PIC clock. It's best to use a Xtal but even Xtals are subject to temperature and to a drift cause by aging. The hardware timers within the PIC are for accuracy most often run of the external xtal processor clock. Some PIC timers can run of an secondary xtal such as a watch xtal (32768 hz). For very short duration timers instruction time to read the timer is relevant. The PIC has very deterministic instruction times so they can be counted and allowed for. This is specially of relevance for timer interrupts where the time to save and restore registers can be a factor effecting the frequency of measurements.
-Given: 405
-Receive: 545
« Reply #6 on: August 03, 2013, 06:10:26 18:10 »
@bbarney
Best regards
Not me who want's it - someone complained because it wasn't included
« Reply #7 on: August 03, 2013, 07:03:16 19:03 »
1 sec in 20 min is about 800ppm for the posted project.
for comparison...
general use stuff:
PIC RC oscillators are usually about 1-2% or 10000 to 20000ppm
typical crystal is about 100ppm
watch crystal is about 20ppm
now the fancy stuff:
OXCO oven controlled crystal is 0.001ppm
Rubidium 0.000001ppm
Cesium 0.0000001ppm
so, no offense, but even for use of conventional crystals the accuracy of this isn't very good assuming you are using a crystal.  I'd imagine the 800ppm is due to error in the timer period calculation.
Vineyards
-Given: 66
-Receive: 37
« Reply #8 on: August 03, 2013, 11:23:28 23:23 »
I use RTC chips such as DS1302 or DS1307 for equipment to be left outdoors in industrial areas. When I get back to check them say 6 months later, I observe that they are fast or slow between 20 mins and sometimes upto a full hour. Unless you have a means to automatically update them you will always end up with a result like that. Invest in low ppm crystals to make it as accurate as possible. The comprimise here is between cost and practicality. You can invest in expensive gear and provide room for it in the housing as well as satisfying the increased power demand if the design necessitates it. Otherwise, you neex to be happy with what you can achieve with the run of the mill components.
« Reply #9 on: August 03, 2013, 11:34:20 23:34 »
That's an interesting post, while reading it came to me asking about commercial products which use 32KHz crystals, then they suffer the same drifts, I wonder how they achive better accuracy then?
« Reply #10 on: August 04, 2013, 03:27:27 03:27 »
did you have something in mind that is better without going to something really fancy?
Vineyards
-Given: 66
-Receive: 37
« Reply #11 on: August 04, 2013, 06:50:41 06:50 »
It is just a matter of how high accuracy is on your list of priorities. For example one of my devices has to work at high altitude and put up with drastic temperatures. The relay needs to stay open for 20 minutes once a day. What matters for me is not whether it goes on and off at exactly the designated times. 20 mins part is more important for me. So I can live with the error margin here. Commercial applications do vary significantly when it comes to time keeping accuracy.
« Reply #12 on: August 04, 2013, 01:45:40 13:45 »
Actually no, I am not an expert in this field, may be some sort of compensation is used, I wish I knew how commercial companies implement it.
Mentor
-Given: 61
« Reply #13 on: August 04, 2013, 04:00:39 16:00 »
I worked with some equipments that had GPS modules to keep a good timekeeping. I think that this solution is becoming cheaper every day.
« Reply #14 on: August 04, 2013, 06:10:57 18:10 »
I had a bad experience with DS1307 left outdoor in a metal box which have some ventilation holes, the clock drift more than 1 hour a day - the problem is we have a very humid air, the board is dewy in the morning. The problem solved by coating the RTC area mainly the x'tal with several coat of clear acrylic spray paint.
Since then i switched to DS3221 with 3ppm internal x'tal, i hate it is expensive..
Checksum8
-Given: 127
-Receive: 102
« Reply #15 on: August 04, 2013, 07:10:09 19:10 »
I have not tried this but it may be helpful.
http://www.romanblack.com/one_sec.htm
Vineyards
-Given: 66
-Receive: 37
« Reply #16 on: August 04, 2013, 08:07:08 20:07 »
Never tried that one.  Any differences in microcontroller communication?
-Given: 850
-Receive: 4409
« Reply #17 on: August 04, 2013, 08:32:18 20:32 »
why not make a crystal oven, set it over your highest temperature you expect to see.
LabVIEWguru
-Given: 274
-Receive: 593
« Reply #18 on: August 04, 2013, 09:33:25 21:33 »
Well, you must be using AC so steal some AC from one leg of your transformer and use a voltage divider to get an acceptable voltage. Now your micro can count the pulses or use a divider to give you a pulse per second or per minute. Software overhead goes up but hardware overhead goes way down. Set the time in software and 1 pulse per second gives you really accurate time. Downside is if you lose power your system doesn't know what time it is, unless you use a micro in low power mode with batteries. If we suddenly lose 60 Hz we have much bigger problems than air conditioning.
« Reply #19 on: August 04, 2013, 11:27:28 23:27 »
No, as i remember i did not change the code, probably the slave id is different - and sorry i mean DS3231.
« Reply #20 on: August 05, 2013, 02:21:44 02:21 »
How can I use PPM value to calculate the actual change in time for a given period of time counting? I mean how can I expect the change in given time after 3 days for example?
h0nk
-Given: 274
-Receive: 234
« Reply #21 on: August 05, 2013, 05:07:16 05:07 »
P.P.M. := Parts Per Million
3 days: 3 * 24 * 60 * 60 are 259200 sec.
259200 / 1000000 = 0.2592 sec
A crystal with 100 PPM deviation will result in an error of 25.92 sec.
Best Regards
« Reply #22 on: August 05, 2013, 10:39:13 10:39 »
wow, in a year this will drift nearly an hour..!
max
-Given: 1747
-Receive: 52
« Reply #23 on: August 05, 2013, 09:47:30 21:47 »
we can also use the analog quartz clock watches module, which gives an accurate 1 sec reference with built in temperature compensation and the deviation is less than +/- 1 min in a year. see the attached files.
« Last Edit: August 05, 2013, 09:56:26 21:56 by max » Logged
micropcb
-Given: 53
-Receive: 390
« Reply #24 on: August 09, 2013, 06:42:23 06:42 »
Finally managed to locate the source. Compiled it with CCS 4.130. Since it is "as is where is"  ,may require modifications for improvement.
